Question about Canon PIXMA MP160 All-In-One InkJet Printer
Feeds Paper but Does Not Print
The paper feeds; however, it does not print. Makes the printing noise but no print. HELP!!!
  • Anonymous Mar 24, 2014
    When printing from the computer after placing the paper in the feeder it just makes a loud noise like something isnt clipped in .. Can you help??
    President:
  • 2,692 Answers
Does the manual give you instructions on how to chean the ink heads? Clean them.
Posted on Jan 13, 2009
The printer does not print. It feeds paper and
Visit HP support for this problem (XP):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01853840&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443024
If you have Vista, change query to read "Printer prints blank sheets of paper" > Choose Vista instead of XP
Dec 05, 2009 | HP Photosmart 8250 InkJet Printer
I print a publication so I print many copies within a few days. It says Paper Jam in tray area but I can see no paper, it makes a noise and never feeds the paper.
Some Laser printers require the paper to be loaded out of the **** on one side to work well. Flip your paper **** over and try loading the paper upside down. Sounds funny but may fix your issue. Also look at the type of paper you are using your printer may need a thicker or thinner paper (look at the manual). Clean the pickup rollers!
Jul 07, 2009 | Samsung ML-2510 Laser Printer
Epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Apr 17, 2009 | Epson Stylus C86 InkJet Printer
Replaced paper in Omni 3750, now it feeds but doesn't print
Make sure you are using thermal paper and it is feeding from the bottom of the roll. If not press down on the lid when the paper is printing sometmes the tension springs were defective.
Feb 19, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
Mis-feeds paper and thinks it has paper jam
the gears of the printer r worn out and they have hanve lost their allignment settings so this problem.either replace the gears.or the other solution.do not insert the paper in the tray ,keep it little bit outside and hold the end of the paper in hand when you will give a printout the printer will make a noise of picking the paper at that time just push the paper inside and then it will print properly.
Dec 10, 2008 | HP Deskjet 2330 InkJet Photo Printer
Printer will not print!
You have a problem with the inner PMX motor inside your printer.
Call HP support
Nov 17, 2008 | HP DeskJet F380 All-In-One Printer
C4380 HP Printer
Does it make noise when it first feeds paper or when the print module sweeps across? It's possible that there is some obstruction in the paper path or in the way of the print module. Is the noise constant or only when a certain action occurs? Let me know.
Oct 29, 2008 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
43 people viewed this question
old marine
old marine
