Question about Refrigerators
Fridge stops but freezer still runs
When power resets it goes for approx 1 week then plays up again. Fridge stops but freezer continues to work
  • Refrigerators Master
  • 4,654 Answers
What is the model number and have you looked at the walls inside freezer for signs of defrost failure? Frost building on freezer walls are a sign that defrost has not been working=> HERE If this is not what is happening then we need to see if frost is blocking an auto damper between the two sides. I need that model number to see what you have. Let me know if my way of placing explanations and links are helpful. Thanks Sea Breeze
Posted on Dec 10, 2012
Noggin
  • 944 Answers
SOURCE: AEG fridge/freezer isn't working
This sounds like your fridge has a leak somewhere and it slowly discharged its refrigerant. the compressor can sustain damage when there is no refrigerant and often will hum and eventually fail. Sorry but you may need a new compressor - if you were going to replace the fridge soon anyway then i would go ahead, but a compressor and the labour to fit it etc may be cheaper than a new fridge - you need a refrigeration repair man/shop (if you can take the fridge to a repair shop it will always be cheaper than calling a guy to your house) Sorry i can't really help, but the symptoms are classic, if you are lucky then a technician may be able to fix the leak and restart the compressor, but not always if you want to try something yourself just try tapping the compressor smartly but not too hard with the end of a dry wooden or plastic stick or similar with the fridge plugged in. the compressor is the thing at the bottom in the back that looks a bit like a small fuel tank, should be right in the middle and will be the largest thing in there. Just be careful not to break any copper tubes or touch any wires. Sometimes a stuck compressor can be freed this way, but you will almost certainly still need the leak fixing and a refill of refrigerant. Sorry about the bad news :( Hope this helps :)
Posted on Mar 09, 2007
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
  • 131 Answers
SOURCE: Freezer working but fridge isn't!
You have a frost issue. You may need a defrost timer, defrost thermostat, or defrost heater.
Posted on Mar 10, 2008
SOURCE: mfd2561hes Maytag Refrigerator
My Maytag mfc2560hes starting making a noise this am. I checked the fridge and everything is hot. The freezer is still cold, and the items are frozen. What am I to do?
Posted on Mar 29, 2008
SOURCE: Freezer alarm keeps going off..
Mate prehaps the defrost element could be burntout thus no auto defrost and the big freeze and the alarm, when you switch off the defrost starts and the alarm resets?
Posted on May 03, 2008
Temperature controls seem to be playing up and then stopped completely
Try resetting system. Unplug for 10 min. Then plug back in. Set all temps. 36 ref. 0 fre.
Jun 18, 2017 | Refrigerators
GE French Door bottom freezer refrigerator not working correctly. Approx 10 years old. Both fridge and freezer stopped working. Cleaned and vacuumed the entire unit and both worked again for 1 day, then...
I have two important question for you: which model do you have and what was the value for the thermistors you tested? This information is key to understanding you current issue.
The thermistors report temp information to the board to run, so if the value is off or open, they will not allow the could system to continue.
Get back to me so I can assist you if you like.
Nov 15, 2013 | Refrigerators
Hotpoint FFB6187
sounds like 2 things either the t stat making fridge run all the time, or 2 the fan not having enough cfm to circulate the air.
Nov 06, 2013 | Freezers
Srs618dp model samsung noisy and lose temperature
I have a Samsung srs618dp side by side fridge. I have just turned it on after 5 months and it seems to be working however every 30 seconds it keeps beeping, very annoying. There is no ice build up.
Apr 06, 2013 | Samsung RS2630SH Side by Side Refrigerator
Hi, was wondering if you could help. I have an Electrolux fridge Model ER6632I that has suddenly stopped cooling. This fridge is approx 8 yrs old. I opened up to the rear of fridge and found that...
Seems that the compressor has some fault within the unit as it takes in more current under pressure. Sometimes it can be due to fault within the compressor, failure of the valve , O-rings. Now shut down the fridge for about 6 hours and then plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. , if RPM of motor is low check capacitor.
Please check this link for tips :
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 25, 2011 | Refrigerators
Bosch fridge freezer stops working after approx 8 hours. Starts OK and freezes OK but next day it's warming up. Turn it off and back on again and it starts all over again and the problem reoccurs..
Found a solution at
www.reviewcentre.com/vt100228_start50_orderasc.html
Short out the dark blue and the dark brown wires that lead into the temp control dial. Everything now works. This bipasses a dodgy thermister or something. Of course this might not solve all similar problems but it does seem a common fault.
Dec 10, 2009 | Bosch Freezers
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
