Question about Acer Aspire X1 AX1470-UR11P Desktop PC with AMD Fusion A4-3420 Dual-
Connections to the hard drive - Acer Aspire X1 AX1470-UR11P Desktop PC with AMD Fusion A4-3420 Dual-
  • Acer Master
  • 5,660 Answers
The Harddrive is a SATA unit.
Uses a SATA data cable, and a SATA power cable.
SATA data cable, and connector on motherboard, example;
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Between the SATA data cable connector, and the SATA power cable connector; the SATA data cable connector is the shorter of the two in width.
SATA data cable connector has 7-pins.
SATA power cable connector has 15-pins.
The connector end used on the harddrive side, and optical drive side, (CD/DVD drive), is usually a 90 degree Bent Elbow.
The connector end that plugs into the motherboard, is a Straight connector.
NOTE* Color of connectors does NOT matter.
Most of the time the SATA data connectors on the motherboard, are different colors.
This is to help discern what number of SATA data connector it is.
Four SATA data connectors on the motherboard?
SATA 1, SATA 2, SATA 3, and SATA 4;
Or:
SATA 0, SATA 1, SATA 2, and SATA 3?
SATA 0, or SATA 1, is usually reserved for the Harddrive.
The Primary harddrive with the Operating System on it.
(Unless you have harddrives set in a RAID configuration)
DOES NOT MATTER WHAT SATA DATA CONNECTOR, you plug into, on the motherboard.
Want to plug the harddrive into SATA 3, or SATA 4?
Go ahead.
NO matter what SATA connector on the motherboard that you plug into, BIOS will find the harddrive.
Note the L-shape in the connector.
Has to line up on the L-shape on the harddrive, optical drive, or motherboard, SATA data connector.
There is usually a lock on the connector. This you may not see.
Sometimes there is a little 'bump' on the connector. Depress with the thumbnail to install the cable, or remove.
This is an example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
NOTE*
IF, your SATA harddrive has a provision for plugging in a SATA power cable, AND a 4-pin Peripheral power cable; ONLY plug the SATA power cable in.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Using BOTH types of power cables will BURN the harddrive up.
May not happen right away, but I assure you it will happen.
For additional questions please post in a Comment.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/SATA
Posted on Dec 14, 2012
Kya hard drive ki storej disk ko kisi other hard disk me laga ke use kar saktey hai ki nhi
internal hard drives are now SATA connected ( you can get converted cables to connect older units) or external hard drives are usb connected
dless of the make you have , all hard drives will fit
Dec 30, 2016 | Hitachi Computers & Internet
I plug in my hard drive and its not reading...what does that mean?
Hi, please connect the external Hard Drive to different USB port of the Computer. If you are using the Desktop Computer then please connect the Hard Drive to back side of the USB Port. Then make sure that Hard Drive AC Adapter is connected and working. Also check if the Hard Drive is working with any other Computer.
Mar 30, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
How 2 install a triple format sata internal drive in a gateway desk top
check for a open sata port on your computer. if there is one connect the hard drive with a SATA cable to the sata port on the motherboard.
connect the sata power to the hard drive or a molex to the hard drive if you do not have one. do not connect sata and molex to the hard drive together. if you don't have a molex connect you will need a molex to sata power adapter.
after connecting the hard drive to your pc. turn it on. in windows xp it will auto detect the hard drive and may prompt you to format the hard drive.
Mar 28, 2011 | Computers & Internet
I want to retrieve data from an old 50-pin hd from my old mac. Anybody got a solution?
There are two ways of retrieving data from a SCSI hard drive.
1. Connect the SCSI hard drive to a different SCSI connector on the same data cable, make sure this hard drive has a different SCSI ID from the first hard drive or other SCSI devices in your system. When you boot up your MAC you should see the second SCSI hard drive, You can then copy off your data or remove the redundant files and keep the old hard drive in your system as a 2nd hard drive.
2. Connect the old SCSI hard drive to a SCSI USB hard drive adapter. Then connect it to the USB port on the MAC and you should see this as an external hard drive.
Jun 14, 2010 | Ricoh 2GB Printer Drive (SCSI-50PIN)...
My hard drive isn't being recognised by my laptop and is making an intermittent buzzing noise? I have tried both the power connection and the USB connection neither are loose.
did it come with a cd? if so, did you install the drivers for your Hard drive first before connecting? disconnect your drive, go the the hard drive makers website and download the latest drivers for the model of your hard drive. then re-connect your drive. hope that works =]
Mar 19, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
External hard drive wont connect
There may be a problem with the hard drive now. Please see a licensed computer technician from the company you have boughten the hard drive from.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 02, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I need to run an HDD2159 external of its computer.
You cannot just connect the hard drive using a SATA to USB cable and connect it to the computer and expect to download data from this hard drive.
You need to connect the hard drive to an USB hard drive adapter which is then connected to a computer's USB port?
Leave the hard drive set as the master drive.
Oct 02, 2009 | Toshiba MK 3017GAP (HDD2159) 30 GB Hard...
SEAGATE DRIVER ISSUE
It is a internal hard drive, which connects through IDE cable (the wide one), so you shouldn't be asked for drivers. If in any case you can't see this drive in your "My Computer" ("Computer" on Vista) it's probably because you have connected it wrong. Notice that the end of the IDE cable must be connected tou your main hard drive (where OS is instaled). If Seagate ST340015A is your main hard drive, than the end of the cable should be connected to it. If not, than on the same cable, about in the middle is another connection, you should use that one.
Mar 17, 2009 | Seagate Barracuda 40 GB Hard Drive
Hard drive replacement
SATA drives are the latest hard drives available nowadays. You could try going online and checking other sites that could still have an IDE hard available for sale.
Jan 02, 2008 | Samsung SpinPoint SP8004H 80 GB Hard Drive
Acer Aspire X1 AX1470-UR11P Desktop PC with AMD Fusion A4-3420 Dual- Logo
168 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
