Question about Whirlpool GR399LXHS Electric Kitchen Range
When self cleaning 30 min in get a e0 f5 reading and cleaning stops
My stove is a kitchen aid mod# ykerc506hw4 I had the locking mech bracket and solenoid replaced and checked.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
E0 F5 = door latch failure
Here is the part to order.
Posted on Dec 10, 2012
  • 8 Answers
SOURCE: Door will not unlock after self clean.
It's probably the timer motor which is stuck. unplug the range!! I recently had the same problem with my whirlpool (hereinafter known as **** inc.) range. Self cleaned the oven and then the door wouldn't open. Googled up similar problems and generally found out that ****inc. had this problem on both gas and electric ranges and it costs an arm and a leg for a new board plus labor. Found out how to manually open door with coat hanger but of course still had problem with same error messages; also the oven, clock, etc wouldn't function. Took the cover off the back of the stove. UNPLUG THE STOVE On the left rear facing the back of the range he found the timer motor had stopped.He unplugged input(230 volt power) leading to the stove, then unplugged and insulated the wiring to the timer motor and the microswitch on top of it ( 4 wires). Then he took the long steel wire off of it and unlatched the oven door. Told me that this probably had something to do with the timer motor on the self cleaning cycle and that it was stuck Said this whole thing could probably be fixed with a bit of WD40. Said probably nothing wrong with board but it sure must be a moneymaker for **** inc. The service techs probably clean the timer motor, say they changed the $300 board, and go on their way. Plugged stove back up and voila! Everything worked except self cleaning function. Hope this helps someone. caution!!!! Do NOT use the self cleaning function unless you fix the timer motor. Replace it or clean it.
Posted on Nov 28, 2008
  • 333 Answers
SOURCE: I am trying to self clean my Whirlpool stove/oven.
use easy offoven cleaner. when using the self clean feature the oven gets so hot that it's likely to burn out some of the electrical components
Posted on May 20, 2010
Testimonial: "Thanks I had the same thought. Hubby tried unplugging and nothing changed. Oh well, Easy Off..is for me. =) "
blueextc3221
  • 15935 Answers
SOURCE: self cleaning F5 error
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$TRE
Posted on Oct 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: Super capacity 465 Whirlpool range . E1 F5 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.ER%^
blueextc3221
  • 15935 Answers
SOURCE: error message for self clean feature E1 F5
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#W
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Clean cycle will not work.
F5 - E0 F5 - E1 and E2 -------- this all codes relates to ----- Check door/latch switch ------------ clean it and check if stiil the same problem ---- Replace switch if defective
Apr 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Self cleaning does not work
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$$$$
Mar 24, 2008 | KitchenAid KERC700LBS Electric Kitchen...
Whirlpool RF196LX Smooth Top Range
4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Oct 21, 2007 | Kitchen Ranges
Error code E1 -F5- Broil element comes on and wont shut off
if it is a whirlpool, kitchen aid or kenmore by whirlpool you need to check the self clean latch asembly found on the rear of the unit. check the micro switches with an ohm meter. always remember to unplug the oven before you test any thing or replace parts. not sure why the broil wouldnt shut off. but the f5 error is definatly related to the door latch.
Sep 06, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
Whirlpool GR399LXHS Electric Kitchen Range Logo
77 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
