Question about McCulloch Garden
Mowcart 66 ride on tractor keeps throwing drive belts
  • 24 Answers
SOURCE: 826LE Power Max Snowthrower_ Drive belt keeps coming off
part # 94-8812 is traction belt 106-4498 auger belt
There is a service bulltin on this I have not seen this yet, Ill paste it for you to look at .
this was issued dec 22-2003 you would think that it would have shown up as a problem by now.
UNITS AFFECTED: Model Number(s): Serial Number(s):
38620 240000001-240999999
38621 (Int'l.) 240000001-240999999
38632 240000001-240999999
38635 (Int'l.) 240000001-240999999
38642 240000001-240999999
38645 (Int'l.) 240000001-240999999
38652 240000001-240999999
SUBJECT: Traction belt jumps off the pulley.
SITUATION: Incorrect pulley alignment causes the traction belt to jump off, usually when the drive is disengaged or as a hill is crested.
CORRECTION:
1. Remove the belt cover, engine belt guide and the bolt securing the crankshaft pulley.
2. Remove the auger brake assembly.
3. Remove the crankshaft pulley and the auger belt.
4. On the left side of the machine, remove the hair pin cotter from the speed control link and slide the link out of the pulley pivot assembly. The traction belt can now be removed.
5. Shorten the pulley half nearest the engine (PN 106-7334) shown in Fig 1. Grind or machine 1/8” (.125”/3.2mm). from the hub end of the pulley. The new finished length of the pulley half should be 1.07” (2.7cm).
6. Chamfer the bore to ensure the pulley fully contacts the shoulder on the crankshaft. You can send the pulley to an outside machine shop if you do not feel that you can modify the pulley in house.
7. Reinstall the pulley with a new traction belt.
A. Chamfer edge after grinding/machining.
B. Remove 1/8”.
C. Masking tape used as a reference line.
8. With the engine off, engage both the traction and auger levers and inspect the alignment of both the auger and traction belt idler pulleys (Fig. 2). Since we have moved the crankshaft pulley it may be necessary to bend the idler arms slightly to center the belts. Adjust as needed.
9. Install the engine belt guide and test operate.
10. Install the belt covers.
PARTS: P/N 94-8812 Traction Belt
Posted on Feb 10, 2009
SOURCE: Murray Lawn Tractor won't go up hill
Your drive belt is worn/slipping
Posted on May 31, 2009
lonewolf1996
  • 142 Answers
SOURCE: How do I replace the Drive Belt on a Craftsman
You need to get underneath the mower.Look in the front on the bottom of the engine.You will see the engine pulley.On the side of the pulley you will see a bracket that keeps the belt from falling off the pulley.It is help on by two bolts.Take the bracket off.Now you will be able to take the belt off.
Reinstall the new belt and replace the bracket.
Posted on Sep 02, 2009
SOURCE: How do I adjust blade drive belt tension on
Belt was excessively worn and after replacement and adjustments made all ran well. Thnaks.
Posted on Sep 03, 2009
braintrust
  • 62 Answers
SOURCE: I am trying to replace my deck drive belt and do
you may have missed it but the diagram is on the deck , look closely you should see it, anyway it should look like an upside down t if you were siting and looking at it from the drivers position. you should have to remove only one pin to get the belt on and it would be on the right side of the deck
Posted on Oct 27, 2009
I have a Yard Works snowblower model 31AE6MKH515 that keeps throwing the auger belt off the pulley, how do I correct this?
This is caused by a fault in the belt alignment or run as we call it, find out if the Auger is loose from a bad bearing and wobbling or drive pulley is the problem, check for any serious amount of play in either end of the belt connection.
Dec 09, 2016 | Garden
Drive belt keeps twisting and coming off pulleys
Could be the pully are not inline, this would throw the belt when you engage the drive. Could be the wrong belt fitted. Could be wrong tension setting. The twisting element could be that the belt is damaged or incorrectly tensioned.
Many operators consider changing from V belts to Toothed belts because there is less squealing, better efficiency and far fewer disengaging problems
Mar 17, 2015 | Garden
M00175X477890
1/2 x 79 transmission
1/2 x 61 primary deck
1/2 x 66 seconday deck
Aug 03, 2014 | John Deere Garden
Mowcart 66 break/clutch dosnt work properly and chain keeps coming off
Loosen adjuster plates where rear axle mounts to frame,they should be elongated slots to allow chain to be adjusted and alig ned,you can also adjust belt under body for clutch/brake function..
Jul 25, 2014 | McCulloch Riding Mower Briggs 20 HP V-Twin...
Keeps throwing transmission belt
There are belt guides that keep the belts on. They are about as round as a pencil and maybe two or three inches long. They are adjustable, just loosen and move them in towards the pulley but not up against the pulley, and re-tighten.
Apr 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MTD JE145H cutting deck keeps throwing belts
Usually the reason a mower deck is throwing its belts is there is a bearing that is starting to sieze up in one of the quill assemblies, which is the assembly that the blade is attached to . Either that or one of the belt tensioner pulleys is starting to go bad, easiest way to check this is remove the drive belt, take off the cover over the tension belt and remove that belt know check all moving parts for tightness or excessive looseness. Hope This Helps You Don
Dec 02, 2009 | Garden
Bush hog zt2200 that keeps throwing belts
outdoor power equipment.com website will show you the diagram you must type in your model and brand? most of the time the pulleys get bent and out of alignment then the belt twists off once that happens it impossible to reuse old belt ? just make sure it lines up and the tensioner is working?
Aug 27, 2009 | Garden
Keeps throwing mower deck belt
Check for misalignment of pulleys. Check belt for stretching or damage.
Jul 07, 2009 | Husqvarna 19.5hp 46" Yard Tractor
Garden Logo
261 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
