Question about SanDisk Sansa Fuze MP3 Player
How to make a playlist on a sansa: I am having trouble making a play list,please help. I use widows XP and windows media player
Once you have connected the mp3player to your computer and open windows media player open the device tab. You should see your device listed there. Or you can look in My computer from the Windows Start tab. You should get on screen directions from there.
Posted on Jan 13, 2009
I have a Sansa Clip 4GB MP3 Player and I have loaded several playlists onto it. When I try to play one of the playlists it will shift to a different playlist and start playing that. I cannot access my...
Save what you want and Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Deleteing Playlist: Open my computer double click my music Here you should find the folder my play list double click and delete file .wpl or .m3u these are the playlists....You can also go to search type .wpl enter when located delete remember where file was located...Windows Media Player will find them also and you can delete from there.. (Library)
Apr 08, 2010 | SanDisk Sansa Clip MP3 Player
Download from audible
hi,
Have you tried connecting to the net and then continue to subscribe??
Feb 09, 2008 | SanDisk Sansa Clip MP3 Player
I have a sansa view 16 gb mp3 player in the MSC mode, I can not see Play List when viewing my sansa player in windows media player. (system - XP)
play list is a file that just save the property of songs of that particular software, make sure once you save the play list it can be recognize by your mp3 player, some player generate their own playlist, and makesure that the songs that was in your playlist is also in your mp3 player.
Sep 28, 2009 | Audio Players & Recorders
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 installed with rockbox doesnt play video.
Sans e200 support:
http://www.sansa.com/support/sansa_e200/faqs
Manual for Sansa e200 series:
http://www.sansa.com/sites/default/files/downloads/e200_userguide_en.pdf
1. Using the Sansa media converter for preparing videos to make them
suited for the player as you are doing is just fine.
2. Page 22 [19 in written manual] of the pdf file shows how to make playlist(s) using Windows Media Player 11.
2.1 First create a playlist
2.2 Save the playlist
2.3 Synchronize the required playlist onto the connected player
Sep 09, 2009 | SanDisk Sansa e260 MP3 Player
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Playlist Upload...
There is a well known problem with the sansa regarding playlist..I am sure sandisk is working on a firmware right now that will fix the issue you are having..
Oct 23, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Song problem (SanDisk 4gb
This is going to take some investigation on your part. First of all, make sure that the correct song works on your PC. That is, if you launch Don't Wanna Miss A Thing on your PC and Bout It plays, then it's the media file, not the Sansa player. Make sure you launch the specific media file from Windows, NOT from your media player software. You want to check the FILE first. (Reverse the files too - launch Bout It and see what plays) If the files are right, then launch them from your media player software. If they're wrong when you play them from the media player software, check the properties of the song. If everything is okay on the PC, then check the Sansa. If you are directly launching the music file on the Sansa (that is, not from a playlist) and it's wrong, then put the Sansa in MSC mode and check the file. Drag it to your PC and launch it. If it's wrong, replace it. If your launching the file from a playlist, just redo the playlist with the correct file after you've finished your troubleshooting.
Jul 12, 2007 | SanDisk Sansa e260 MP3 Player
How do you add a playlist to the player!!!
There is another way but that is called Favorites. First go to settings on the player and enable advance then go to one of your songs and press the select button then it will give you an option that says add to favorites? choose the check mark to add that songs to your playlist. Also there is a way to add playlist using windows media player. The steps given would be for windows media player 10. First click on the Library Tab thecn click on the arrow for the Now Playing List choose New List then Playlist, now add songs to your newly created playlist by dragging them to the drag items here window after you have choosen all the songs you like click on Now Playing List and choose Save Playlist As.. After saving the playlist change the settings of the player to Autodetect and connect the player to the computer. Now wait for it to be detected by the computer and click on SYNC tab on the windows media player software. There are two windows the left is where you will choose the playlist the right your mp3 player. Choose the playlist that you have created and click on START SYNC now it will be transferring the playlist to your mp3 player just go to Music then Playlist. Hope this helps :D
Jun 30, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa Fuze MP3 Player Logo
266 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
