Question about Microwave Ovens
F9 code cannot exit from the f9 code and oven keeps beeping. How do I cancel the clean cycle.
  • Microwave Ovens Master
  • 9,047 Answers
As always, we would really need the full model number from the tag on the unit to be able to give you detailed help.
Otherwise we can only help in a general sense.
Please post a new help request with your full model number and very detailed symptoms, namely what it's doing or not doing, and when.
But F9 generally indicates a problem with the door latches or switches, except on microwaves, for which F9 is usually a problem with the inverter or related circutiry.
Posted on Dec 12, 2012
2 Suggested Answers
allbrands
  • 600 Answers
SOURCE: I have an Amana convection
Hello, Thank You for using FixYa. I will be helping you today. Without the model number to be exact the F9 is a door latch failure it may have gotten wet while cleaning. Try to unplug the unit for about ten minutes and turn it back on the lock might advance and clear the F9 code from your display. If not you may have to replace the door lock.
Thank You and please rate my answer if it was helpful..
Posted on Jun 21, 2011
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Jul 27, 2015 | KitchenAid KHMS2050SSS Microwave Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
F5 keeps blinking and stove is beeping
hello,
This f 5 code indicate or means that the oven has detected a condition it needsto check.what u need to do to solve this problem is to apply the below step as a guild.
Press "Cancel" to clear the display and to stop the beeping sound,then try turning the oven off and on again. If you still see the "F," turn offthe power to your oven and wait five minutes before turning it on again. If youhear the beep or see the "F" when you try to bake or broil again,
If your oven still has the warranty this will be covered under this ok
Hope this is very helpful for .
Thanks for using fixya.
Jul 27, 2011 | Microwave Ovens
Error code F9 and lock on computer On Maytag gas range.model mgr587bdb.
The F9 error code refers to the door latch. The problem seems to be with the latch motor or a switch associated with the motor. If I am reading your question correctly you say that it would not unlatch and then upon resetting it unlatched but the oven won't work and you still get the error code. If so try resetting again but have someone come out to check it out or you will continue to have this problem.
The F9 indicates one of two possible problems. One you have already done and the other is the door lock mechanism. If the lock mechanism got stuck in between the lock and unlock neither switches on the lock mechanism are closed. This could be caused by a post on the lock mechanism that has failed.
I just looked up the part for the door lock and it is no longer available, with no other source for the part.
So I guess I would suggest having a technician come out and see if he can see if the lock mechanism can be fixed so the oven will work but you will no longer have the clean cycle working.
They may or may not want to do this for you, but you could use a local service company and they may be able to make it so you can use your oven.
I hope this helps (remember to rate and comment this answer).
May 12, 2011 | Microwave Ovens
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
May 11, 2010 | Microwave Ovens
KitchenAid kemc308kss0 Micro/Oven Combo Microwave: At the end of any cycle there is a four-tone beep that will continue to beep until KINGDOM COME until you either a. open the door b. press cancel. That is...
From page 7 of your owner's manual:
All Tones (combination oven models only)
All of the above tones are preset on, but can be turned off.
To Turn Off/On: Touch and hold STOP TIME for 5 seconds. A
tone will sound and “Snd oFF” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd on.”
Tone Volume
The volume is preset at high, but can be changed to low.
To Change: Touch and hold the number pad “7” for 5 seconds. A
tone will sound and “Snd Lo” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd HI.”
REMINDER TONES
The Timer and Timed Cooking reminder tones are preset on, but
can be turned off. Reminder tones do not include end-of-cycle
tones. On combination oven models, if “All Tones” have been
turned off, the reminder tones cannot be independently turned
on.
Timer
To Turn Tones Off/On: Touch and hold TIMER SET • START until
a tone sounds. Repeat to turn back on.
Timed Cooking (combination oven models only)
To Turn Tones Off/On: Touch and hold COOK TIME until a tone
sounds and the lower oven display returns to inactive mode
(blank). Repeat to turn back on.
Apr 26, 2010 | KitchenAid Microwave Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Crisp display
yes, it does indicates there is a bigger problem It has run a self- checking program and displayed the error before calling help see in this model page there is a manual of the oven, check last pages if they help u if no still there are instructions what to do and who to connect read it well before calling it will save u more then a couple of $$$ good luck windman
Jan 17, 2006 | KitchenAid KBMC140H Convection Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
