Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide,
that gives step by step information on Dis-Assembling with screenshots,
even a novice can fix the disc eject problem with the help of this DIY
Guide. It also gives information on fixing many Wii Related Problems,
so its a kind of Wii Problems Reference Fix Guide
what i would recommend is to unplug the unit and hold the power/eject button for 15 seconds. Plug the unit back in and hold the eject for 10 seconds while the unit is on. Let me know if this assists your problem or if you need further assistance and i will be glad to assist you. Thanks and have a great time with your Nintendo Wii
1 Try this: While holding the SELECT button, press the ATT button for 2 secs. It will rest the player and eject the CD
2 To unlock the CDWhile pressing CD, press and hold 0 formore than 2 seconds.“EJECT”appears on the display, and the CD eject from the slot the slot
# If above does not work you have to open the cover and remove CD manually
Do you have any small children in you house?
They love to put quarters, flat washers, etc. into cd drives. This is the major cause of the drive not ejecting in my experience. I have never had a Mac CD not eject a disk. It is very difficult to get foreign objects out of the slot, and I suggest taking it in for repair.
There is a small eject switch inside the drive slot. The idea is to push on it with an "unbent" paperclip. Its located at the left (or bottom) of the slot. You'll have to experiment.
The eject button is the load button on our 2005, maybe the same for you. Just hold it in for a few seconds and it should spit out your cd. You should be able to lightly put the cd up to the insert space and it should take your cd. If your cd player holds multiple cds then perhaps there are some in there that have not been ejected. Hope this works for you.
frist make sure you are inserting the disk correct label side up or label to the right if you are which you mostly Are then your console has a propbelm with feeder which mean it must go back to the store
I had the same symptoms. The reason to my problem was that my 2 year old has pushed *three* disks into the console. I got them out through the following, admittedly pretty weird, approach: I hit the eject button, while gently prodding with another disk into the slot (at a slight upward angle). I could feel the disks inside the console rotating or vibrating as I was *gently* touching them with the fourth disk and hitting eject repeatedly. Somehow, the gentle prodding made one of the disk come out a bit, so I could pull it out easily. (I was pretty surprised when a second disk came out, and then a third.)
