Question about Linksys WRT Computers & Internet
How to setup guest access on WRT160N
It works fine for my home secured network. But I need to give my visitors my password to access internet at my home. I want them to have my visitors acess to internet as guest without passsword. How do I setup guest access?
5 Suggested Answers
kenshin99
  • 89 Answers
SOURCE: Cannot setup home wireless network between computers
Hi!
Since all computers are online, you do not need to change any setting on the router for the computers to share file or resources.
If you are using Windows XP - try this link:
http://support.microsoft.com/kb/304040
For Vista:
http://windowshelp.microsoft.com/Windows/en-US/Help/e2e03106-2546-4085-bd07-6c3ac95003111033.mspx
I hope that helps!
Good luck and have a nice say!
Posted on Dec 02, 2008
rahul26485
  • 611 Answers
SOURCE: cannot access Belkin security settings
avast virus disable it then try it you get the other wise reset the router and re-configure it after reset you get the all configuration in default setting then you easly get it but anti virus disable then work after then you can enable
Posted on Mar 04, 2009
tecnomage201
  • 221 Answers
SOURCE: Secure network
Normal 0 You should use the strongest form of encryption that all of your wireless devices can support. If they can all do WPA2, then use WPA2. Otherwise you can use WPA.
With WPA or WPA2 you should also use a strong key (sometimes called password or passphrase).
To set up wireless security, you must use a computer that is wired to the router.
Where to find the router settings: The other settings are all found in the "Wireless" or the "Security" section of the router's setup pages, located at 192.168.1.1
First, give your router a unique SSID. Don't use "linksys".
Make sure "SSID Broadcast" is set to "enabled".
Next, leave the router at its default settings (except for the unique SSID), and then use your pc to connect wirelessly to the router. Test your wireless Internet connection and make sure it is working correctly. You must have a properly working wireless connection before setting up wireless security.
To implement wireless security, you need to do one step at a time, then verify that you can still connect your wireless computer to the router.
Next, encrypt your wireless system using the highest level of encryption that all of your wireless devices will support. Common encryption methods are:
WEP - poor (see note below)
WPA (sometimes called PSK, or WPA with TKIP) - good
WPA2 (sometimes called PSK2, or WPA with AES) - best
WPA and WPA2 sometimes come in versions of "personal" and "enterprise". Most home users should use "personal". Also, if you have a choice between AES and TKIP, and your wireless equipment is capable of both, choose AES. With any encryption method, you will need to supply a key (sometimes called a "password").
The wireless devices (computers, printers, etc.) that you have will need to be set up with the SSID, encryption method, and key that matches what you entered in the router.
Retest your system and verify that your wireless Internet connection is still working correctly.
And don't forget to give your router a new login and password.
**Picking Passwords (keys): You should never use a dictionary word as a password. If you use a dictionary word as a password, even WPA2 can be cracked in a few minutes. When you pick your login password and encryption key (or password or passphrase) you should use a random combination of capital letters, small letters, and numbers, but no spaces. A login password should be 12 characters or more. WPA and WPA2 passwords should be at least 24 characters. Note: Your key, password, must not have any spaces in it.
Most home users should have their routers set so that "remote management" of the router is disabled. If you must have this option enabled, then your login password must be increased to a minimum of 24 random characters.
One additional issue is that Windows XP requires a patch to run WPA2. Go to Microsoft Knowledgebase, article ID=917021 and it will direct you to the patch.
Sadly, the patch is not part of the automatic Windows XP updates, so lots of people are missing the patch.
Note:
WEP is no longer recommended. The FBI has demonstrated that WEP can be cracked in just a few minutes using software tools that are readily available over the Internet.
Posted on Aug 03, 2009
AlliedSOS
  • 82 Answers
SOURCE: I have forgot my security password for my wrt160n
Easiest thing to do is reset the router to factory defaults and then reconfigure it. There should be a recessed button on the back of the router, press it in with a paperclip or something and hold down for about 20 seconds. If it was a wep key, there are utils like wepcrack that can try and scan your wireless net and crack the key for you but really, that would be more work than just resetting and reconfiguring the device.
Posted on Oct 05, 2009
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
Dec 29, 2014 | Cisco Linksys E1000 WirelessN Broadband...
How can I remove my neighbor from my network
Easiest thing to do, Change the password to your router. Once this is done, it will prevent your neighbor from any further access to your router and of course prevent internet access. Most all routers are simply a local web address for access. Example: 192.168.1.1 typed inside a browser address pane will take you inside the router. Check your router for setup procedures.
Have a great night..
Sep 09, 2014 | Linksys By Cisco E2500 DualBand WirelessN...
Want to put lock on guest
Linksys E series routers can broadcast 2 wireless networks. First one is the main wireless network which is secured wireless network.
The second network is a guest network which will always show you unsecured.
It will never show you secured and you can not make it secured.
However it has a web based security.
Anyone can connect to the guest network but will not be able to access Internet without Guest access password.
In other words there is a security.
You can disable guest access also.
See more about Cisco Guest network access password
Mar 10, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I have a Linksys WRT160N router that I am using with a MacBook Pro laptop running Snow Leopard. I used my computer (with some difficulty) to set up the wireless access by way of a wired connection. The...
My Friend ,
Login the router setup page .
And under router security settings uncheck the option (block anonymous internet request).
Set the wireless channel as 6 or 9.
And then use wep security key.
this will surely work.
Regards :-
Amit
Jan 07, 2011 | Linksys WRT160N Wireless Router
How do i find and delete the internet security? it won't allow much of anything to be added to my computer grand19351@hotmail.com
Have you installed the WRT160N router using the CD?
Sometimes when you install this router it will install the Home network defender software. And because of that software you may get error message while accessing some websites.
There is not way to uninstall that software but you can reset the router and reconfigure the router manually without the CD.
Once you reset the router it will come back to the factory default settings and you will need to reconfigure the router.
If you just want to change the internet security then you can open the router setup page and check the access restriction settings.
Click Here for more information about the routers and network
Oct 09, 2010 | Linksys WRT160N Wireless Router
Get stuck changing net settings, ie ssid...
if your home is set up with wireless modem or router and your computers are connected wirelessly its pretty simple to set up. more likely you or someone who set it up probably set it up securely meaning with security key and password. So you do have to know few things about your home network. like what is the name of your home network (SSID). the security setting of your home network. and finally the password of your network. if you don't know these things about your home network you will not be able to get connected wirelessly. but if you do have these info on hand read along....
JUST MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont work if you don't have a wireless setup and u are trying to connect wirelessly. people overlook this no brainer.
1) go to Settings
2) Network Settings
3) Internet Connection Setting. confirm on "O.K."
4) easy *it may or may not give you a message reading "checking network configuration2_bing.gif"
5) wireless
from this point on you need to know few things about your network.....
6) scan -- once scanned it'll give you other wirelss access point for you home network and some other near your home along with few information such as SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) SECURITY (this is the password you set up your network with) SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network will probably not do you any good since it'll probably be all locked with password and such and so should yours be.
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network. if you don't know ask the person who set up your home network)
9) on WLAN SECURITY SETTING2_bing.gif page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
10) WPA KEY - which basically means password. input the password you used to set up your home network (this is another thing you should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input all the correct info you should get the "setting list" screen
12) press "X" to save the setting
13) do the connection test and if all things were entered correctly you should have success.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network security setting, and the password of your home network.
on the other hand if you are setting up a wired connection it makes it a whole lot simpler. you don't need to know your network name, security key, and password.
make sure you have the ethernet cable plugged in to your ps3 and to your modem or router
1) go to Settings
2) Network Settings
5) wired
6) auto-detect
7) automatic -- for the IP address setting
8) do not set
8) automatic -- DNS setting
9) automatic -- MTU
10) do not set -- PROXY SERVER
11) ENABLE -- UPNP
save connection setting
test connection
if your home network is set up and u got the ps3 connected it should work
May 19, 2010 | Sony Playstation 3 (PS3) Console
No access for other laptops on my wireless router
You need to access the router's setup page using a computer that has Internet connection through the router. To do that, launch IE from that computer and type 192.168.2.1. It will then asks for a username/password. Try leaving the username and password blank. If that doesn't work, try admin for username and leave the password blank.
It will then open your router's setup page. Just click on wireless tab on the left panel and then click security. There you can set security mode to disable.
Hope this helps!
Nov 12, 2008 | Belkin (F5D5231-4) Router
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Computers & Internet Logo
713 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
