Onida ctv standby, r923 resistans is open so i want the resistants value
  • 1,238 Answers
Try to read the color code of your resistor, if the resistor was burnt you have to do is send your TV to tech.
Posted on Dec 10, 2012
How to get display in onida oxygen 250 ctv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 26, 2014 | Televison & Video
Onida 21''ctv picture coming in stamp type {cutting from four sides}
Hello
Replace its Horizontal output Transistor. If the base-emitter junction has a leak inside it, this type of fault will occur. Before replacing it, check the main DC voltage to LOT [Line Output Transformer]. It should come around 102VDC. If there is not this much voltage, check the electrolytic filter capacitor connected across thie supply line to main negative for open or value developed. Replace the same is good. Till there is low voltage found, check the retifier diode that rectifies this 102 volt DC. If all the above are OK and still you get a stamp like raster, check the heat of the Horizontal Output Transistor described above. if it overheats, LOT is defective and should be replaced with same type and number. OK.
Jun 12, 2011 | JVC Televison & Video
HOW CAN I ENTER INTO SERVICE MODE IN ONIDA COILOUR TV OXYGEN 21''DVMC (KY INSIDE) ?
with onida orginal remote we can open service menu(press vsm at the same time on remote control)and check the values, first write down the values before changing the values.
Apr 08, 2011 | Televison & Video
Sir, my onida 20xs ctv make high boost transister 2499 has burnt
MOST OF THE 2499 TR IS DUPLICATE .SO YOU USE ONLY OLD TR.WHICVH IS TAKEN FROM OLD CTV BOARD. OTHERWISE YOU CAN USE 25INCH CTV H OUTPUT TR.
Aug 03, 2010 | Televison & Video
I've got an Amstrad CTV 3121 N television. It does
Open internal fuse or power supply failure
Feb 10, 2018 | Televison & Video
Onida Audioport 21'' CTV no picture & sound
this is video section problum .pls check video mute trangester is sort.
or croma ic is filed
Oct 20, 2009 | Televison & Video
Onida stand by problem
sir my onida tv 21'' ineed un lock
Nov 07, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
