Question about Polaroid FLM-323B Television
Cannot get digital OTA with antenna to work
We hooked up our antenna cable to the HDTV input which should be the ASTC tuner. The proper menu comes up but when you try to go into the HDTV tab to get to the channel scan mode the screen just goes to all blue and it says "no signal". We should be able to get it set up without a converter box, at least that's what we thought when we bought it.
  • hindsite97 Jan 19, 2009
    To get dtv stations I have to use the other antenna jack for the HDTV tuner menu to come up for scanning the channels. When I go to the menu for the auto scan my screen turns plain blue and it says "no signal" and then my controls get locked up. I have to shut off the tv to operate again.
  • Arlene Rickaby Feb 03, 2009
    I can
    t get the ATSC menu to even appear and have tried to attach antenna to HDTV input and only get blue screen no signal. If it states it has ATSC why can't we get it to work? I get the test message saying I need to buy a convertor box and convertor boxes state they arte not for tvs with ATSC, What to do?
  • 362 Answers
Hi hindsite97, I will be happy to help.
  1. Press the menu button
  2. Use the up/down arrows to select Menu setup
  3. Press the right arrow button and then the up/down arrow button to select Auto Program
  4. Press the right arrow button to select Auto Search
  5. Press the right arrow button to begin Auto Search
This should FixYa as long as the Tv is operating correctly. Here is a link to the users manual in case you don't have it. http://www.polaroid.com/service/userguides/ce/lcd_tvs/fla3232b_fla3732b_ug.pdf
Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
  • Jason Morris Jan 19, 2009
    It appears your tv is not functioning properly, Here are a couple of things to try.
    1. Use the buttons on the tv control panel to scan for channels, not the remote.
    2. Unplug the tv for an hour to allow reset then try the scan again.
    Let me know the results.
    Lone99star
JVC HD-56G886 tuner stopped working
My (unfortunate) guess would be the Tuner received a static discharge when you were changing the antennas... this time of the year is bad for static - if you're in a "Winter" climate.
Receivers have a very sensitive FET or MMIC amplifier right inside from the antenna connection to make it better for picking up distant stations.
However, this same "sensitive" amplifier is also prone to being destroyed by even a small static discharge... especially if the tuner had its power turned ON.
Sad to say, it's likely toasted... :-(
(I hope I'm wrong... but you have already tried all other possible solutions)
Jan 12, 2013 | JVC HD-56G886 56" Rear Projection HDTV
The DTV input in my GV46L stays black. Why?
You don't say what you are trying to input but take note that your model does not have a digital tuner on the DTV input. If you use a digital OTA antenna, the signal must first go through a digital converter or tuner before it goes into the DTV input. The DTV/ANT input is only cable ready. There is no digital tuner in the TV to activate the DTV menu.
Nov 02, 2012 | Vizio GV46L 46 in. LCD Television
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
Is this system set up with a converter to run off and external roof-top antenna or does it need a digital converter box?
This model will require a digital converter box to receive the digital OTA channels since it has an NTSC instead of an ASTC tuner.
Sep 21, 2010 | iLO 2600 Television
Sceptre x23BV-naga 23" LCD HDTV needs a digital tuner replacement
just get a hd standalone tuner and hook it up to one of the inputs. way cheaper solution.
Apr 09, 2010 | Televison & Video
How do I hook up a Pioneer PDP-4300 for High Def?
That depends on what source your talking about.
Cable call you cable provider and ask them for a HDTV box
Satalite you should already have one if not ask them.
OTA =over the air you need a digital tuner with a nice antenna I suspect this has a digital tuner inside so all you need is a good antenna.
DVD= hook the DVD up with the red,green,blue cables called SCART connections..
Blueray= Will bring you high def.. with its connections.
So your question is vague and can be answered in so many ways.. Rate me please
Oct 03, 2009 | Pioneer PureVision PDP-4300 43 in. Plasma...
Not able to scan for digital OTA channels on a JVC LT-32X667 LCD
Seeing as it does not have a digital tuner in it, I would think this would be the problem, you will have to get a box for it.
Aug 23, 2009 | JVC LT32X667 32 in. LCD Television
Cancelling cable
That model has an additional ASTC DTV tuner. Plug into the HDTV co-ax input from the DTV antenna.
Jun 03, 2009 | Polaroid FLM-323B Television
Maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
Apr 08, 2008 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
Digital Television
You will need to use a converter box if you want to receive digital signals from an antenna as the tuner is not the ASTC (HDTV) type. Once you get a converter or cable box you can come out of it with component video cables and go into one of the inputs in the back of the set.
Feb 26, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Polaroid FLM-323B Television Logo
279 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
