Question about Panasonic TH Televison & Video
Our panasonic plasma tv model TH-50PE8U only shows a black screen
  • 3 Answers
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
what is a UPS?? mines doing it too
Posted on Oct 05, 2008
  • 225 Answers
SOURCE: Plasma TV - intermittent blinking
Power supply failure. Either a capacitor went bad, or there is a loose solder joint near the big transformer on the power board. I would guess loose solder connection.
Posted on Nov 14, 2008
  • 21 Answers
SOURCE: TV Screen Stripes
NOt very clear.....
Multiple stripes all over the screen? Vertical or horizontal?
If it's only like an inch vertical lines put a mark on the cabinet where exaclty the line is, turn off the TV then open the back, you'll see lots of ribbon wires (gold color) from the plasma panel it self going to buffer boards, using the mark find the closest ribbon wire where the line is showing then remove and clean the contacts, make sure to reseat it properly when putting it back otherwise you'll just add more lines or black bar on the screen if pins are not seating properly.
But do not be afraid if the lines get worst just turn the power off right away and reaset the ribbon wire till you get it correctly.
CAUTION;
DO NOT try to do this while the TV is on oherwise you'll burn COF (Chip on film) on the panel and you'll end up replacing the whole PDP.
Posted on Mar 11, 2009
  • 814 Answers
SOURCE: screen goes black after 1-2 hours
You need to have your television tuner tested for faulty components. Your problem is caused by the components in you tuner overheating and losing functionality. The tuner need to be thoroughly test and repaired. You can reach Panasonic customer support at this telephone number. 1-888-843-9788. They should be able to tell you what the problem is and where to take it for repair. I hope this information helps you with your problem.
Posted on May 22, 2009
  • 9 Answers
SOURCE: Panasonic TH-42PX60U PLasma - 1/2 screen blacked out
If the screen split is exactly 50/50 top/bottom You are not getting SU or Scan Upper drive.
These are lovely set to work on.
Most likely is SU board itself - Not repairable just to be replaced.
Sorry I work in the UK so I can only guide that the UK part is around £30
SU may have been damaged by failure if the PDP (Plasma Display Panel) but is 9 years only had 2 screens damage the SU board.
There are several setups to do after fitting a PDP. If you don't have the service data - Do not risk it, Reduced life of the Panel and a safety risk.
Posted on Aug 14, 2009
Panasonic Plasma 50 TH-P50U30A blacked out with no sound
Appears to be a power supply issue with everything being so dead.
Jan 22, 2017 | Panasonic Televison & Video
Panasonic TH50PE8U
Panasonic Product Support - TH-50PX80U
shop.panasonic.com > Get Support
PanasonicOwner's Manuals. Owner's Manuals and Documentation. Operating Instructions Manual- TH-50PX80. Warranty. Warranty information. Warranty - TV Plasma ...
Panasonic TH-50PE8U Flat Panel Television User Manual
tv.manualsonline.com > ... > Panasonic Flat Panel Television
... and free pdf instructions. Find the user manual you need for your TV and more at ManualsOnline. ... Panasonic TH-50PE8U Flat Panel Television User Manual ...
Oct 29, 2015 | Panasonic Televison & Video
Panasonic 50" Plasma. Model: TH-50PE8U purchased in November of 2008 Recently has stopped working. Powers up but just has a black screen. Nothing comes up. Any suggestions as to what is wrong or how t
Do the power LED at the front panel light up, when you switch ON the set. If yes, the main board & sustain boards need to be checked. If NO; the main power regulator board should be replaced. In both the cases, it will be better to contact the authorized service center; especially to Plasma Displays.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 30, 2014 | Panasonic VIERA Televison & Video
When you use a input the screen fuzzes red. It's a Panasonic Plasma TV TH-42PZ85U. It was made in 2008. Started when i was playing a game. It did it a few times and now its permanent. On the Video Inp
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 19, 2017 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
My Panasonic plasma TV has suddenly developed a one pixel thick horizontal black line across the screen. It is not there when the TV is switched off.
it'll not be there when tv off because dead pixels do only show when back light of screen comes on, anyway if you still have a warranty then ask for them to check it out as it sounds like you need a new screen there mate
Nov 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
My Panasonic Viera 42" Plasma, 2 yrs old, Model # 42PZ80U, screen just went black and I cannot bring it back. The red light is blinking 10 times.
Typically this means you've got a power supply that went bad. I've been doing research for a potential class action lawsuit on these "blinking lights of death" problems that the Panasonics are having and that is usually why the tv will show 10 blinks. Occasionally another component inside the tv can be what caused the tv to shutdown and show the 10 blinks.
I'd like to hear more about your experience with the television and any contact you've had with Panasonic in an attempt to get the television repaired. If you're inclined to share your story with me, please contact me at kiaeger@levjen.com.
Oct 12, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonice TH-50PE8U Red/Purple Line
take a rotary vacumm and make circles on screnn make sure tv on and vacumm, back up slowly making circles that take up the whole tv, repeat this s couple times, it goes away
Jun 22, 2009 | Panasonic Viera TH-50PX80U Plasma TV
I have the Panasonic TH-50PE8U plasma tv and a Dell Latitude laptop. I tried connecting those two together as the tv as a monitor but when i plugged it in and restarted the laptop it would show up on the...
My girlfriends computer did this a lot. What we did and I don't know if it would work for you was to use the HDMI cord (obviously your laptop has to have an HDMI). The S-Video cord was very tricky to keep it from going black we had to mess with the cord a lot!
May 16, 2009 | Panasonic TH-65XVS30U 65 in. HDTV Plasma...
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Televison & Video Logo
67 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
