Question about Kenmore 24032\24036 Top Load Washer
Washer will not spin or agitate
My Kenmore 80 series washer will fill with water but will not agitate the clothes or spin. Was working great then all of a sudden just stopped. Help Please
  • lil2foxie Jan 13, 2009
    Thank you for responding so quickly. I'm going to try it first thing tomorrow. Is this something a female can do?
  • 135 Answers
This is a bad coupling, part # 285753. It is available from timerking.com for $9.99, and other places as well. To replace unplug and lay the machine down on its back, remove the 2 pump clips, and slide the pump out of the way. Then remove the 2 motor clips and remove the motor. The coupling is between the motor and gearcase. Hope this helps!
Posted on Jan 13, 2009
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore washer wont spin
Transmission parts that would cause that are the clutch and the spin tube. Also an article of clothing wedged between inner and outer tubs could cause it.
Nov 15, 2017 | Kenmore Washing Machines
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Hot water wont shut off
solenoid valve is jammed open
replace
Mar 31, 2008 | Kenmore 24902 Top Load Washer
It won't agitate
after it fills do you hear any sound and does it go to spin on its own or do you turn the timer your self it could be a bad pressure switch thats what we are trying to determine
Feb 12, 2008 | Kenmore 24642 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
78 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
