Question about Plumbing
Faucet won't turn on
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Need more info.
Posted on Dec 21, 2012
Model19949 DST flexhose to faucet won't lock to water supply Disconnects when hot water is on. I have pushed coonection together as hard as I can but it won't lock up
examine the hose coupling, from the diagram it seems as if there are two slide clips to lock the hose to the faucet, perhaps either they are not engaged, or were already in the 'locked' position when you installed the faucet.
Sep 13, 2014 | Plumbing
GE portable dishwasher connector hose slips off faucet adapter
Google your dishwasher you will see parts on line There are loads just looked .
Apr 13, 2017 | Dishwashers
Faucet won't stop dripping. Does it need replacing?
No it doesn't need replacing gif you turn your water source off and take the faucet apart most of them have rubber O rings in them and you can go to your local hardware store and get new O rings. It is cheaper then buying a new one faucet
Feb 28, 2013 | Furniture
I replaced the plastic stem on a 8 in wide spread faucet and the hot water side starts running on its on after sitting a few hours and won't turn off
take the handle off and spin the cartridge 180 degrees there are little ears on the sleeve just pry it out and turn so the ares snap back in place but just turn it if it does not work turning it clockwise then take it out again and try it the other way its a trail and error thing you must turn the water off first or you will get awful wet
Jan 01, 2013 | Delta Victorian Widespread Bathroom Sink...
System won't switch to shower
You need a diverter in your spout. The spout will screw off and the new one will screw on. Lift the ball while the water is running and it will divert the water to the shower.
Dec 14, 2012 | American Standard One Handle Tub & Shower...
Water won't shut off
What is the model number of your unit? Does the water stop if you stop the machine or do you need to turn the faucet off?
Nov 24, 2012 | Washing Machines
CANT GET WATER OUT OF FOUNTAIN COVE FAUCET
Make sure all of your supply valves are open. Also, make sure you didn't install it backwards. If the faucet got turned to the wrong side, it will look right but it won't allow the ports to line up.
I also had an issue with a piece of pipe from a big box store. It had a piece of foam rubber in it and when I turned the water on, it plugged the faucet.
Jan 25, 2012 | Fontaine Fountain Cove Widespread Bathroom...
Turned on hot water faucet and i can't turn it off. I can rotate the faucet knob back and forth but the water won't turn off. Is the valve stuck open because of too much pressure or something...
With no model number, I will assume that you have a two handle faucett assembly, although they are both about the same. Either the knob and/or srew is stripped in thr stem of the knob. Hopefully the screw is just loose. If this is a sink faucet, you should be able to turn the water off to the faucet in your vanity under the sink. If it's a shower faucet, you will probably have to turn water off to the whole house. Any way, you may be able to get away without having to do this now but, I'd find out where the shut off is nad be ready. You should be able to remove the center part of the knob by getting under it with a small screw driver or butter knife. You should see a screw taht hold the knob on. Hopefully you can get this screw out or, by trying to grt it out, turning counter clockwise, you will turn your water off. If you can't get the screw out, you will have to drill it out, remove the handle, and turn the stem counter clockwise to turn off your water. In ant rate, you will orbably have to replace the valve, unless it was just a loose screw.
Jun 17, 2011 | Home
Plumbing Logo
104 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
