Question about Vizio VS42LF 42 in. LCD HDTV
My TV all of a sudden turned white and grey.
My TV all of a sudden turned white a grey. I can still see the picture but looks like all the colors are white and grey. Not sure what do I need to replace. sound works and picture is there. I probably need a new bulb or something. model number is VS42LFHDTV10A
  • 1,238 Answers
First, try to play DVD on your tv to determine if the problem is on TV itself. If the TV looks fine on DVD you have cable box connection problem if not you have faulty t-con board not bulb etc.
T-con is the responsible for colors and image graphics.
Posted on Dec 10, 2012
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Have sound but no picture.Screen is a grey or
The porblem can be the main board not feeding the signals to the T-CON board or not feeding the 12vdc to the T-CON board, or bad T-CON board due to blown fuse. Those are the two area you need to check. Please read my guide.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 12, 2010
Sebin
  • 712 Answers
SOURCE: Model VS42LFHDTV10A. The TV is
This may be the problem of relay switches. It can be replaced to eliminate such errors.
Posted on Sep 11, 2010
  • 517 Answers
SOURCE: I have a Vizio 50"
Good day!!!
That problem is usually cause of bad inverter board or T-con board also there is the possibility that you have failing capacitors....
If your TV is totally black even back-light the problem is inverter board..please try to replace it to fix your TV.
If your have back-light but no image comes out...The problem could be on the T-con board..if that so please replace it...
This is for bad capacitors...
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter..
Look at the label capacitors...That is the sample image..
I hope this solution will be helpful...Thanks for using fixya...
Posted on Aug 17, 2011
White screen
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 17, 2015 | LG Televison & Video
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
How to change resolution on a Toshiba LCD TV from 480i to better?
Can't solve this problem, because I have the same one! I can say that adjusting some of the fine picture contrrols, like brightness, contrast, color etc help a little. This TV is supposed to go 720 and as high as 1080 I thought?..........
Mar 02, 2010 | Toshiba 32HL67 32 in. LCD Television
White/Grey screen with non-HD channels
I removed the HDMI cable and connected with component video and rca audio. No more white screen.
Picture quality looks good. I don't know if it's as good as HDMI, but then I don't need to reboot the TV three times to get to teh on-demand menu... Grrrrr....
I am trying to contact Toshiba on this as well. I have seen several reports of this problem on the web.
Dec 04, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
My samsung dlp 6163 display suddenly changed to B&W
Bad Color Wheel!!!!! Call Encompass for Part 1-800-638-3328 if out of stock call Mats 1-800-628-1118 Just looked it up encompass is out of them right now part # BP96-00674A Listed for 129.69 Go to E-Bay Lots of good deals for TV parts. E-Bay has 4 prices range from 122.00- $149.00
Sep 29, 2009 | Samsung HLP6163W 61" Rear Projection...
Screen flashing ribbons of color over picture
i think its your cable box. check it carefully.
May 25, 2009 | Vizio VA26L 26 in. LCD HDTV
Sanyo Flat Screen (DS27910) "Grey" Screen
dont know for sure but i think that the tube is going bad. Have one in my shop doing almost the same thing.Taped on the tube and it does strange things. My tube tester wont test this kind of tube that is in these sets.Not much help but it is a start.
Sep 17, 2006 | Sanyo DS27910 27" TV
Pink screen
Is your grey scale or Black and white programming pink?? Thats an indication that the green and blue grids on the picture tube are week or that the red is over driving. First thing is take off the back of the set. Find the end of the picture tube and look at the printed curcuit board there. see if you can find and red drive controls there. Put on a black and white pic and ever so slowly rock that red drive control a little at a time till the picture looks almost normal.. If you get it to be a little \less pink then stop right there but if it starts to get a bit green or blue then try rocking those controls all back and forth till you get the bese B&W picture you can BUT BE VERY CAREFULL as there is alot of voltage on this picture tube and if your not carefull it will bite ya. Now dont be too critical as the tube is a bit weak so you probably wont get a perfact grey scale so if after a while live with it or get a new set. Good Luck.
May 02, 2006 | Jensen Q2749J 27" TV
Vizio VS42LF 42 in. LCD HDTV Logo
128 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
