Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I want to buy a 16" 3/8 Husky bar that fits the 55 Rancher to replace my 20" bar on my Poulan Pro 5020av...where can I get it?
A good friend of mine whose a Poulan/Husky Pro said they have the same bar mount...just wondering about drive link and is there any other compatibility issue's before I spend the dough?
As long as your 5020av has a 3/8 sprocket it will work they make a professional landowner and homeowner for these saws each costing different prices tell the dearler what your doing and he can decide what you need
Posted on Dec 23, 2012
steve_lima
  • 181 Answers
SOURCE: Replace anti vibration mounts in Husq 55 Rancher chainsaw.
the mounts push in and then have a plastic plug that slides into the rubber.the best way to get the old ones out is to just break them and pull them out in pieces
Posted on Mar 02, 2009
dontbother10
  • 2220 Answers
SOURCE: How do I get the clutch drum off?
A YouTube video shows the procedure using a Husqvarna 350 here:
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. I looked at IPLs for the 55 & 455 and didn't see any special tools.
2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and be cut when the piston rises.
3. It is probably a left handed thread (tighten it to loosen it).
Let us know how it worked for you. GL
Lou
It appears the 455 must be a "spur" type chain drive sprocket. the 55 offers the option of a "rim and spline" drive sprocket. If replacing the clutch drum I recommend the "rim and spline".
Posted on Sep 10, 2009
Testimonial: "Works great , thanks so much. "
B-Roosky
  • 59 Answers
SOURCE: Oil is leaking out the bottom of the saw after
check the hose that goes to the oilway if everything checks clear you may have a crack in your oil tank due to excessive vibration and weak molding.
Posted on Jan 12, 2010
Testimonial: "Your answer seems about right. I'll look into it further and report back"
dontbother10
  • 2220 Answers
SOURCE: husqvarna rancher... chain tensioner not working
A Husqvarva IPL for a 455 Rancher 2005-01, follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2005/I05000/I0501036.pdf
See print "A" (clutch cover) pn 537 28 64-01 & pn 503 21 70-10, if missing or loose these may cause your problem. If not an inspection of the parts beneath may disclose the defect.
If the bar is what can be moved pn 537 28 65-01 or 537 28 66-01 may be stripped. After I determined what parts need replacement, I would contact a local Husky Dealer. They may have these parts on hand and if not ordering through them should save you shipping and handling fees.
If your saw was not manufactured between Jan 2005 and Mar 2005 you can find your IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 15, 2010
dontbother10
  • 2220 Answers
SOURCE: I have a Husky 55 Rancher, was sawing a tree and
Yes. this checks both. Change the plug first <$5 plug >$50 coil.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
Ignition module gap
HusqvarnaUSA.com
06 1500198
Lou
Posted on Mar 19, 2010
I need to know the size and thread for the Husky decompresion valve,so I can retrofit on my Husky Rancher 55
Well it will be metric thread. The to easiest ways will be go to a nuts and bot shop, thay will tell you and should have the tap you need to cut the thread into the housing or if you buy a thread-gage, that will tell you the thread pich
Dec 17, 2013 | Husqvarna Maintenance Kit For Model 51 And...
I can not find a bar to fit the rancher 55. This
The 50/51 and 55 always had the same bar mount, the bar was part no. 508912164 for 15" 508912172 for 18" and 508912180 for the 20", the oil is not fed through the bar adjuster hole.
Aug 18, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
I have a 455 rancher 20 inch i would like to take down to a 16
There was never a 16" bar, there is a 15" that will fit, in either 3/8 or .325 pitch, in the UK we ran .325, but in the US they may have been on 3/8, both are available, let me know if you need part no.s
May 08, 2011 | Husqvarna Chain Saw 20" Bar
What is the longest bar i can go on my 455 rancher saw ?
Available power and the amount of oil may both be a limiting factors. Your oiler has a 3 position adjustment (as do most intermediate level Huskies) with 20" being the longest recommended. My 359 is virtually the same and I run a 24" Carlton bar on mine with no problem. If you opt for a longer bar let the saw determine cutting speed. Come on over, my bar and chain will fit your saw, try it before you buy it. If you have an acquaintance with a 24" small mount Husky bar that is probably a good idea. I would likely not recommend a 24" bar if regularly cutting Oak or a hard wood, I do a lot of Fir.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 13, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqavarna rancher 55 repairs
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston.
• I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it).
• Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  1. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
Lou
May 01, 2010 | Husqvarna Chain Saw 20" Bar
Chain for 24
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Select "Husqvarna; 455; 24"; All; All; All" and make your choice. A couple of things to consider, it only returns 3/8 pitch chain, 0.325 is also available. I ordered a 24" bar for my 359, a Carlton that only takes 81 drive links (82 is normal). I saved $20 by ordering that bar, I just have to be careful when ordering chain. I prefer Stihl chain to Oregon. My Husky is maintained by Stihl mechanics and gets Stihl 2-cycle oil; please do not tell her, she may never run for me again. LOL
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 24, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna rancher... chain tensioner not working
HusqvarnaUSA.com
06 1500198
Lou
Mar 15, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Changing clutch drum on a husqvarna 455e rancher chainsaw
You have a couple of options. Oregon offers both rim and spur sprockets to fit your saw. Rim systems are initially more expensive but replacing just the rim portion is less expensive than 2 spur sprockets.
A part number for an OE spur sprocket and illustrations that may be helpful for disassembly may be found here:
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000; black numbers on silver tag 90s; silver numbers on black tag 80s)
15 = week produced - March
Your saw has an outboard clutch, this is a very guide for removal:
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
More questions or if I can be of more assistance please reply below. Good Luck. HTH
Lou
Feb 25, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I need a bow blade to fit a 455 husqvarna
I make no guarantee of the applicability of this research. I recommend you contact "CheapChainsawParts.com" (or 1 (800) 438-0668) to verify this application.
Methodology to arrive at the bow part number "HQ-100"
An Oregon bar for a Husky 455 is mount/oiler configuration "095" ( the last part of any Oregon replacement bar).
A Oregon bar for a Husky 55 is also mount/oiler configuration "095".
You can check my Oregon research here:
This bow
http://www.cheapchainsawparts.com/cmp_HQ-100_part.html
is the replacement bow for a Husky 55; it should also fit a Husky 455. I make no affirmation there are no modifications required, applicability of this application, or even that it will fit.
Please reply below with what you found . TIA
Lou
Jan 27, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
