SOURCE: how to register a garmin nuvi 205w
go to: https://my.garmin.com/mygarmin/marketing/register.htm
SOURCE: garmin nuvi 205 can't find satellites
you can get the manual at www.garmin.com
you'll also need to get yourself a usb cable... the normal end for the computer and i believe the other end is called a mini b connector.
Robert
please take a moment to rate this solution.. thanks
SOURCE: Nuvi 205W keeps rebooting.
Here is the solution
touch the screen in the right bottom and turn the device on keep the screen pressed. when it asks to reset data select yes
Your unit most likely has a firmware error, which could be due to a corrupt file. To solve it you yourself can try to update the firmware when connecting to the pc, if the unit cannot stay on enough for this to be performed, your unit will have to be sent in to service.
SOURCE: where i find the serial number of garmin nuvi 205w
it was on the box and on the bottom of the GPS
The Garmin was worming GREAT then all of a sudden it says no date available if you try to type in an address the grey box keeps popping up. Can anyone help?
