Question about Sceptre 32 X320BVHD 32 LCD TV
SCEPTRE X322BV, HDTV BLUE LED COMES ON WHEN POWERING UP, BUT NO PICTURE OR SOUND
    New Friend:
  • 41 Answers
I have the X322BV-HD and with no warning had the same thing happen. I"ve scoured the net and found very little--just as here on this site. I just got off the phone with a tech support rep at sceptor and got the following information:
HOW TO DO A FACTORY RESET:
  1. (Tech said this will often work even though you won't see anything on the screen--as long as the blue light is still on!) On the remote, press [MENU] and then 3 - 6 - 9 - 8 (If it's accepted, the TV will turn itself off.)
  2. Wait 10 seconds.
  3. Turn the TV back on and it will be back to all factory defaults.
That didn't work for me. But the second option, a Power Cycle Reset did.
POWER CYCLE RESET:
  1. Unplug the power cord and wait 10-15 minutes (extremely important, I used a timer set for 16 minutes just to be sure).
  2. While it is still unplugged, press and hold the [POWER] button for at LEAST 30 SECONDS - DO NOT RELEASE!
  3. While continuing to hold the [POWER] button, plug the TV back in.
The second option worked for me and it's back on working just fine. Hope this helps!
Posted on May 24, 2014
  • 1,238 Answers
In that case you need to call a service ,
Posted on Dec 10, 2012
4 Suggested Answers
SOURCE: 32" LCD HDTV Sceptre model x32, blue led but no pic or sound !
Having the same problem. Took it to a repair shop and they say it is some capacitors and the power supply... Which seems kinda hinky to me... I would think one or the other would be the problem, not both at the same time.
Posted on Aug 02, 2010
  • 8457 Answers
SOURCE: Screen goes black after powering up sound is just fine.
The backlight video board inverter it dead,need a new one.
Posted on Oct 03, 2009
  • 9 Answers
SOURCE: I have an Sceptre 37"
For most TVs in the market, you would use their DYNAMIC or VIVID mode for the best picture settings.
Posted on Sep 09, 2011
Hi, have 2 sceptre 32 inch led tv, both same problem, no picture no sound, just red to blue light. do you have part that can fix this problem model, #x322bv and x325bv
I can't find a manual for either of these sets so I'm not able to be specific with parts but a set with no sound or picture is generally caused by either a bad main board or power supply. You can find out what board is bad by checking the PSON..stands for power switch on , the voltage should change when you push the on button and stay that way but going by the fact you get a blue light I'm guessing that is working and you have a bad power supply, another test would be with the set on and the light blue test the various power supply voltages and see if any are missing or incorrect, the values should be on the legends next to the connectors, they will say for example pin 1 ground pin 2...12 volts...pin 3... ground...pin 4.5 6...5 volts ect....Good luck!!
Nov 15, 2017 | Sceptre Televison & Video
FIX BLUE SCREEN ON LED TV
A blue screen usually indicates no video signal.
Jan 25, 2016 | Sceptre Televison & Video
I HOOK UP A RCA BLUE RAY I GET THE SOUNF AND PICTURE BUT IT'S NOT SHOWING IN COLOR
Check in menu to see if the region is set to Pal Europe instead of NTSC.this should restore colour.if it is already set to pal and giving black and white then switch it to NTSC
Dec 07, 2014 | Sceptre X322BV-HDR 32" LED TV 1366x768, 60...
Have 32Sceptre led 2013 have sound but no picture wonder it could be the inverter or the panel
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Nov 24, 2014 | Sceptre X322bv-hd 32-inch Class Television...
Sceptre X42GV-Komodo 42 in. LCD TV no picture no sound but splash screen displays good
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 22, 2014 | Sceptre Televison & Video
X322BV-HD sceptre picture but no sound
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Oct 24, 2014 | Sceptre Televison & Video
Sceptre 32 inch, Blue LED light comes on but no picture or sound.
The internal power supply is failing. You are having to "shock" it into operation by plugging and unplugging.
Jan 01, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
32 inch sceptre x322bv lcd tv wont show video, it turns on with the blue lcd to indicate it powering staying blue for 4 seconds then goes red while the lcd screen shows the sceptre logo for 1/2 second im...
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Aug 15, 2017 | Sceptre X322bv-hd 32-inch Class Television...
My sceptre 32" class LCD 720p 60hz HDTV x322BV-HD!
if that is brand new and still covers on warranty you need to do is get back to the dealer for repair or possibly replace
Nov 03, 2012 | Televison & Video
Sceptre 32 X320BVHD 32 LCD TV Logo
5,016 people viewed this question
Top Sceptre Televison & Video Experts
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
