Proscan 32lb30q will not work with my PS3?
I have a hdmi to av connector and just the plain hdmi cord and neither will work with my proscan flatscreen monitor. Any suggestions? The hdmi works fine on my other flatscreen.
SOURCE: ps3 gets sound but no picture when using hdmi cord
hi theres is 2things you can do leave the scart in then go to settings and select hdmi or plug the hdmi lead in on its own switch the ps3 off leave it for 10 seconds and then switch it back on it should then ask you to select hdmi and go through some settings hope this works friend had the same problem
Posted on Jan 10, 2009
gamerfixer07
  • 344 Answers
SOURCE: none of the connections for
The product description says that your TV has 2 HDMI inputs. All you need is an HDMI cable to hook it up.
OR
It also says that it has the A/V inputs (red/white/yellow). Which you just plug in the cord that came with the PS3, each plug with the corresponding color. Good luck and thank you!
Posted on Jan 13, 2009
SOURCE: Looking for a working remote code for a ProScan
Someone else on the web used 627 and I just tried it. It works!
Posted on May 07, 2009
  • 814 Answers
SOURCE: Proscan 32LB30Q HDTV Just stopped working--1month old
This unit need to be taken to a service center to repair to be tested for component failure. The PROSCAN website for customer support is www.oncorpus.com. go to the customer support and find out where you can take your television for service. The PROSCAN customer support telephone number is. 1-888-977-6722. I hope this helps you with your problem.
Posted on May 21, 2009
SOURCE: Proscan 32lb30Q. I need to hook up wireless
You can buy a digital to analogue converter that connects to your COAX digital output and then connects to you RCA jacks. They run around $75. The only problem I've encountered is the DVD does not work through the COAX output, just TV. I'm looking into it.
Posted on Sep 10, 2009
I have a Proscan 32 in LCD Model # 32LB30Q . I had TV mounted base misplaced where can I order replacement base
You will have to order it from Proscan. The part# and web address should be in your owners manual.
Jul 14, 2011 | Proscan 32LB30QD 32 in. LCD TV
I am looking to hook up my Ps3 to the back of my proscan 32lb30qd tv. The AV multi out cords dont seem to work with the tv. Is the cord broken or am i doing something wrong.
Use a YPbPR component connection to connect your Ps3 to your TV. You can find this product at Best Buy. Just tell them exactly what you are trying to do.
Aug 14, 2010 | Proscan 32LB30QD 32 in. LCD TV
How to hook up my new PS3 to proscan HDTV. the new 80GB Sony PS3,
You will want to hook it up with a good HDMI cable and then go to that input on your tv when using the ps3
Sep 19, 2009 | Proscan Televison & Video
Jul 01, 2009 | Proscan 32LB30QD 32 in. LCD TV
PLEASE HELP ME CONNECT MY DVD PLAYER TO MY NEW PROSCAN 32LB30Q.
Use either another HDMI cable (available at your local electronics store) or a component video and left/right audio cable to connect the two pieces together. The connections on the back panel of both pieces should be color coded and clearly marked.
Apr 10, 2009 | Televison & Video
Feb 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Remote code for a tivo remote
Ok I found it!  For the Proscan 32LB30Q from Costco, the 5-digit code for the Comcast remote is 00030, and the 4-digit code is 0030.
However, I still haven't found the code I need for the TiVo remote... but we're making progress.
Jan 31, 2009 | Proscan 32LA30Q Television
None of the connections for my ps3 will work with my 32lb30q proscan 32 inch lcd flatscreen?
OR
Jan 13, 2009 | Video Game Consoles & Games
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
