Question about kawasaki PVS1965 Portable DVD Player
I need the cables for monitor to the dvd - kawasaki PVS1965 Portable DVD Player
Can i connect my monitor cable to a DVD player?
depends on the dvd player.some come with the monitor view option.If not u can use a tv card on your computer and connect the dvd through it.hope i've been o help.cheers
Mar 18, 2012 | Dell Computers & Internet
I want to watch a dvd on the monitor but i dont have a computor to plug it into,i have a portable dvd player
if your portable dvd support vga cable just connect it to your monitor using that cable but you can do that only if your portable DVD has a VGA slot and you have a VGA cable.
Jul 06, 2011 | Computers & Internet
Audiovox PVS69701 Dual Screen DVD player monitor has blue screen
I had the same problem, and it seems to be a short in the video cable between the two monitors. I can bend my cable until i see the second screen and then tuck it under the headrest. I am currently looking for a replacement cable. I see it at 1800customersupport.com, but will also check the local radioshack since I need it quickly.
Jul 30, 2010 | Audiovox PVS72901 Portable DVD Player
Can i connect a dvd player to a dell e173fpf monitor with a scart to vga adaptor/cable?
You can with an RCA to VGA converter device (Amazon has it for $45 S&H), the AV cables of your DVD player and a pair of amplified speakers. Connect the yellow RCA video cable to this device then your monitor's VGA cable to the device. Also plug in the red & white RCA audio cable to both the device and to your DVD player. Finally connect your speakers to the DVD player ad your'e all set!
Jul 04, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Electronic ILLITERATE!!! - nothing recorded from cable tv channel
okay, if you have a cable box (cable out plug to dvd/vcr in), then from the dvd/vcr (cable out plug to tv/monitor). make sure tv/monitor and dvd/vcr are set to ch #3. you swith channels with the cable box ,you are not going to be able to record HBO on dvd (but you can with the vcr), any other cable ch(tnt, history, tbs,we, oxygen and more) is recordable w/ both dvd/vcr
no cable box. take cable wire plug to dvd/vcr in, than other wire is connected to tv/monitor
now go to dvd/vcr with remote, menu, set to catv, scan channels. now when you wish to look at tv the dvd/vcr must be on at all times. again you will not be able to record Premium ch like HBO
hope this help............pls feel free to rate
May 14, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Monitor to monitor 9 pin. rounded ends cable.
www.18002526123.com or call the number. I found this in the manual. The cables are called EZ View cable (122-004020-208)
Dec 21, 2007 | Durabrand PVS1966 Portable DVD Player
How to connect using a LCD monitor, cable box, DVD player
You won't need the VCR, that's only used for a cable box, and since you have one now there is no need. You'll want to connect everything with the better video plugin possible. Composite (red, white, yellow) is the worst, then s-video, then component (red, blue, green), then DVI, then HDMI. That will square your video. Then send all audio signals to the Denon. These cables are usually the red and white cables. OR Plug everything into the Denon to the appropriate input. Then connect the monitor to the video out of the Denon.
Jun 21, 2007 | Denon AVR-886 Receiver
kawasaki PVS1965 Portable DVD Player Logo
27 people viewed this question
Top kawasaki Televison & Video Experts
Robert Roath
Robert Roath
Level 1 Expert
Henry  Thomas
Henry Thomas
Jaime Hernandez
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
