Question about Samsung M7E HM321HI 320 GB SATA Hard Drive
Boot problem with hard drive fist time cannot boot my hard drive if restart pc than its ok
  • Samsung Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
Hope this helps
Posted on Dec 11, 2012
L410
Step 1:
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. make sure there are no disks in cd floppy usb drives Test all power and data leads that attach to your hard drive IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error. also make sure you have set it boot from you hard drive in BIOS Restart your computer and enter BIOS mode. On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on. Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it. Once you've selected your desired options, continue to boot.
Feb 27, 2013 | Acer Veriton Computers & Internet
How can i change the real time clock....
a. Click Start, type services.msc and hit ENTER.
b. Locate Windows Time.
c. Right-click and select Restart.
there can be a number of things that can halt the boot process
bios settings not right
bad or faulty leads
faulty bootmanger
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter make sure your first boot device is set to your hard drive press escape then press f10 to save to cmos to restart
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope it helps
May 05, 2012 | Dell 038HRF GX150 PENTIUM-III SYSTEM BOARD
When I restart with the boot disk I made (or the intstallation disk) the computer starts up normally. I am not being prompted to scrub it. Help!
you need to change the boot order of the computer to boot from cd instead of hard drive.
When you first start up the computer you should see a message to press to enter setup the most common keys are:
  • Delete
  • F1
  • F2
  • F3
  • F5
  • F10
  • Escape
  • Insert
  • Control + Escape
  • Alt + Escape
  • Control + Alt + Escape
  • Control + Alt + Enter
Once you've entered setup you should be able to find a selection something to the effect of boot order chage the fist boot selection or primary boot device to the CD rom so that the computer will boot from the boot disk instead of the hard drive
Apr 19, 2011 | Iolo Technologies DriveScrubber
Hp pavilion a530n will not boot for cd it says not hard drive found reboot and select proper boot device or insert boot media in selected boot device
Need to set it to boot onthe CD drive.To boot on CD drive;
1-at start up press F2
2-At BIOS select BOOT option and move the CD drive to the fist option using the keyboard arrows.F10 to save and exit.
Oct 26, 2010 | HP Pavilion A530n (DW234A#ABA) PC Desktop
My western digital 1tb external hard disk freeze my pc when i conected i must restart after restart is ok
every system has a limit to the devices that can be connected to them.1tb is a very large memory and is capable of making the system or the hard disk freeze causing you to restart.it is most probably that your system cannot utilize it while it is on and so has to be re-boot so as to make the hard disk boot up with the system.one very good sign of this is if your system takes a bit of longer time to boot with the hard disk connected from the start,if so my advice is for you to upgrade your system.like the ram and processors should be increased.hope this was helpful?
Oct 21, 2010 | Western Digital Elements powered by WD 320...
I cannot boot my PC when the seagate hard drive is attached. I have to disconnect the external Seagate drive and then boot. Once booted I can physically plug in my seagate External Hard drive and it...
restart the system, while restarting , press delete/F8 to enter in BIOS menu, select boot priority and select the primary HDD as first boot device, deselct the "boot otehr device" option.
it should work fine.,
Cheers!
Sep 11, 2010 | Seagate Computers & Internet
How to format the desktop,which is affected by a virus(trojen)?
Boot from your system disc and do windows over again,and then go to format selected partition. First go to your bios and go to boot disk priority then select first boot device on boot from disk. Then exit and safe with changes. Put your system disk in and there you go
Oct 06, 2009 | HP Compaq Presario SR1830NX PC Desktop
Error 00163 and 00173 on THINKPAD 600X will not let initialize
Dear that is not bios problem but fist you are format all drive in hdd and after install the windows program and your problem is resolve .................ok
Apr 08, 2009 | IBM ThinkPad 600X Notebook
Drive has power but fails to come on
hi if try bios setting then setup it..
Open your hdd Drive change your jumper .....restart your pc put in Any OS Xp Driver...press ok enter 5 times if it boot then format & setup it....
Jun 29, 2008 | Western Digital Caviar (wd800lb) 80 GB...
Pc cant boot
Is the BIOS settings ok? Try changing the Molex power Connector or Change the power Supplies. Hope this helps
Sep 17, 2007 | Computers & Internet
Samsung M7E HM321HI 320 GB SATA Hard Drive Logo
107 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
