Question about Miller Legend Traditional Series 5000 Watt Generator Welder
I have a miller legend with 18hp onan p218 and It starts fine and runs for a few mins then starts to idle up and down but when I strike an arc it will go to high idle then idle down and start going up
Idles crazy when not welding
mamicheddy
  • 79 Answers
SOURCE: miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
Posted on May 08, 2009
  • 87 Answers
SOURCE: When I strike an arc with my miller 180SD
Check your foot controls first the POT my be acting up change it out w/another if you have one,
Posted on Oct 21, 2009
co7196
  • 3433 Answers
SOURCE: Miller Syncrowave 200 wont strike arc for TIG
proper polarity?
Posted on Nov 12, 2009
SOURCE: i have a Miller Legend with an Onan 18hp P218G
  1. 106-977
Posted on Apr 27, 2011
rwooley
  • 100 Answers
SOURCE: No arc on my miller trailblazer pro350
There are two sources of power for the exciter circuit on this machine. The main one takes output power from the generator then goes through the voltage regulator back to the rotating field to continue the cycle of generating. The regulator varies the power back to the rotating field to keep the output steady and correct. The other circuit provides power to the rotating field while you are starting the engine. This starts the loop. It is similar to flashing the fiels on old cars that had generators.
It power from the starting cycle portion seems to be working. This tells me the rotating field, the brushes and the main winding is all good. The problem is most likely the voltage regulator or associated wiring. There are people who repair and return these as they seem to give quite a bit of trouble. If you google the part number of the circuit board, you will probably find a few of these folks happy to repair your board. I have repaired a few myself as it is almost always the same components that fail. Dust,dirt and moisture seem to build up and cause the fault.
I hope this helps. Robert
Posted on Jan 14, 2012
Miller Legend welder. Onan engine starts and runs a few minutes then dies. Why won't it restart for 5 minutes?
Some engines have a low oil cutoff switch. If the oil level drops to a certain point it kills the engine. Your oil level may be close enough that after starting and running for a little bit the level drops enough to kill the motor. After sitting for awhile the level rises enough to allow the engine to run again check the level and add oil if necessary.
Hope this helps.
Bob
Oct 22, 2015 | Onan Starter for twin cylinder engine...
250. What causes it to run roughly and lose RPM?
The Miller 212 has a 60% duty cycle. So for every ten minutes of welding the machine is designed to weld for 6 min and cool down for 4 min.
Sep 02, 2015 | Miller Welding Tools
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
Y is my 91 miller running but won't idle up when strikes an ark and dies?
ya get both cylinders to fire and check that your idle up chain from selonoid is working to keep idle going
Sep 18, 2014 | Cars & Trucks
Wire diagrame for onan p218 engine
Goggle wiring diagram onan p218 engine.
Jan 20, 2014 | John Deere Garden
John Deere 318 with an issue
black smoke is over fuelling and not spark related
check / clean carby especially the float, needle and seat area
Nov 23, 2017 | John Deere Garden
My bobcat 225g runs full bore all the time, I thought it would idle then when you strike an arc it would pick up speed,
A welder does not speed up when an arc is struck. It is normal for a gas welder to stay at a high rpm. If it did not, it would be very hard on the machine as a high amperage is needed to start an arc for welding, and to be consistant. Unlike a generator which will "idle down" when not in use.
Aug 21, 2010 | Garden
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
Miller bobcat 225g plus welding problem
May 06, 2009 | Miller Welding Tools
Miller Legend Traditional Series 5000 Watt Generator Welder Logo
89 people viewed this question
Top Miller Electrical Supplies Experts
Craig Butler
Craig Butler
joe_jochoa
Level 1 Expert
littlewheel
Level 1 Expert
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
