Can't connect vizio smart tv with belkin n750 dual band router
I can connect my laptop but not my vizio smart tv
  • 7,627 Answers
In your TV's menu there should be a wireless setup. You didn't supply the Model of the TV. Here's a manual for a Vizio: http://store.vizio.com/documents/downloads/hdtv/M3D650SV/1185QSG_M3D650SV_B.pdf
Posted on Dec 10, 2012
  • Karen Dec 10, 2012
    I do have the wireless set up on the tv. The tv sees the connection but when i test the connection it says download not available and has a signal strength of 3 bars.
  • max carson
    max carson Dec 10, 2012
    Don't get hung up on the signal strength, that's not as improtant is staying connected, Distance, interference, number of devices, ISP, their are many things that will cause a weak signal, even the Wireless channel. I'm not clear when you say "when i test the connection it says download not available"? My TV runs at a medium signal, and it works fine. If you are not connecting try a reboot of Wireless Network, starting with the ISP Modem, remove battery, unplug, unplug your wireless, check ALL cabling, insert battery in ISP Modem, plug into AC, wait for device to selftest, plug in Wireless device, wait for self test , try to connect to TV, Or reset your wireless device by pushing and holding the reset button to default settings , reconfigure SSID and security code to wireless device.
SOURCE: wireless ready laptop not getting connected to internet through belkin router
You may want to check if the wireless switch is "ON"
on the laptop most wireless ready laptops has either a
button or toggle switch to enable the wireless radio..
if it's already enabled and you still cant connect to
the wireless network,try changing the wireless channel
from the router.
Posted on Jun 19, 2008
  • 16 Answers
SOURCE: Slow speed with my Belkin G Router!!! Help!!!
alright figured out a way to speed up the connections
under firewall - Disable it. Must be slowing down everything. Just make sure you have at least windows firewall (XP) or something else as you are directly connected to the internet now.
Let me know if this helps anyone.
Posted on Mar 04, 2009
SOURCE: Cannot connect Belkin F5D8233-4 Router to Mac Laptop
Hi, I had the same problem with my MBP and the best solution I found was:
Dissable the Wlan security and use Mac Address control only for the wireless. This will keep your network secure anyway and you can connect normally.
The only inconvenience is that when you want to connect other computers to your wireless you have to enter its MAC address on the list.
Remember to set the list as Allow.
Posted on Apr 28, 2009
Geekman
  • 32281 Answers
SOURCE: Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Posted on Sep 29, 2009
consaka
  • 661 Answers
SOURCE: reset my belkin router now i can't connect to
if you truly reset your router then you may have to reconfigure it. If your belkin router is also your dsl modem or cable modem then you will have to call your ISP provider and get your user id and password to start with.
I have a feeling this device does double as your modem since you now cannot connect. Most routers will work as a router right out of the box. However if your modem is seperate then it may expect your router to have a different subnet for its IP address then the default. Try plugging your computer directly into the modem if that is the case. If it works then just reset the routers IP address to be on the same subnet.
Posted on Mar 09, 2010
What modem are compatible for n75 db dual band N router
Any modem should work; the modem is the device that provides a signal to and from the router. I have never run into any compatibility issues for a signal TX/RX device.
May 17, 2014 | Belkin N750 DB Wireless Dual Band N Router
Usb ports do not light up
You are not the only person having problems with the Belkin N750 DB Wireless Dual Band Router. Are you using the correct cables? One more thing you can check, does it have a reset button on the bottom or the side? Try those two things.
Feb 12, 2014 | Belkin N750 DB Wireless Dual Band N Router
Cannot get belkin N750 to reset to fix the lost password
Make sure you hold the reset button on the back of the router for 10 seconds. This will do a factory reset for you, simply hitting the button will only restart your router. Once you're done resetting it, connect to your wireless network using information provided on the bottom of your router box and go to either http://192.168.2.1/ or http://router/ to configure it again.
Apr 23, 2013 | Belkin Components Belkin F9K1103 N750 DB...
Belkin n750 db wireless dual band n+ router setup disc error
You didn't supply the OS you are using, it may be a software compatibility issue. Look for download for your OS. Try Belkin Support : http://www.belkin.com/us/support-product?rnId=6054
Dec 23, 2012 | Belkin N750 DB Wireless Dual Band N Router
Belkin n750 db connects with windows 7 laptop, but will not connect with xp laptop. It will not let me enter the password.
It is possible that, if you have the router set to wireless N only, your XP machine won't interact with it. Your XP adapter probably doesn't support wireless "N"--you'll have to tell the router to use "N" or "G"
Apr 21, 2012 | Belkin N750 DB Wireless Dual Band N Router
My cd drive is jammed and wont let me download router software
Here is the link to Belkin's website to download the information on that CD so you can install the router:
http://en-us-support.belkin.com/app/answers/detail/a_id/5390
Jan 26, 2012 | Belkin N750 DB Wireless Dual Band N Router
Forgetpassword wirelessnetworkname
If you have a computer that is still able to connect to the wireless then, on that computer, download a program called "SIW", run it and look over secrets/passwords and it should reveal your wireless password. Another option is to check your router for a WPS pin you can use that to connect on a Windows 7 laptop. Otherwise your best bet is to hold the reset button on the router and reconfigure it.
Nov 14, 2011 | Belkin N750 DB Wireless Dual Band N Router
Computers & Internet Logo
1,905 people viewed this question
David Payne
David Payne
