Question about Coby kyros Tablets & eReaders
My coby mid7010 only runs when battery charger is pluged in even though the battery indicator shows full
Cant remember my password
A really annoying issue but your password is Your and only you are supposed to know it.
So I guess your only choice is to do a Factory Reset of your Coby tablet:
Hope this Youtube tutorial might help you:
Factory reset on Kyros MID 7012 without using Settings
Also you should read these tutorial:
Coby Kyros MID7010 hard reset
http://webcache.googleusercontent.com/search?q=cache:eQiuI75ELTMJ:resetandroid.com/coby-kyros/+&cd=6&hl=es&ct=clnk
http://www.androidtablets.net/threads/how-to-factory-reset-on-coby-kyros.24344
You can get some more information doing a google search for
factory reset of Coby kyros Tablet
Jul 30, 2015 | Coby kyros Tablets & eReaders
Why my coby MID 7048 always show "damaged sd card"?
The internal flash memory is broken you may have a broken logic board. If you're out of warranty, somebody has to open the device and replace the logic board. The part is available on ebay. On youtube you will find a guide on how to disassemble an Acer tablet. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Coby Tablet Repair Services.
Nov 12, 2014 | Coby Electronics Corporation Coby Kyros...
Coby mid8065
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
Regards! If that helped, don't forget to accept my answer!
May 31, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
Battery not charging tablet gets hot and wont turn on
The battery is dead and cannot be recharged. Replace the battery.
Mar 26, 2014 | Polaroid S7 7-in. Internet Tablet
Coby mid7010 touch screen not working
Try recalbrating the screen in the main settings or go to a professional to get it fixed
Jan 20, 2014 | Tablets & eReaders
The coby tablet does not power on, although it has a full battery
i have soundlogic xt my device stil on android plz sand me slotion model no ks-umpco7ovk
Nov 07, 2013 | Coby Kyros 716829701508 Tablet PC
Coby Kryos Android Tablet is not charging. It is connected to a charger but its not charging.
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
May 21, 2013 | Tablets & eReaders
What are other causes of a phone not turning on besides a dead battery, overheating, and freezing?
replace the battery for starters
check that the charger is putting out the correct voltage
Jun 05, 2017 | HTC HD Windows Phone 7
I need to download driver software for my coby kyros MID7015 so i can sync it to my pc
i have coby kyros mid7010-4g tablet
it just load the coby logo then penguin logo then android_ text
i tried the factory rest ( power + back + home ) ..
it gives " Unexpected updater mode! Please reboot your device.
How do i proceed from here Any help please.
Mar 20, 2011 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
85 people viewed this question
Top Coby Tablets & eReaders Experts
Fred Block
Fred Block
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
