Question about Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades
I bent the depth of cut scale on a Craftsman 7-1/4 in. Circular Saw. How to true it so I can again set correct depths?
  • 843 Answers
With the saw unplugged, lay it upside down on a bench or table. Put a small scrap of 2x4 against the blade and adjust until the depth of the blade matches the thickness of the 2x4. Lock it in place, Then bend or adjust the depth scale so that it reads 1-1/2 inches. Good luck.
Posted on Dec 10, 2012
Testimonial: "Thank you Al. Your solution worked very well. It's great to know that there are helpful people like you still around. "
4 Suggested Answers
  • 497 Answers
SOURCE: craftsman 7.5in. circular saw model #31511880.
Is this a brushless motor?
Posted on Nov 06, 2009
  • 11 Answers
SOURCE: My 7 1/4 in Craftsman circular saw stops running.
Is there anything jammed between the blade and the body/guard of the saw?
Posted on Jun 26, 2009
odiebugs
  • 949 Answers
SOURCE: need substitute switch part for sears saw
Sorry , but go buy a new saw. Your not going to find an aftermarket
dealer that carries this switch.
Trying to rig some other switch is not worth the trouble over buying a new one. If the switch is not available, then the saw is old.
New
Craftsman Evolv 12 Amp 7-in Circular Saw 35.00 dollars.
Posted on Feb 15, 2010
Blade wont cut all the way down when cutting baseboard
the maximum cutting depth of a circular saw is the distance from the teeth to the drive washer hub of the saw blade
so on a 7 1/2 saw the effective cut would be less than 3"
if your base board is thicker than that get a bigger saw
it the board is a lot less adjust the cut depth adjustment for the saw base
Nov 19, 2016 | Saws
GUIDE DOES NOT LINE UP WITH BLADE EVER AFTER ADJUSTMENT NOTHING SEEMS BENT OR BROKE.
If you have removed the blade, check to make sure that you have assembled it correctly. All the spacers in the right place.
Feb 04, 2012 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
I cant get the blade to lower. Where is the release?
without a model number I am going to guess. Most circular saws have the blade depth adjustment towards the back of the handle and usually on the left side. If you need an owners manual you would need the correct model number and then go to managemyhome.com and you can probably find it there. If you want to reply to me with the model number I will find exactly where the release is for you.
May 26, 2011 | Sears Craftsman 7-1/4 in. Circular Saw...
We have Skil 7 1/4 circ saw model 5400-01 how do you adjust blade depth?
There is a lever on the back of the top blade guard, if you pull up on it you can adjust the foot up or down to control how deep the blade will cut.
Oct 16, 2010 | Skil Xdrive 7 14" Circular Saw Ships Fast
Blade Depth
Aren't there two handcrank wheels on the sides of the saw? One is for blade angle of cut, the other is for depth of cut.
Jun 07, 2010 | Craftsman 10" Table Saw
I have a Makita sr 1800 circular saw. How do you
that is the standard circular saw with stationary shoe you cannot really set a depth in that model.l
Nov 29, 2009 | Electrical Supplies
Makita Circular saw 5007NB, the cutting depth guide is jammed. What can I do?
you can try spraying some lubricant on the bolt/roll pin and see if that frees it up that is about all i used to do to them
Jul 01, 2009 | Makita 7 1/4" Circular Saw 5007NB
Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Logo
119 people viewed this question
Top Sears Saws Experts
Mike Squire
john h
Mike
Are you a Sears Saw Expert? Answer questions, earn points and help others
