Question about Car Audio & Video
I put a xhdr6435 in my z71 and every couple of weeks it would go into a spell where it wouldn't turn on so I'd have to unplug the wire harness and plug it back in then it would work and it got annoying so I bought a pioneer and it works fine but I like the dual better so I tryed putting it back in and it will come on but no sound. The harness is completely connected and wires are where they belong. My questions are why did it keep going into that shut off spell before and why don't I have sound?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
My best guess would be that the internal output ic is bad and needs to be replaced.
Posted on Dec 11, 2012
  • 132 Answers
SOURCE: wire harness diagram
www.scosche.com will give you the cars wires, u may want to just by a harness adapter, cutting wires=bad
Don
Posted on Jan 02, 2008
jackiaria
  • 350 Answers
SOURCE: Need a new wiring harness for my Dual XDMR7710
Look in your local phone book yellow pages under stereos for a local (not big name) stereo installation store (there will be one) and go there.....you will thank me!
jack
Posted on Feb 22, 2009
mikehitchner
  • 28 Answers
SOURCE: Dual XDV8125 car stereo wiring
The best way to be sure is to get the car stereo installation plug for your year make and model car and wire that to plug for the back of the stereo then plug the installtion plug directly into the factory plug of the vehicle.If this is not an option then try to locate the dimmer wire (usually orange but this differs depending on vehicles so be careful).Also usually the wiring codes are printed on the radios top or bottom.Usually the dimmer wire controls the LCD power.
Posted on Apr 12, 2009
  • 68 Answers
SOURCE: wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Posted on Nov 17, 2009
SOURCE: Dual XHDR6435 CD Receiver was working fine for a
just simply take out the reciever and disconnect the power cord and plug it back in and there you go.
Posted on Oct 04, 2010
I have a 95 toyota celica with an electrical problem. When I purchased the car the wipers would not turn on. The solution was they needed plugged in. When I plugged them in they wouldn't shut off...
Do you know how to do automotive electrical systems testing ? How to use a voltmeter or a test light ? How to use an read a wiring diagram ?
Windshield Wiper Motor Wiring Tutorial
Electric Testing Techniques You Need to Know
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Testing the electrical circuits an eliminating what's good is the way to a fix or solution !
http://www.bbbind.com/free_tsb.html you can find wiring diagrams here . Someone eles on here may tell you to replace the wiper motor ,an that may fix it , but suppose you do an it doesn't fix the problem ? Testing an not guessing > there are no magical fix's for automotive electrical problems .
Apr 03, 2017 | Cars & Trucks
After you push the power button you hear a POP sound and it dies. It previously wouldn't release the door lock.
Most deadbolts use a cylinder lock. In the cylinder lock, the key turns a cylinder, or plug, which turns an attached cam. When the plug is turned one way, the cam pulls in on the bolt and the door can open.-----------------------------------------------------------------------------------
Launch Creader CR-HD
Mar 11, 2013 | Cars & Trucks
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
Dryer not turning on.........before I would change the timer setting and it would would work.......after a couple of weeks, when i change the timer setting it wouldn't turn on at all. Question is
Definitely sounds like a timer problem. Sears Parts Direct should have your part. The model # you supplied is incomplete to determine if you have a gas or electric dryer. Check the model # again and go to Sears page to find the correct part.
May 08, 2012 | General Electric DBXR463EG Dryer
The fuel pump was changed on my 87 toyota camry the car ran good for a couple days and than it just turned off it turned over but wouldn't start than after a couple hours it started. than a couple
Sounds as if you may have a relay getting to hot and not woriking until it cools down. Below is a diagram of the relay box under the hood of the vehicle. The relay marked "EFI MAIN RELAY" could be the problem. When the vehicle is NOT starting, have someone try and start the vehicle. As they are turning the key put your finger on that relay. You should feel it "click" as it is engaging (can't spell). If you don't feel anything like a "click" going on, then that means the relay is not working. This is saying that the problem is fuel related. It could be many other things but since you said you were having fuel problems then I would starthere. You may even want to gently tap on that relay as well to see if that kind of loosens it to begin woroking again. Below is a diagram of that box for you.
Feb 03, 2012 | Cars & Trucks
Last year my 2003 neon stopped running and we had the timing chain replaced WE got 40 miles and the car stopped then wouldn't even turn over we changed a fuse and got it to run another 70 miles to limp...
I would say yes, if it wouldn't let the car run, then yes the wire may be frayed now, repair the wires first and eliminate that problem . then have the codes read,
Jul 06, 2011 | 2003 Dodge Neon
Where do i hook the blue wire up to on a dual xhdr6435 into the dash
Hi, the blue wire is used to turn on a separate amplifier or to raise the antenna. If you don't have a telescoping antenna or amplifier, just tape off the blue wire and leave it hanging behind the head unit. Please let me know if you have more questions, and thanks for using FixYa.
May 06, 2011 | Dual XDM6825 CD/MP3/WMA Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
