Question about Keurig Ultra In Home Single Cup Brewer with 54 KCups
Came on by itself and all lites are flashing
Unplugged unit. plugged in 2 hours later. all lites are flashing and wont do anything
  • 1,511 Answers
Needs rest to factory setup. Start again. See manual.
Posted on Jan 31, 2014
Power button flashs on then off wont turn on
Tries tv unplug,replug the tv back like about an hour later for the tv to do a resetting itself back to the factory setting.The tv now should be working again.If not tv still have the same problems,mean ur tv have a power supply board is the causes and the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for a replacement.
Sep 14, 2011 | LG 50PG20 50 in. Plasma HDTV
When I switch on the Unit the Power Light/Indicator keeps on flashing and nothing happens on the tv. The unit was working perfectly for the first 2 days. What could the problem be?
Tries the unit unplug,replug it back like an hour later for the unit to reboot and restart itself back to the factory setting.The unit should be working now.If the unit still have the same problems,the unit must have to be taken aparts and troubleshoot and fixed it power supply circuitry side of it PCB board.
Sep 01, 2011 | Iomega ScreenPlay
Ps3 freezes after playing for an hour wont let me do anything with it until about 2 hours later
unit sounds like it is over heating. try cleaning the unit and make sure its in a well ventelated area.
Mar 07, 2011 | Sony Video Game Consoles & Games
My daughter turned it off and now it wont turn back on
Now the tv LED power light indication is flashing?Yes.Tries tv unplug,replug back like about an hour later.By letting the tv restting itself back to the factory setting.Now tv should be working again.If tv have same result problems or again later on.The tv power supply board is the causes and the problems,that the board where the power a/c cord plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 21, 2011 | Insignia 42" LCD Flat-Panel HDTV
When I turn the set on a picture only lasts a moment then the power lite and theOPC lite flash, both together then the OPC then both... what should I do?
Unplug,replug tv back hour later.To let the tv to reset it self back to factory.The tv should work now.Not than the Tuner board is dead,that the board that,where the incomming broscasting signal cable plug into it.Tries websites like a Shopjimmy.com,Ebay.com to buy a Tuner board for the replacement.
Sep 13, 2010 | Sharp LC-42D43U 42 in. LCD HDTV
My Haire HL37E is stuck in the multimedia mode and wont respond to anything, what is my solution
get a niversal remote and use the codes for lg not for haier,,, once its programed (turns off/on) press last/channel button that`s it
Sep 08, 2010 | Haier HL37E 37 in. LCD TV
No Power to outlets, Power light flashes green
Let it charge without anything plugged in to the outlets for at least 8 hours. Then, test the battery voltage again. If you still get less than 11.5 volts on either of the batteries, it's time for a new set. It's recommended that you replace both as the other one, even with a reading of 12 volts, is going to fail very soon. The UPS is trying to charge the batteries to get both batteries, as a pair, to 24 volts. It will continously charge them until it gets there (which won't happen if it's a bad battery) and you'll burn out the new one you just replaced. You can new batteries at www.batteryinternational.com for a fraction of the cost of a new UPS. Hope this helps.
Jun 10, 2009 | Tripp Lite Lite OmniSmart 725...
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Acer aspire computer with liteon power supply PY300B00153201AA6E
power supplies are easy to replace. usually 4 screws. open the pc. remove the screws and unplug it from the motherboard. a replacement costs 40-60 dollars. plug it into the same place(s) you unplugged the original pwr supply. replace the screws. replace the cover and thats it.
Jan 08, 2009 | Lite On LiteOn 204Watt PA-4022-6B Power...
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
Keurig Ultra In Home Single Cup Brewer with 54 KCups Logo
23 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
