Question about Car Audio & Video
What cords do i need for a MB Quart DSC 280 discus amp? i just need to hook it up to my car and to my 2 kicker comp 10s (in box)
I really need help on how to hook this up, i never did it before and have no idea what anything is or even where to start.
  • 631 Answers
SOURCE: i have a Rockford Fosgate Puch 1000 watt amp "thermal" problem
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up without the thermal LED being lit, the wiring needs to be checked. If it still indicates that it's in thermal protection, it needs to be serviced. A local repair shop will be the quickest. Rockford will email you the schematics.
Posted on Apr 08, 2008
sicaudio
  • 96 Answers
SOURCE: high wattage car stereo
positive (1 guage) from main battery to second battery positive terminal. hook all amps positive to second battery and hook 2nd battery ground to frame of car (where amp is now grounded) if you have a 2nd battery a cap is a waste of money. make sure all grounds (battery and amps) are together on same ground point of car, do not ground amps to battery - ground everything to 1 spot on the frame or body of the car ! - yes you can pigtail remote leads.
Posted on Jan 10, 2009
  • 55 Answers
SOURCE: No Power light or sound from kicker amp and speakers
OPEN UP THE AMP AND CHECK THE FUSE HOLDER THAT IT IS CONNECTED TO THE BOARD
IT MAY HAVE GOT BUMPED AND THE CONNECTION MAY HAVE BROKE IT MAY BE A HAIR LINE BREAK WITH THE COVER OFF AND THE POWER ON MOVE THE HOLDER MAY NEED TO BE RESOLDER THE CONNECTON THATS ALL IT IS GOOD LUCK
Posted on Feb 20, 2009
etirbynnor
  • 655 Answers
SOURCE: i have 2 kicker l7 12s 4ohm speakers and was
Hello gonenutz14,
It depends on how you define the "best way". Driving each sub with a separate 750 watt amp will result in about 50 percent more power than having them share the output from a single 1000 watt amp. But with 2 amps, there's more wiring issues to contend with and the adjustments are more complex. The 2 750 watt amps will cost more than a single 1000. Plus if the 1000 watt amp is stable to 1 ohm, the power difference will actually be less than 50 percent because of the lower impedance. But if the 750 watt amps are also stable to 1 ohm and their outputs can be combined, we're back to 2 being better than 1.
I'd say that the simplest, most economical way is to use a single amp. If maximum power to the subs is the highest priority, and cost and wiring is not an issue, then 2 is better.
Hope this helps.
Posted on Jul 12, 2009
  • 102 Answers
SOURCE: how many watts are in the kicker comp zr600 amp? i
  • Amplifier Type: Dual Channel
  • Bridgable: Bridgable
  • RMS Power at 4 Ohms: 150 W x 2
  • RMS Power at 2 Ohms: 300 W x 2
heres a link to a stats page for the zr600>
http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
Posted on Feb 05, 2010
2 kicker cvr 12's in prewired kicker box with 1 wire terminal, kicker cx1200.1 amp. Whats the best way to wire this combo?
Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
Sep 23, 2013 | Kicker Comp CVR 12 x 12 Car Subwoofer
I have 2 10" Kicker Comp Subs
That amplifier is only rated at 150 watts at 4 ohms, or 300 watts at 2 ohms. Not a very strong amp to run 2 kicker comps. My guess is you have the subs wired wrong for your application. There are 2 types of subs, one is a dual 4 ohm, and one is a dual 2 ohm. Most people bridge these coils together and that cuts your ohms in half. For example. Lets say you have the 10cvr104 subs. Thats the dual 4 ohm sub. You wire the coils together in parallel, now its a 2 ohm sub. You have 2 of these subs running off of your amp, if they are hooked up in parallel, now you have a 1 ohm load, out of the amplifiers normal operation. Your amplifiers internals heat up really quick and there is a thermal overload, putting your amplifier into circuit protection mode. My suggestion for wiring your subs is as follows: for each speaker, wire the coils together like this- positive coil1 to negative coil 2 and negative coil 1 to positive coil 2. That is called running in series, and doubles your ohm load. Next, we need to wire the speakers together properly to hook up to your amplifier. For this, since the coils are hooked together, you only need to use one set of terminals from each sub. And take the positive from sub 1 and hook it to positive of amp. Take negative sub 1 and hook it to positive of sub 2. Take negative of sub 2 and hook it to negative of amp.
Aug 30, 2012 | Rockford Fosgate Punch 301M Car Audio...
I have 2 12s kicker comps 2ohm. One of them are working fine, the other one, when I hook up to amp, it throws them both off and just does this repetitive bass....or when I just hook the one thats...
Measure the resistance across the voice terminal of the known good sub, and then compare that to that of the problem sub. You may see a greatly changed value, which likely means the voice coil is damaged. Don't connect the subwoofer again because you risk damaging your amp as well.
Nov 16, 2017 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
How do i hook up my kicker comp dual voice coils
If you are wanting to run them bridges, I'm going to assume each voice coil is 4 ohms, then what you want to do is as follow
+1 -2
+3 -4
So on the diagram here, I know its silly, but you'll hook a wire from lead 3 to 1, that will bridge the positive side dow. Then you will hook a wire from lead 4 to lead 2. From lead 1 and 2, run your speaker wire to the terminals on the box. Now if you have a mono block amp, its not going to affect. If you have a 2 channel amp that is bridgeable, be careful. Some amps are not 1 ohm stable. Try and see. Good Luck.
May 02, 2010 | Kicker CVR15-4 Car Subwoofer
Hooking up 6x9's to a amp
yes as long as u put in on the high pass filter (HPF)
Dec 07, 2009 | Kicker ZX200.2 2-Channel Amp - 140W ZX...
What are the specs,rms ect on my older mb quart psc 216 speakers
Any type of 4 channel amp that will allow the speakers to be hooked up at 4ohm. I would check your local walmart. The brand VR3 are made by Rockford fosgate as well as lighting audio. From what I have heard they are some really good amps at affordable prices. If you are looking to spend some money I would recommend a JL Audio e2150
Oct 28, 2009 | MB Quart Car Audio & Video
I wonder if i get two kicker cvx 10 can be push by jl audio 500.1
It can but it'd be a waste for your subs. 1 of those by itself will handle that amp. it'll push them just not really hard, i'd recommend an upgrade to a 1100-1200 watt rms amp if you're gonna run 2 cvx's. if you only run one sub that amp'll work well...
Oct 08, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Car audio help please!!
buy a distributor block split it in to 2. Use the main wire from the battery and then wye it off on the distributor block using a 80 amp ATC fuses. then use the remaining wire.
Aug 11, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
