Question about LG 60PC1D 60 in. Plasma Television
The volume on my plasma tv goes up to 100 and when i lower the volume it will take a second volume for the volume to go up to 100 how can i fix my tv to lower the
I cant lower my volume it goes high to a 100 i touch the tv touch button to lower the volume when i let go it goes up all the way
  • LG Master
  • 8,617 Answers
The tact switch is most likely defective which is keeping the volume up engaged. Replace the tact switch should fix the issue. If not the button assembly pcb will need replacement. You can get replacement boards from www.tvcircuitboards.com
Posted on Dec 10, 2012
Power outage
It sounds that the main system control memory IC data has been currupted.
Sep 26, 2013 | RCA L32HD31 32 in. LCD HDTV
Volume Control
Look for any jammed buttons (keys) on remote control and/or on control panel.
Aug 12, 2012 | Televison & Video
The volume goes to 100% and will not lower by remote or using the volume button on the TV. If I use the up button to change the channel I think it was turning volume up. How can I fix this and will it be...
It could be the volume up tact switch is stuck thereby needing replacement. I cant help further without knowing the model number but www.tvrepairworld.com should be able to provide free tech assistance as well as any replacement part you might require.
Jun 01, 2012 | Televison & Video
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
Volume Control
check the up volume button on the set. it sounds like it is stuck in the on position. You can open the back and disconnect the wire harness to the control buttons. This will verify if the volume up button is the problem.
Feb 11, 2009 | Akai LCT3215/26 32 in. LCD Television
Picture Refresh Problem
Used Panasonic Concierge Chat and they had me do this:
press volume down on the TV (not the remote) and then press menu on the remote for 10-15 seconds to bring up a check screen. After that, unplugged TV for one minute. Plug TV back in and set up for Home. Can exit out of the rest of the set up. So far so good......this was happening only periodically for me, so we will have to see if it works. I was also having to go to TV Video and select Component 1 (cable for me) every time I turned on the TV, but the above action fixed that. Now it goes to the input that was on when the tv was last turned off. Concierge is free. Very cool.
Jun 09, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
PANASONIC 42 PLASMA WHEN YOU TURN IT ON THE TOP ONE THIRD HAS A DOUBLE PICTURE AND GOES AWAY AFTER A SHORT TIME. PANASONIC SAID TO LOWER THE VOLUME CONTROL ON THE TV AND HIT THE CENTER BUTTON ON THE REMOTE...
well did you do that and did it work ? i guess that panasonic doesn't say that for nothing so try that first , and unlike lcd tft tv's plasma need to be warm to get the best picture
Jun 01, 2008 | Computers & Internet
Need help fixing the volume on my TV?
You are probably using a cable box that has a lower audio output level. If thats the case have the cable company fix it.
Jun 06, 2007 | Samsung HP-P5091 50 in. Plasma Television
LG 60PC1D 60 in. Plasma Television Logo
270 people viewed this question
Computer Repairing
Computer Repairing
