Question about Microsoft Windows Vista Ultimate Edition
My system is hanging frequently
I have a system with XP Service pack 2. It is hanging very frequently. The system has been formatted for about 4 to 5 times now and I still have the same problem. I thought it could be a problem of the RAM. I have got 2 RAM's in my system, 512 & 1GB and I tried running my system only on 512 and later only on 1 GB still the problem persist. I checked the mother board and none of the components on motherboard is getting heated. Checked the SMD and found it to be fine. Removed the complete motherboard from the cabinet and tried installing and the installation went fine, but after a few hours it again got hanged. I am not able to resolve the issue. SMPS is also working fine, what should I check next.
  • Farhan Hafeez
    Farhan Hafeez Jan 13, 2009
    I have an assembled PC. it is not a branded machine. The trouble started a month back and I would say it started all of a sudden. I have changed nothing and still getting that irritating problem
  • Cheryl May 11, 2010
    When did this trouble begin? What changed before it all started? And what is the brand of your computer and motherboard?
    ~~Cheryl
  • 24 Answers
Use the Microsoft-supplied Performance Monitor log to pinpoint where the trouble is occurring. If that doesn't lead you to the solution, please supply further details:
  • Brand of motherboard, memory, chip, etc.
  • Exact error message or behavior. Do you get a blue screen? Does the CPU usage top out? What exactly do you mean by "hang"?
  • Does the problem occur in Safe Mode? You will not be able to use many of your devices and peripherals in Safe Mode, but at least this can help rule out trouble with the basics: motherboard, memory, etc.
~~Cheryl
Posted on Jan 13, 2009
Why dont u pick ur computer first, n then u go to the nerby comp shop n slam it on the floor n buy a new dell computer.is it fine now????????
Install XP, it hangs up with the message at the bottom ''Searching for previous versions of Microsoft Windows'' please help
Windows installer always formats the disk after checking the previous installation. There are two ways to overcome this problem. One, if windows still boots, then insert the installation disk in the drive and let it Auto Run, and ask you whether you want to upgrade the OS or install new. If you upgrade then the formatting will not take place as windows knows that there is already a window on the disk. But should you want a new installation then it will do all the checking and may hang again. So, upgrade. Two, dl you have a DOS bootup disk. If yes then boot up with DOS boot up disk and format the HDD with it. once it had formatted and windows checks up, let it. It will not hang now. as there in a very clean HDD.
Nov 09, 2009 | Microsoft Windows XP Professional with...
Key of windows xp server 2
I dont know if it will matter but whaty service pack are you using?...and is it the corporate edition?
Jul 26, 2009 | Microsoft Windows XP Professional With...
Troubleshhoting of acer Laptop.
DEAR,
1. install XP service pack 2, format in Fat(32) or NTFS system file,
2. delete the partitions
3. restart your computer with XP service pack 2
4. dont format as quick format,
5. do full format
6. XP service pack 2 serial key: XP8BF-F8HPF-PY6BX-K24PJ-TWT6MA
try it all the best....
Jun 20, 2009 | Computers & Internet
Format my laptop.very slow and gets hanged
hi there. As long as you have an xp/vista disc the process is simple. Here's what to do:
1-Insert the xp/vista disc into the laptop.
2-restart the laptop and boot from cd
3-click to reformat drive and fresh install xp/vista
4-when needed, insert cd key which is located on the bottom of your laptop.
5-Make sure to install updates eg, service packs etc and security software.
May 27, 2009 | Computers & Internet
My PC is not installing XP service pack 2
You'll need to upgrade your RAM, minimum requirements for windows xp is 512MB.
for the best price on ram go to http://www.pricewatch.com
i would recommend at least going to 1 or more gig.
Mark
Mar 27, 2009 | Intel Celeron 2.4Ghz Socket 478 CPU (...
Is windows XP service pack 3 arrived..
Dear, It is coming soon as a bootable format. then you can install just SP3, no need of SP3 for that.
you can down load SP3 from Microsoft web site free and just run it over SP2.
Hope, it will help you.
Regards,
Rakesh Kumar
Network Support Engineer
Nov 09, 2008 | Microsoft Windows XP Professional With...
Need to upgrade from Windows ME to Windows XP or Viesta
Yes you can upgrade to windows xp service pack 2/3 without problem. I recommend you update the bios (rompaq) from the revision on the compaq site, and install at least a second
SDRAM 256mb memory module in it first or it will run slow and hang up frequently. I've been running mine on XP for years, still using it now;) (with 384 memory-one 128chip and one 256 chip)
Jul 26, 2008 | Compaq Presario 5WV270 (202498-003) PC...
I installed new XP Pro (SP2) on PC with motherboard ECS 848P-A. The system restarts or hangs frequently. Please help. THankssss
hi
(1) check your power supply earhing, smps
(2)check *********** board dont ground with cabinet.
(3)check the hitting event of all circuit and processor fan.
check your ram
(4)if upper is not problem then
format the system and install new winxp
Mar 20, 2008 | Computers & Internet
Uninstall xp
You can remove service pack 2 from within add/remove programmes, you will not lose any documents, but you will lose the udated security patches which is not recommended. If you mean you wish to remove XP SP completely, obviously the files and everything you have installed on c drive will be deleted as you can only save docs etc within an operating system, as c: is just a partition on your hard drive the files reside within the operating system. If you are upgrading to another operating system my advice would be to use a dual boot system and install the other operating system on a seperate partition of your drive, but you would have to have a fair knowledge of pc operating system installation processes.
Oct 03, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows Vista Ultimate Edition Logo
537 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
