Question about Dishwashers
LG LD-2120W E1 message
The diswasher runs for awhile then E1 appears on the screen
SOURCE: E1 Error Message
Yep, impeller motor problem.... mines done it twice now. Absolute piece of **** dishwasher. I HATE IT!
Posted on Dec 16, 2008
  • 423 Answers
SOURCE: I have a LG Diswasher LD 2050 with a trouble Code
The most common problem on an LG dishwasher when error code E1 is reported but there is no actual leak found is the problem of a natural syphon being created by improper installation of the dishwasher. Pretty easy to fix:  Either add an Air Gap valve (available at any hardware store for almost free) or follow the drain hose from the dishwasher to the drain. Raise the hose and attach the hose to the up onto the bottom of the countertop. Adding that "rise" eliminates the possibility for the syphon effect to drain the dishwasher before the drain cycle begins.
If the hose ever fall back down, the problem will return immediately.  Adding the Air Gap valve is harder but is far more permanent (and complies with construction codes that really should not be ignored.)
Posted on Apr 17, 2009
Krazytech
  • 725 Answers
SOURCE: I keep getting an E1 error on my LG LD-2120W model
leakage Error E1
  • The excessive RPM of Washing Motor happened during Washcycle due to water leakage.
  • Water leakage in Hose connections.
  • Water is leaked by damages.
  • The Motor Water Seal leakage of Sump assembly.
  • The height of Drain Hose connection
  • (sink-Drain Hose) is not over 20 .
  • Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
fix it to the recommended Height. Replace the Impeller of the Washing Pump.
Posted on Sep 27, 2009
  • 106 Answers
SOURCE: E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Posted on Mar 30, 2010
  • 3 Answers
SOURCE: LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
Posted on Nov 07, 2010
I have a freestanding LG dishwasher and the E1 error message has come up. How do I fix it?
The E1 ERROR mean's your main wash motor is clogged or failed & you need to pull it apart completley to test or clear the blockage.Generally its just clogged so get a lg service guy to do it cause he will know your dishwasher inside out.THANKS, ECO KIZZA
Feb 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
Have E1 problem,machine stopped running,replaced washerpump/motor,runs for a few minutes E1 comes up and machine stops,any ideas
I had the same problem, new wash pump didn't solve the e1 error. New capacitor did the trick. Hope this helps
Jan 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
I keep getting an E1 error on my LG LD-2120W model dishwasher, can you advise what this means so l can either fix it or get it fixed. Thank you
leakage Error E1
Sep 27, 2009 | LG Dishwashers
Instead of showinf a time my LG dishwasher (LD-2120w) has code: F on then during a cycle it stops and flashes 0E. I have found OE means to clean the filter which i think i have done, but the priblem is...
With an OE error, the next step is to follow the drain hose from where it connects to the dishwasher through the point where it connects to the drain.
Look for crushed hose, kinked hose. Then look for a plugged drain connection.
Please report back what you find. There are other things that ~could~ cause the problem. OK?
Aug 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
I have a LG Diswasher LD 2050 with a trouble Code E1. The manual says "Water leakage in hose connection" "water is leak by damage" Ihave check and everything is Okay. It let water in and when it start...
Apr 17, 2009 | LG 24 in. LD-12BW5 Free-standing...
Stopped Working Mid-Cycle
blockage in outlet pipe
Chris
Lg durban
031-7165444
Jan 29, 2009 | LG 24 in. LD-12BW5 Free-standing...
E1 Error on LG Dishwasher (LD-2040WH)
Maybe the blockage is somewhere else. How about removing all the trays from the dishwasher, in other words, empty it from all racks and dishes and try it again
Oct 14, 2007 | Whirlpool 24 in. DU940QWD Built-in...
E1 Error Message
agreed all LG d/w with E1 is the wash motor faulty.
take care.
Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
Owen Barnes
