Question about Music
Where in the mixer 2222fx does the power cable being connected?
I un screwed it because someone poured fanta on the mixer but due to the similarity of cables i did not mark them so i dont know exact where the power cable should be connected so help me pliz
    New Friend:
  • 7 Answers
Hmmm, the back of this mixer is pretty straight forward, you can only plug it in one place!
did you disassemble the mixer and are working with the internal components? those details would be helpful.
if you can post a picture of what exactly your looking at I can probably label it for you so you know where everything goes.
Posted on Dec 10, 2012
4 Suggested Answers
  • 5603 Answers
SOURCE: I lost the power cable for my mackie 32X4 mixer
This likely uses the standard power cords found on tower computer. You can ALSO often find these cords at Thrift shops.
Posted on Feb 21, 2011
  • 5603 Answers
SOURCE: i need to know what
The 1/4 inch should be a TRS (balanced connector) You should find pin 1 of the XLR to the sleeve of the TRS. Pin 2 of the XLR can connect to either the tip or the ring of the TRS and pin 3 of the XLR to the other TRS tip or ring. The line should be an audio interconnect line, balanced. If that doesn't work get back to me as there may be another problem. Make sure all interconnected equipment is powered from the same receptacle or power conditioner !!! Remember these subwoofers are WAY down in frequency so unless you have stuff down in the 50Hz or less range it won't do much. That is LOW...
Posted on May 03, 2011
  • 140 Answers
SOURCE: I'm looking for a solution how can i connect my
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
Posted on Jun 10, 2011
Inserts how to use properly
Not sure what lead you are using, from the mixer end T R S are send return and screen respectively. You need a splitter cable or proper insert lead. Where are you trying the bypass, if it is on the unit being inserted you may just have the wires the wrong way round. You have remembered to set the send and return levels haven't you?
Jan 15, 2014 | Behringer XENYX 2222FX MIXER
Good Morning All. I am a mobile DJ currently
Just a guess - You may have an active component in the amplifier which is going bad ( i.e. transistor, chip ). Best to take it to a service depot to be checked. It is also possible since it is often transported that an internal cable assembly is loose.
Oct 24, 2013 | Music
Behringer xenyx 2222fx turns off and on continuously after 15min of operation
More than likely, something has happened to the internal pathways to make it become unstable.
Have you tried unplugging EVERYTHING from the board? If not, try that, and just watch what it does with nothing but the power cord connected to it.
If unit still click off/on, then it probably needs service. I'm not so sure this is worth tackling yourself, unless you're willing to risk losing it altogether. Might be fun just to see what happens though. Good luck.
Jan 06, 2013 | Behringer XENYX 2222FX MIXER
BEHRINGER XENYX 2222FX POWER SUPPLY REPAIRED BUT NO AUDIO AND MAIN AUDIO OUTPUT LEVEL LED NOT RESPONDING
I suspect that there is a problem on the effects board. Most of the signals go through this board. I would check the seating of connectors associated with the board.
Aug 22, 2011 | Behringer XENYX 2222FX MIXER
NO POWER. CORD TESTED OK AND IVE ALREADY CHANGED THE FUSE BUT STILL NO POWER...
Why did you change the fuse? If it was blown, then power supply has failed. Here is your schematic. The power supply is on page 14.
http://elektrotanya.com/behringer_ub-2222fx-pro.pdf/download.html
Scroll down the page at the site to the "Get Manual" Click on that to download the schematic. When working on line operated supplies use an isolation transformer for personal safety. The regulator chip IC2 has probably failed but test before changing. HINT: When restoring the supply, put a 60 watt light bulb in series with the hot power lead to act as a resetable fuse... saves fuses and also other components if all the bad parts haven't been weeded out.
May 11, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
Behringer Xenyx 2222fx doesn't power up. I've replaced the fuse and power cord, still nothing. When you flip the phantom power switch, the red +48V indicator light comes on on the front. Other than that,...
The Phantom power comes from a seperate winding on the switching power supply.Likely one or more of the other voltages are not present due to a failure of one or more components. The supplies are current limited so a short anyplace on the board may cause the problem. I had one of these short betwen the +/- 15 volt busses because somebody spilled liquid into it.
Here is a close schematic... a slightly different model with less channels, but circuoitry is the same, just more copies of it in yours: I believe it is zipped with four files... the last is the power supply.
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Feb 19, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
It doesnt power up all of a sudden, for no apparent reason.
This is likely a pwer supply problem... BUT do check that the power cord is properly seated... pretty common that these work loose.
Jan 15, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
How do i connect 2 monitors to the one monitor output jack on the peavey xr 600c mixer..cheers My product not quite the one as listed from your product database but may be similar
The monitors will have to be POWERED monitors with built in amps.
You can simply use a wye splitter cable to drive the two monitors. Run the cable from the mixer to one monitor and put a wye cable and an extention to the second powered monitor speaker.
Jul 25, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Music Logo
22 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
