Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
The shut off switch is stuck to the on position
I took the handl apart and the switch was stuck to the on position. i could not the switch to the off position
  • albennett Jan 15, 2009
    thank you for your help
        aubrey bennett
  • 294 Answers
This sounds like you have an internal problem with the electrical switch. I would recommend you take it to a vacuum dealer who has experience with this model. This is a relatively simple reapir for a pro shop to handle.
Posted on Jan 14, 2009
2 Suggested Answers
advacak
  • 125 Answers
SOURCE: hoover wind tunnel model no. u-6476-910
get a new switch
Posted on Jan 26, 2009
I have a new Bissell Powerglide 1305 vacuum. It is red. I took the thing apart screw by screw to clean it inside out after my son decided to vacuum out the fireplace ash. However, once I put it back...
Knowing a little of how mechanical things are designed I would guess that when you took it apart you didn't notice exactly how the mechanism was set up that triggers the reclining feature. I would take it apart again. Then canalize how the reclining mechanism should work. It's probably to pieces that are not fastened together but are only held by positioning on assembly.
Feb 10, 2015 | Bissell Vacuums
The on off switch is stuck in the on position. I can'tfigure how to take the handle apart. Where can I find an on-line manual? Hoover wind tunnel up-right.
On the windtunnel the switch is not in the handle. It is located in the top of the body housing underneath where the handle meets the body. The slide lever you are pushing on to make the machine run is just a push rod.
Dec 02, 2009 | Vacuums
I have an Easy-Flo central vac unit. The handle on the electric hose has a switch on the handle. With the switch on ''O'' in the center, it's off. On the left, is the ''I'' position. The vacuum runs but...
You can't get that apart. I repair the switches on these hoses a lot. The only way to fix it is to just get a new switch and replace it. You can get a replacement switch here:
Switch Replacement
Nov 18, 2009 | Vacuums
When I push the button to release steam on the handle it feels soft and no steam is released. It has been going out for a while now.
I didn't fix the problem but I did take the handle apart. There is a little metal piston that is pushed down by the button on the outside of the handle. It was very sticky and stuck in the off mode. I freed it when I took it apart but obviously it just stuck again. I am going to take the handle apart and see if a little WD40 will make it easier to push. Either that or glue it in the "on" position. I really love this appliance and if I can't fix it, I'll probably just buy something similar.
Jun 29, 2009 | Steam Fast SF-275 Steam Max Canister...
On-off switch is stuck on
on the back of the handle down below the grip you will see 4 screws take them out.then slide the handle out towards the back.on the sides of the handle you will see small notches those are the snaps the hold it together.the handle will come apart.feel free to call me if you need help i don't charge just like to help people save money.if there is a cord cradle there you may have to take that off also,held onby 2 screws.314-628-9153
Apr 23, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Euro-pro model EP923H Steam Valve
I suspect you have done something on this by now but . . . You need to pry out a plastic cap/insert in the top of the handle. Beneath it are 1-2 screws to remove. The halves will then come apart. I have mine broken down but have no idea what to do now. It is not making steam. Reply if you have any thoughts.
Keith
Apr 08, 2009 | Euro-Pro EP923 Canister Steam Vacuum
My dyson dc 17 does not work when in the upright position
I had this same issue today, after not being able to find a solution, I took apart the brush area by unscrewing the three simple screws... my belt had a TON of dog and cat hair built up inside it so I cleaned that out and it did the trick.
Dec 06, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kenmore canister switch issue
It most likely is the hose pcb. It has the switch on it, and part of it is either just dirty or bad.
May 17, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
126 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
