Question about NEC MultiSync MT1050 Multimedia Projector
NEC MultiSync MT1040, Color Alignment
There is a dark yellow/light green stripe on the right side of my projection, and very noticable displacement of all yellowish colors.
I understand realigning the color "guns" is tricky and complex, but
returning it to the manufacturer is not an option. I need step by step
instructions on how to either use the menu to align my colors, or
do it manually.
Thank You.
Kimi
  • 277 Answers
SOURCE: MT830 Color Convergence (Blue Left - Yellow Right)
take a look here: http://www.extremetech.com/article2/0,1697,1049289,00.asp "... The others, however, have lost portions or all of their blue channels. TI's theory is that the shorter wavelength and higher energy of the blue light apparently causes the organic polarizing material in the LCD to get lightburn much faster. TI showed us a damaged LCD panel that controlled blue light transmission, and there was a large spot in the center that was apparently burned out..."
Posted on Oct 31, 2006
dhiman
  • 115 Answers
SOURCE: How do I align the color on an MT850
Hi
pls check the board before the color wheel, as it is noticed that this problem comes with the main PCB Board.
Viren
Posted on Nov 19, 2007
HDTV GURU
  • 261 Answers
SOURCE: Alignment (convergence) of color panels MT1050
I can assist you with that if you want. It is very tedious, but can be done. You need a cross hatch pattern generator or something with vertical and horizontal lines to lineup the LCD Panels again. Tricky little procedure if your not familiar with it. Let me know if i can assist you and hopefully save you agravation at the same time. Thanks Jay
Posted on Jan 31, 2008
ve3wtj
  • 147 Answers
SOURCE: NEC DATA Projector
A trapezoid can be corrected using the "keystone" feature. This is used when your projector is located above or below some angle other than 90° to the centre of the screen.
As for the second tone, that may correct with the keystone.
Posted on Sep 17, 2008
SOURCE: NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
Posted on Feb 08, 2009
Red color seperating
If you mean the red light is displaying offset from the blue and green then the red LCD panel inside the projector needs to be physically adjusted. If you take the projector apart you'll notice that the light source is split into red, green and blue light by passing through an optical splitter. Each color then passes through it's own LCD panel. Next, each color is joined back together by another light splitter to be projected to your screen. The red LCD panel is misaligned.
Jun 03, 2012 | NEC MultiSync MT1050 Multimedia Projector
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
Need the radio wiring diagram for a 95 camaro
yellow is power . red is ignition or acc. black is ground. front speakers : left positive tan, left - grey , right - light green , right + dark green , rear speaker : left - yellow , left + brown , right - light blue , right + dark blue . this is for the fatory wire color code if u need the actual wire color code for cd player it is . white is front left , grey is front right , green is rear left , purple is rear right. solid colors are positive and wires with the colors listed with black stripes is for the negative
Mar 08, 2010 | 1995 Chevrolet Camaro
What is the color code for the wires to the factory radio for a chevy malibu 2004
1989-1990 And Newer
AS VIEWED FROM MATING END OF CONNECTOR
A B C D E F G H I J
K L M N
F Not Used
H Power Antenna Turn On Pink (if available) Blue
Smaller sized
Mar 07, 2010 | 2004 Chevrolet Malibu
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
I need a factory radio wiring diagram for a 2006 chevy 1 ton just a am/fm cd player
1989-1990 And Newer
A B C D E F G H I J
K L M N
F Not Used
Smaller sized
Feb 01, 2010 | 2004 Mazda 3
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Need a wire color code for a ford radio f58f-18c815-aa
Notice, this is from the 2005 Ford F150 Wiring Harness. Other radios should be the same or very close. From the main 24 wire connector on back of radio (C290A).
Pin 1- Light Green w/Violet stripe - Voltage always
Pin 2- Light Green w/Yellow - Accessory delay relay output
Pin 3- Light Blue w/Red - Instrument illumination
Pin 4- Black - Ground
Pins 5, 6, & 7 - Not used
Pin 8- Orange w/Light Green - Speaker, left front +
Pin 9- Grey w/Light Blue - Speaker, left rear +
Pin 10- Orange w/Red - Speaker, right rear +
Pin 11- White w/Light Green- Speaker, right front +
Pin 12- Dark Green w/Orange- Speaker, right frt -
Pin 13- Black w/Light Green- Ground
Pin 14- Grey w/Black- Vehicle Speed Signal
Pin 15- Red w/Black- Voltage supplied in Start
Pins 16 & 17- Not used
Pin 18- Light Blue w/Red- steering wheel signal
Pin 19- Dark Green w/Orange- steering wheel return
Pin 20- Dark Blue- Parking Aid mute signal
Pin 21- Light Blue w/White- Speaker, left front -
Pin 22- Tan w/Yellow- Speaker, left rear -
Pin 23- Brown w/Pink- Speaker, right rear -
Pin 24- Not used
Good Luck
Feb 09, 2008 | Car Audio & Video
Hi
Viren
Nov 19, 2007 | NEC MultiSync MT850 Multimedia Projector
NEC MultiSync MT1050 Multimedia Projector Logo
135 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
