Im sorry for mucking you around especially the ones who are trying to help me solve a problem, i thought all computers have a tower, the so called tower is connected to the back of the computer..however we have tried to connect it, it says no video input...please tell me what cord are we missing if any,thank you...philips desk top computer model HN S1901
  • 7,627 Answers
It's difficult to say what is missing from my point of view, but the monitor cable looks like this example: http://www.bestbuy.com/site/Dynex%26%23153%3B+-+6'+PC+Monitor+Replacement+Cable/7003182.p;jsessionid=4F4A0BA3CDEA423AEE9239AA96261E0D.bbolsp-app04-17?id=1099391933657&skuId=7003182. Take a look at this, it may help: http://www.gcflearnfree.org/computerbasics/10. Good Luck
Posted on Dec 10, 2012
  • 3 Answers
SOURCE: Computer will not power on
Regarding the blinking green light on power supply for hp a430n...I've had that happen as well when the computer is turned off for an extended period of time. It would not immediatly power up when plugged in to power. Hitting it and beating on the button didn't help either.
However, after calming down, I noticed that when I unplugged the computer that the light continues to blink, but gradually fades and goes out. So, I thought that since power supply holds a charge after being disconnected as can other components inside a computer that I would assume the converse: It needs to power up to "full charge" as well. In my case, I was right.
All I did was plug the computer in and leave it alone for about 20 to 30 minutes, go sit and cuss for a while. When I came back and checked it after that time, the front panel blue light was on and the green light on the power supply was glowing steady. The computer started right up! Thank goodness...stopped cussing.
If it hadn't, and I had tried all the resets listed above, I would have bought a new power supply too...but not this time!
Posted on Feb 15, 2008
SOURCE: philips iqon recovery cd
http://global.msi.com.tw/index.php?f...=170&cat3_no=2
Posted on May 11, 2008
bunnydawg
  • 5158 Answers
SOURCE: inputs/plugs in back of computer
it's not dumb at all. i presume you didn't get a manual with it. give me the model number and i'll find you a start up guide. also most of the connectors will be colour coded. the two small round ones pink and green are ps/2 connectors. that is your mouse and keyboard. if you get them reverse it will just not boot. power connector is fairly obvious. I presume that has a dial up modem and not a network card. They are not interchangable.
Robert
Posted on Aug 27, 2008
bluegreenash
  • 661 Answers
SOURCE: no signal input
this sounds like fried graphics card... the clue being the error message before it died,
Does the PC boot so that you can see the Bios Screen, (the very first info that displays) the BIOS screen does not use the windows drivers and would be unaffected if a driver failure occurs,
if this is the case then press f8 on boot to select SAFE mode so you can remove/replace the graphics drivers (in device manager)
if you cannot get bios or safe mode, then try reseating your graphics card first as it may have just worked it way out of its slot (due to expansion of card/slot as system heats/cools)
if this fails to work then a replacement of the graphics card is probably what is required.
Posted on Sep 27, 2008
  • 135 Answers
SOURCE: Monitor malfunction, says VGA Input: No Signal and goes to sleep
from what you have described it appears that the onboard video might have malfunctioned,there is no way to replace it, you can however go buy a video card from your nearest computer retailer. you just want to make sure it is compatible with your machine. on another note from what your saying the keyboard is donig i would be wary about spending to much $$ because it could also be your motherboard
Posted on Apr 23, 2009
Ihi i have a samsung sp 43t6hp and it looks like im watching tv in 3d how could i fix the problem
Sounds like you need a convergence board. Problem is there might be some transistors that you need as well. I've had a similar issue. Most places will cost $300+ to replace what might be a $15 part. Also there are 2 transistors in there that need to be replaced at the same time (once one goes the other is likely to as well). I would suggest calling Sears to fix it. They charge much less for the visit ($99 min charge) and will replace both parts at the same time.
Sorry I know that's not a true answer on how to replace the convergence board or other parts but mucking around in a rear project tv is a good way to get shocked. Those TV's hold a lot of charge even after unplugging.
http://www.searshomeservices.com/televisions/repair
Mar 03, 2011 | Samsung HCL652W 65" Rear Projection...
No power to computer
This could be as simple as a dead power supply. Many powers supplies have a reset button located in the back of the tower, if yours has one, push it for about 5 seconds and try it. If it doesn't work (and you don't have a tester) here are a few thoughts:
Do you have an old computer lying around the house? Take out the power supply. There are 4 screws holding it in from the back of the tower and the power leads go to the motherboard, cd/dvd drives, floppy drive and ususlly one on the board for the system fans. Try swapping them.
If not you can take yours out and have it tested at your local computer store. When buying a new one remember that you have to get at least the SAME wattage as the one you have. A little more is ok but never less.
Oct 29, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Im trying to take pictures off it to my computer but it wont show up so i can get them please help
I downloaded a driver at one point from a company called Mobile Action for this same purpose. As I recall it cost $30 but it kind of worked..after mucking about with it for a while.
Oct 08, 2010 | Motorola Mobility RAZR V3m Cellular Phone
4got security code
Master reset code is 3547514211
Jul 12, 2009 | Nokia 6300 Cell Phone
No network/ no service
Your going to have to call T Mobile and have them reset your phone with the towers. You can usually call *228 from your phone. What that does, is it resets your phone with the towers around you and updates your roaming list. Try that, but if that doesn't work then call T Mobile using a landline phone and have them troubleshoot the problem. Hope that helps!
Mar 18, 2009 | Samsung Beat SGH-T539 Cellular Phone
I"m trying to hook up this Emachine and im having proble4ms connecting cdrom floppy hardrive
An external drive would have a cable you connect to the back of your tower. An internal would not have this but would connect directly to your motherboard on the inside of your PC Tower.
Based on your follow up question it appears you want to connect to an inside pin out connection point. Is this right? And if so, what type of cable do you have that need to connect? Is it thin and round or flat and wide?
Thank you for your patience. One of use will be able to help you further once you post this information. Sorry, but we actually need to konw this in order to solve your problem.
Regards,
Worldvet
Please use th comment box below to reply.
Aug 18, 2008 | Computers & Internet
Monitor driver
Dear Sirs.
I think that no especial plan need for solving this problem. I also thought, that such well-known website as FixYa and FixYa team have some programs archive. I'm sorry for inconvenience. I'll try to find driver for my monitor in other websites.
Best regards, Versy
Jul 24, 2008 | Computers & Internet
Installing a firewire pci Card onto my HP Compaq dc5000 Small Form Factor PC
Hi, Actually there are various types of customized firewire connections for your computer. Here is a link to view some products that might work with your computer. http://www.firewire-1394.com/firewire-usb-combo.htm Also, there are different sizes of PCI cards available. You have to shop around to find an apropriate size.
May 04, 2007 | HP Compaq dc5000 PC Desktop
Logitech Harmony Remote
Check the batteries are OK Uninstall it's software, reboot and reinstall it. See if there's a return to default option in the software. You may have mucked things up when you tried changing the configuration. Sorry I can't give more advice I don't know the hardware at all. BMW
May 15, 2006 | Logitech Harmony 628 LCD Remote Control
Computers & Internet Logo
David Payne
David Payne
