Question about Nokia N73 Cellular Phone
How to format phone memory N95? - Nokia N73 Cellular Phone
    Genius:
  • 1,665 Answers
Method:1
1. Switch off the phone.
2. Hold down the following three buttons: Green (call answer button, * button, and ‘3′ button.
3. While holding these buttons, press the power button and switch on the phone.
4. When the message ‘Formatting’ appears on the screen, release all of the buttons.
Method: 2 ( Hard Format)
2. Hold down *#7370# button.
Method: 3 Soft Reset
2. Hold down *#7780# button.
Posted on Jan 13, 2009
    Scholar:
  • 35 Answers
Type *#7370# into the phone while on.
Remember to back-up your data using the Nokia PC Suite.
Also make sure you remove your memory card if you have one, and remove the password from the memory card before you try to reformat.
1. Switch off the phone. //Erm..nothing happens when its off..
2. Hold down *#7370# button. // No-one cant press 7 buttons at same time, and there is 7 and # twice, what colour of mushrooms have you eaten?
3. While holding these buttons, press the power button // 8 buttons same time? that goes too far...
4. When the message ‘Formatting’ //it just starts normally...this must be a joke.
Real way: When phone is ON! press *#7370# then klick yes..voilá!
Posted on Feb 11, 2009
SOURCE: Formatting N95 Nokia Phone
my handset(N95) restart if i was capctures the photos.  so what i have do?
Posted on Sep 10, 2008
billman87
  • 27 Answers
SOURCE: Format N95
There are 3 methods to format the phone
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! IMPORTANT: back up your phone and memory card first! ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
First: if the phone menus work there is a; go to menu -> tools -> settings -> general -> factory restore. note: the defualt code is 12345
Seconed method requires you to enter these into the dial number area. Nokia Code : *#7370# : NOKIA Format phone (Soft Reset)
Nokia Code : *#7780# : NOKIA Factory Reset (Hard Reset)
Found these in the N95USERS fourm. Note: the defualt code is 12345
Third: is a button combination the needs to be done during the phone powering on
Hold down. 3, * and Green Call button While holding this combination press the power button once to start the phone Note: this does not require any codes; if this works the phone will prompt you to be set up again
None of these methods format the memory card
There are two methods to format the memory card
First: Go to menu -> tools -> utillites -> memory -> options -> format mass storage
Seconed: Connect your phone to your PC via the supplied USB cable. Then select Mass Storage mode on the phone. Once you PC has installed the Mass Storage device you can format the card from My Computer. Note: assuming Microsoft Windows XP or VISTA.
Billman87
Posted on Jan 04, 2009
Raysagem
  • 1017 Answers
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
You could try this, but don't hold much hope:
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know, you need someone to press the ON button.
Or try:
Hard reset code *#7780#
Posted on Mar 02, 2008
nonontech
  • 4737 Answers
SOURCE: i am using Nokia N95 ordinary phone,i formatted my
Among all the mobiles I and my friends have used, Nokia is one of the best except it's price. The error “memory full delete some data” is not only with this Model but with several Nokia handsets as well. N95 has an built-in large internal memory as compared to other models, but when the RAM has not enough memory this error happens, sometimes corrupted files create this, sometimes virus so there are several solutions, but first follow these steps:
Check and delete the following:
-Call logs
-Messages (Large bluetooth receives)
-Media stored on the phone, not on the card
-Old Calendar entries
-Browser bookmarks and saved pages
-Apps on the phone; reinstall them to the Memory Card!
-Unwanted contacts
If this doesn't end the error, back up your stuffs using PC suite or directly to your Memory card then reset the phone using
*#7370# or 12345. Good luck
Posted on May 08, 2010
swapnilbhujb
  • 6 Answers
SOURCE: I want to format PHONE
Switch off ur mobile and whn turning on hold three key of phone (call key, # ,end key OR call key, #, 3) dnt release keys until phone fully starts. Aftr u will get ur phone is formatted. Plz backup ur contacts and other data befor doing this in memory card or pc and then restore. swapnilbhujbal@live.com
Posted on Apr 10, 2011
I want to format PHONE MEMORY of my NOKIA N95 8GB? I am unable to delete applications in phone memory. Is there any way to format the phone memory?
Apr 10, 2011 | Nokia N95 Cellular Phone
Not detecked memory card
do format your memory card then insert it in mobile phone
May 25, 2010 | Nokia N95 Cellular Phone
Why my n95 cannot read memory card? always showing memory card corrupted. when i try to format it shows that the card is in used by other application.
Try to format your memory card and remember, memory card use FAT system. if you format your memory card to FAT32, you can't open it on your phone.
Jan 20, 2010 | Nokia N95 Cellular Phone
How to reseta nokia n95 memory
you can do a soft reset that will reset the memory for your nokia n95 . Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device: Soft reset code *#7370# Hard reset code *#7780# If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95: + Turn off the mobile device. + Press and Hold the following three buttons: the green Call Answer button, the ?*? button, and the number ?3′ button. + While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details. (note a hard reset will erase all data that is not saved to a sim or card) a soft reset only resets the memory and the phone. it will not erase your data that you saved
Nov 11, 2009 | Nokia N95 Cellular Phone
I can not erase the phone memory of Nokia N95 8gb
Change the profile to General, then use *#7370#
Aug 05, 2009 | Nokia N95 Cellular Phone
Phone restart several time(Nokia N95) HELP!!!
Here i think your phone memory is affected with virus and you have to format it once if it is attacked.
Because virus scanner are not going to delete it.
Let me know exactly, what is the problem?
If it is saying Phone memory is full and a pop up will be blinked to delete some data, then your phone is attacked.
So try to format it. not just restore factory setting
Jun 03, 2009 | Nokia N95 Cellular Phone
Hi....can i reformat N95 8GB China Phone to SYMBIAN OS?????
Hard reset your phone by keying in *#7370* and putting in your code (default is 12345)
You format the Mass Memory by going Menu>File Manager>Mass Memory>Options>Format.
Hope this helps! Thanks.
Mar 17, 2009 | Nokia N95 Cellular Phone
N95 phne
well, formating your phone has two aspects to it.it could be either formatting your phone itself or your memory card only. formatting your memory card can be done in the memory card program on your phone, but formatting your phone requires you to type in a code in your stand-by screen ( *#7370#) Formatting your phone memory will delete all settings, messages, calendar items, contacts etc.
May 30, 2008 | Nokia N95 Cellular Phone
Y is the mass memory of my n95 8gb alwiz saying memory in use?
you are using too much applications in your phone. close any applications and try to run it again.
Jan 20, 2008 | Nokia N95 Cellular Phone
Format N95
Billman87
Nov 16, 2007 | Nokia N95 Cellular Phone
Nokia N73 Cellular Phone Logo
1,792 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
