Question about Brother MFC 420CN All-In-One InkJet Printer
Black taping brother mfc-j825dw cartridge - Brother MFC 420CN All-In-One InkJet Printer
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC 425CN will not print black
Have a look at the bk cart. Did you fix it well into position by clipping the support above the cart?
Can you see any difference by ink fuel before and after cleaning cycle? If there is no difference the valve is not open: drill a hole into the top cover and leave it open. Try another cleaning cycle again.
Posted on Nov 05, 2007
bob_computer
  • 3153 Answers
SOURCE: not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Posted on Aug 22, 2009
komguy
  • 2306 Answers
SOURCE: Brother MFC-6490CW is not printing black
If it's under warranty you're in luck, you need a new printhead,LK3197001, around $80.00. I just replaced one yesterday in the shop for the same problem. I would call Brother customer service and see if they'll help cover the cost.
1-800-276-7746
Posted on Sep 04, 2009
Testimonial: "Thanks, 'komguy' :) !! That's helpful. I'll get hold of them ASAP! Cheers!"
  • 127 Answers
SOURCE: Brother printer won't recognize ink cartridge.
I use generic cartridges all the time in my brother printers with no problem. better to pay $2 per cartridge than whatever the brother brand ones cost!
Posted on Jan 05, 2010
pineworks
  • 4041 Answers
SOURCE: Just replaced ink cartridges on my Brother MFC
Hi there you can refill Brother cartidges, like other printers it will not have it sorry.
This is the only way you can trick it.
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 04, 2010
Brother mfc-j825dw, Service manual
For a service manual, contact Brother directly.
Mar 27, 2017 | Brother "MFC-J825DW Wireless All-in-One...
How to reset brother mfc 7320 toner life end message
Remove cartridge. Place a piece of electrician's tape over the small circular translucent window on the right side of the cartridge. Reinstall cartridge.
Oct 09, 2014 | Brother Tn2110 Black Toner Cartridge For...
BLACK WONT PRINT ON BROTHER MFC-J825DW
Needs more Cleaning on Black (3 times) then leave the machine ON but dont do anything on it. There is Negative pressure and it needs 1 day to go away
Jan 31, 2014 | Brother Mfc-J825dw Multifunction Printer
Printer not detecting ink cartridge
Clean contacts, check level. Is it OEM or a refill cartridge???
Oct 10, 2013 | Brother MFC-J825DW Wireless All-in-One...
Brother MFC-J825DW false paper jam error
In my case that was registration actuator leaning to the side.
I was able to find it by removing back cover, and gently moving black plastic actuator to the side (stick).
It's prety well described in Brother "SERVICE UPDATE No. F1400" that I googled.
Good luck
Feb 22, 2013 | Brother MFC-J825DW Wireless All-in-One...
Mfc-j825dw keeps saying scanner cover is open and its not. how do i fix this
short of returning it for another look to see if the lever where the cover closes is not got tape or something preventing it from seeing the door is shut.
Aug 27, 2012 | Brother MFC-J825DW Wireless All-in-One...
Not detecting ink cartridge - or saying empty - Brother MFC 240c
OR
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 5460CN Won't Print w/ Full Black Cartridge
What type of machine do you run?!! MFC420 or mfc 5460?!!
Is it a machine with LC51 or LC41 carts?
In both way: Did you check the other carts? It could be that there is another one empty.
Did you stick the tape at the right place, too? The tape should be a bit larger than shown on the pic.
For the LC51 it it the same position.
Did you answer the printers question of changing the cart with YES?
Nov 27, 2007 | Brother MFC 420CN All-In-One InkJet...
MFC-240 shows no ink cartridge
Same problem here... Figured out something that works fine for me anyway.
I took some black electrical tape and covered the clear plastic area in the front of the cartridge. It's a bit of a delicate procedure. Need a piece of tape about 3/16 of an inch wide and 1/2 inch long to match the contour of the clear plastic so it still fits inside the printer and can be surrounded by the light sensors.
Unfortunately, I think Brother is making too much on the ink cartridges and therefore is trying to make them tamper proof. I t's backfiring on them. Will never buy another Brother.
Oct 03, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 420CN All-In-One InkJet Printer Logo
94 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
