Question about Kitchen Ranges
My the right inner element of my Frigidaire Pro Series Stove does NOT turn on.
I have inspected the element and it seems to be fine. How can I know if it is the power board or not? or the on/off switch. The outer element turns on fine.
    Scholar:
  • 78 Answers
Have you tested the element with a multi meter just looking at the wont always tell you that it's not open circuit or if there is wiring fault,if you run either elements independently on one switch then your stove may just have a burnt out wire on the selector switch hope this helps !!!
Posted on Dec 10, 2012
  • Jeff Dec 13, 2012
    Dave, I have tested the element with a multi meter and it is ok. How can I test the selector switch? If it's not that than I'm guessing it's the power board.
  • 311 Answers
SOURCE: The inner right front element
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
tony2155
  • 64 Answers
SOURCE: Front left dual element on a Frigidaire ceramic
open the door and look under the top remove the screws and the top will lift
Posted on Jun 23, 2009
SOURCE: Whirpool Imperial Series Stove turns off while I'm trying to bake
there is a control board just behind the clock. on that board is an omron g2rl-1a-e-cf, 9vdc, 16/250vac type relay. i replaced that relay with an equivalent wired in one and that fixed the problem.
Posted on Jul 14, 2009
  • 447 Answers
SOURCE: The stove top on an electric frigidaire oven works
Ok,if you knew enough to check resistance, and your meter showed an ohm reading, not "OL", then check to see if they both are getting voltage. If not, simply check to see if you are getting power TO the board, (I assume you mean the temp control board) and OUT. If power comes in, but does not come out, change the board. If you are not getting power to the board, check the high limit. (over temp safety)
Posted on Mar 31, 2010
Throws breaker when turn oven on
is it a new larger stove,then it could be a power supply deficiency,otherwise an element is bad or shorting to unit case and causing a trip
Aug 14, 2009 | Frigidaire FEF375E Electric Kitchen Range
Electric warming drawer will not heat
Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
Feb 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Element will not turn off
Sounds like the contacts inside the switch have welded themselves together. You will need to replace the switch. (the one that you mentioned "clicked" to off) If you like, post an Ask Me with your full model number and I will look up the part number for you. This is a fairly easy repair.
Dec 29, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
My right front burner will not turn off on my electric stove top?
Hello, the switch controls the element ,if the element is staying on replace the switch.Please note any electrical repairs should be performed by an authorized service technician. good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven PLEF398ACA
I have the same problem with the LR, it is on all time and do not go off. What I did was to disconnect the yellow wire from the SF5601 power board terminal P3. Now I can use the other three burner until I got a new board. I don't have the circuit schematic but my diagnostic is that the board integrated output relay contacts are welded together. That is why the burner element is on all the time and or intermittent. THE VERDICT: The solution is to replace the surface power board SF5601
Oct 14, 2008 | Frigidaire Ovens
Kenmore Elite 790 Range
I can't believe I found this today. Today, my Elite 790 inner coil also stopped working! A little too coincidental.
When I turn on the burner, I can hear like a relay click on, but it does not heat. The middle and outer burners are fine.
Dec 20, 2007 | Kitchen Ranges
Kitchen Ranges Logo
110 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
