Question about LG Kitchen Ranges
How do you replace the hidden oven element in an lg range
Techsim
  • 59 Answers
SOURCE: Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Posted on Nov 03, 2008
SOURCE: LG Range Element Will Not Heat
on my 30755 top left element will turn on but not adjust top right turns on to high only will not adjust . 3months out of warenty
Posted on Dec 14, 2008
SOURCE: Oven element started to spark
See this for description of same issue:
http://forum.doityourself.com/appliances-large-electric/255234-ge-electric-range-oven-element.html
Posted on Jan 24, 2009
ethelpilgrim
SOURCE: bottom element needs replacing
the side right side panel comes off three screws hod it on the back pullout
Posted on Feb 08, 2009
SOURCE: Whirpool electric oven replacing bake element
In addition to what aborcass stated, I just had to fix the same problem. Remeber to turn off the power before you do this. On my stove the element acess is behind the side panel (right side when facing the stove). You remove two screws on the back and one underneath at the bottom, (you need to pull out the drawer). Once screws are out, slide the side panel forward gently about an inch and it should just drop off.
You should see the wires for the element level with the bottom of the stove. The wires will guide you to the element. And you should see that the element is screwed in with two screws to the stove. This is the tricky bit, to remove the element follow the metal piece holding the element to the right until you see a third screw. Remove this screw and the whole thing will come out. Take off the wires, replace the element on the metal strip, slide the element and metal strip back into the stove (take care to ensure the left side of the metal strip slides into the proper position under the metal clasp. Re-attach the screw, plug the wires onto the element and turn the power back on. You should have heat.
Good luck.
Posted on Apr 05, 2009
Gr673lxss 1 how to find hidden bake element
Kyle,
Usually what they mean by "hidden" element means that the bake element sits in a recessed part of the oven cavity. You only have one bake element and one broil element in the oven. Hope this helps.
Mar 13, 2015 | Whirlpool Electric Range
Replacing hidden element frigadaire oven fpes3085kf
There are normally two options for this. There's either an access panel at the bottom of the oven, or a panel underneath the oven. It's best to have a certified technician do it, to be sure that it's accessed without hurting the range.
May 21, 2014 | Frigidaire Fpes3085kf Slide In Electric...
FIND HIDDEN ELEMENT
The lower panel in the oven should lift out Depending on brand ma have a couple of screws at back of panel to take out first then they usually just lift out to expose element
Mar 14, 2014 | Kitchen Ranges
The Bottom oven element has burned out. Is is
It's replaceable,if it's an exposed element meaning you can look in the oven and see the element you can do it yourself unplug the range take out the two screws securing it pull it slowly toward you,unplug the two connectors and put in the new one,if it's a hidden bake meaning you can't see the element you would be better off having it done.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I am looking at buying the new hidden heat element
It sure can. Whirlpool has some wonderful appliances and their ovens have a very large capacity for your Thanksgiving turkey or what ever you cook. The best of luck to you and enjoy your huge new 30" oven.
Sep 07, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Hidden bottom element not heating. Went to remove it and it had burnt through. New element doesn't get hot.
Assuming that you installed the replacement correctly, can you check the element with a resistance meter?
It's possible the replacement element you bought was faulty. But first, we want to ensure that the oven is otherwise functioning correctly. You'll need that resistance meter to check continuity along the red wire (i'm presuming) that connects your top and bottom element to your selector knob. Also make sure there are no internal fuses in your oven that may have blown.
Please remember to turn the oven off at the breaker board before working inside it.
Hope this helps, let me know.
John
May 09, 2009 | Kitchen Ranges
How to change hidden element in kitchenaid oven
you have to remove the plate that covers that element
Jan 03, 2009 | KitchenAid Kitchen Ranges
Oven heat
Nov 03, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Cooking element
You do not list a full model number. Typically a JBP78_____ uses a WB44X10013 bake element. Disconnect power to range. Take out two 1/4 inch hex head screws holding element in at back of oven. Pull element out a few inches into oven. Disconnect wires. Reverse to install. Not too hard if it is an exposed element. A bit more involved on ranges with "hidden" bake elements (which are under the floor of the oven).
Oct 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kitchen Ranges Logo
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
