How to disabled/turn off the "push button setup" on my router?
I was try to use the "push button setup" to connect my router to my laptop. How to turn off this type of connection? I dont want to use this feature anymore and want to go back using password instead. Can you help me with this? Thanks.
  • Ari Nuraya Dec 10, 2012
    It's TL-WR841ND from TP-Link
  • 7,627 Answers
5 Suggested Answers
  • 556 Answers
SOURCE: Need help with a router
Yes I do know routers require configuration (setup) go connect to some devices to access the internet.
I am not familiar with the ISP 3web -- can you provide me the website where the support or help function is located.
I may have found the 3web help site check the following link to assure the service is right and let me know if you have a DSL or Cable connection.
help link
If you are not familiar wit configuring your wireless router --
Will you provide me with the Manufacturer and Model of the
Router? They all configure differently when it comes to
detailed instructions. (the link provides instructions for
some routers however maybe not for yours)
I may need manufacturer and model information on your modem device depending on what I find at the ISP's site. (if the link is right I probably do not need this)
The following is probably not covered in the 3web documentation.
With wireless services attached to your network you should also consider securing that wireless service so others cannot easily access your network and computers, like your neighbors or people on the street with a laptop.
If you want to consider that I can discuss several options with you. However to determine which options your equipment supports I will need to know the manufacturer and model number of your wireless adapter or the computer with a built-in wireless adapter you intend to connect to your wireless network.
Posted on Dec 14, 2007
  • 20 Answers
SOURCE: Belkin Wireless G Plus MIMO Security Problem
try www.supportspace.com
100% free, but 100% qualfied experts to help you.
Posted on Oct 31, 2007
unsivilaudio
  • 25 Answers
SOURCE: can't connect ipod to network when WPA PSK in enabled
Dont use WPA PSK, use WEP if possible.
Posted on Dec 31, 2008
  • 226 Answers
SOURCE: my wireless Dell laptop wont connect to my linksys router
plug your cable in direct to the router and go to 192.168.1.1 and change the settings in there ssid to what you want and change the security so only you can login
Posted on Jul 20, 2009
Enter client device pin
The client device PIN is a WPS method to connect to the network
I would suggest you disable the WPS feature and go with standard WPA or WEP
To get the PIN :
Turn off / Disable wifi in the laptop
  1. - Hardwire the computer and router
  1. - Open the router setup page ( http://192.168.2.1 )
  1. - Click wi fi Protected setup on the left side
  1. - Scroll down a little and you can find the router PIN
  1. - This is the number that you need to enter in the device
To Enable WPA Security in the wireless network
  1. - Leave the password blank and click submit
  1. - Disable Wi Fi Protected setup at the top and click Apply Changes
  1. - Click Security under wireless on the left side
  1. - Change the security mode to WPA
  1. - Type a password
  1. - Save the changes.
Dec 17, 2013 | Belkin F5D8631-4 Router (F5D8631au4A)
Escribe your Linksys E2000 Advanced WirelessN Broadband Router Network Routers Problem Router has been working fine since initial setup almost a year ago. Turned on computer yesterday, and it would not...
Please check whether your computer's wireless connection enabled or disabled. If you are using windows 7 this information you can find in network sharing center. By accident if WLAN is disabled it can be enabled. Also power cycling the router may do the trick.
More drastic approach is resetting the router which I recommend to reserve as last resort. With information you provided the router seems to be fine and your computer wireless need to be enabled!
good luck!
Sep 12, 2011 | Cisco Linksys E2000 Advanced WirelessN...
Trying to connect my ipad 2 to wi fi via belkin surf n 300 wireless router put password in and message camesup "unable to join the network "Belkin.361B"
Before you start :
Make Sure the Wireless Switch on your Computer is turned Off (If you are using a laptop to connect to the router )
Make sure that the Light on the Router is Solid Green
Step 1 : connect a computer to the router (Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 18, 2011 | Belkin Surf N300 Wireless N Router
Setup didn't work, "details" section on network
Win7 will connect without any problems, but win vista will not get connected to the network...
You can update the drivers for wireless adapter in vista laptop, it will get connected...
If it still not getting connected then change the security settings on your router to 64bit WEP... (Initially it will be in WPA)
disabled the WPS (wifi protected setup) in the router...
change the ssid in the router...
Now try to connect to the new wireless network...It will work perfectly....
click here to configure the wireless part of your belkin router...
Any issues call 18002235546 ( 24/7 )
Feb 06, 2011 | Belkin Play N600 Wireless Dual Band Router...
I was told by our Satellite Service to "secure"
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 21, 2010 | Belkin (F5D5231-4) Router
We have set a laptop wireless using bt but I cannot remember the security code I have tried putting in the code in the 192.168..1.1 in the address bar but not getting anywhere what am I doing wrong
Hi Friend,
Please disable the firewall of your system and then try to open 192.168.1.1. If that doesnot work, then reset the router. Push and hold the reset button for 30 seconds and turn it off. Switch on the router and ensure that the computer is connected with an ethernet cable with the router to configure it.
Type 192.168.1.1 and hit enter. Lave the Username blank and type admin in Password. In the router setup page click Wireless and Select the wirless mode as manual and enter the settings as required.
Click Wireless Security and set the Security as per you requirements
Regards
Chiranjeet
Sep 17, 2010 | Computers & Internet
Can't log on with laptop
Are you trying to login to the router from a laptop wirelessly or is the laptop directly connected to the router? If you are trying to configure the router for the first time, you need to be directly connected to it. Wireless is turned off by default and access to the router setup by wireless connection is also usually disabled by default.
Oct 12, 2009 | Cnet CWR-854 Router
Linksysfix doesnt exist how do i set up wireless
First of all you need to connect your router to your PC with a cable. This should then detect your wireless network providing that your wireless connectivity is installed and functioning. You can then configure your wireless setup by accessing your router. To do this type in 192.168.1.1 into your browser and then when prompted for Username & Password use "admin" (without the quotes) for both
The router interface gives you tab browsing, so you can go to the wireless tab and then onto wireless security. In the basic setup make sure that the Auto Detect button is disabled - it improves speed.
HINT - I have found that disabling the Windows Firewall enhances performance as the router has a built-in Firewall.
Hope this helps
Feb 27, 2009 | Linksys Wireless-N WRT150N Router
Computers & Internet Logo
David Payne
David Payne
