Question about Dell Mobile Precision M4400 Notebook
Jumper to reset password and bios on a dell precision m4400 laptop
  • 27 Answers
Well, Windows Password Ky can help you reset all kinds of laptop password as well. Try to free download it from: http://www.lostwindowspassword.com
Posted on Dec 11, 2012
    Problem Solver:
  • 12 Answers
I know a software can reset laptop password,and I used it before,my friend recommended it to me,it is easy to use,and I do it by myself,It seems called Windows Password Recovery Tool.You can have a try
  • 43 Answers
SOURCE: how to bios reset jumper location dell c400
try to remove the cover of your laptop. Then remove the motherboard battery for about 10 min. Put it again and bios should be restarted.
Posted on Mar 20, 2009
  • 21 Answers
SOURCE: how do I reset my lost bios password for Dell
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
The location of the password jumper on a Dell Optiplex motherboard can be found by reviewing the Optiplex User Guides.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Each Dell Inspiron has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Support at (800)624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Inspiron.
Thank You,
Your Support Tech.
Manish Shirsikar,
Fixya.com
Posted on May 18, 2009
  • 523 Answers
SOURCE: How can i reset bioss password....dell precision m65
my friend the new laptop has no jumper anymore on the board, and u cannot reset the bios this easily, some laptops u still can do that by disconnecting the bios battery and connect it after some minute, but if this doesnot work donot destroy ur laptop.
Posted on Jun 14, 2009
  • 11 Answers
SOURCE: I am failing to remove the Bios password in Dell Latitude D630
This should be pretty easy to do.
1. Reboot your laptop and select F2 to go into the BIOS settings. You'll need to be quick or it will boot to Windows.
2. Use the --> arrow key to move to the Security page.
3. Arrow down to the Set HDD password and press Enter
4. Enter your current password
5. Select the Enter key twice to enter no password
6. Select the F10 key to save and exit.
Posted on Dec 17, 2009
SOURCE: Dell precision m4400 blue screening
"BSOD" also known as "Blue Screen of Death" occurs when system is not stable due to misconfiguration or driver incompatabilty or Virus or worm infection.
Method 1 :  Start your system by pressing F8 upon startup. Select "last know good configuration that works".check this one solve your  porblem.
Method  2 : Start your system by pressing F8 upon startup. Select "safe boot "and check if it work or able to log you into your Desktop.
Uninstalled any software or hardware you have recently added or installed.Click "Start", Select "Run", type "msconfig"
Again click "Startup" tab.Untick all the program thats loads during your system Boot up.
Method 3: Start your system by pressing F8 upon startup. Select "safe boot "and check if it works or able to log you into your Desktop.
Click "Start", and then select "All programs", then "Accessories".Select "system tools" and then "System Restore".Try to restore your PC to a point or date which you know it was working fine.
Method 4 : If none of the above workor you are able to boot it. Then download "Hiren's Boot CD"
Here is the link
http://hirens.longcomputerservices.com/Hirens.BootCD.10.1.zip
Download the file and burn the ISO image in a CD.Boot your system using that CD. It has lots of tools for repairing Windows, system restore, Data recovery etc.Check if it can fix your problem.
If Hiren's Boot CD can't fix it then Backup all your important datas and go for a new install.
Don't forget to create system restore point whenever you are going to make changes to your system.It will help you in recovering during the time of failure.
HAPPY NEW YEAR.
Posted on Dec 31, 2009
I have an Dell Precision M4400 with the Bio's admin pw set and we don't know it..
Remove the battery from the motherboard, wait about 60 seconds, put the battery back in, the password should be cleared.
Oct 31, 2014 | Dell Precision M4400 Notebook
I forgot my pass word for my dell precision how do i reset it
start computer computer ask password enter wrong password. and now click on reset password option. you can reset password now
Jan 21, 2011 | Dell Precision M4400 Notebook
I need to know how to do the bios password thing on a DELL PRECISION M20 laptop
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
To set up a password, go into BIOS by pressing DEL key on start up and under Security set supervisor password.
Dec 15, 2010 | Dell Precision M20 Notebook
How to reset Dell Precision M60 BIOS password
Nov 06, 2010 | Dell Precision M60 Notebook
How can you reset a Precision M70 Laptop bios password
For that you need to reset bios password.
There is 2 way (1) Reset bios password with cmos cell and jumper settings.For that you need to open back cover of laptop then find motherboard pull cmos cell from motherboard for 10 minutes then reattach it into it's position.There jumper near cmos cell named clear_cmos it has 3 pins 1-2-3 put jumper in 2-3 position then power up then again put it into it;s original position 1-2 then all password RESET.
(2) you can RESET bios password with software download it from below link.
Click here
Click on above link download software there is instruction how to reset bios password.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Dell Precision M70 Notebook
Unlock dell inspiron 1521 unknown bios pswd
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-1521-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Feb 12, 2010 | Dell Inspiron 1521-JB Notebook
Jun 14, 2009 | Dell Precision M65 Notebook
How do I reset my lost bios password for Dell Precision M70
Thank You,
Your Support Tech.
Manish Shirsikar,
Fixya.com
May 18, 2009 | Dell Precision M70 Notebook
Dell Mobile Precision M4400 Notebook Logo
1,102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
