Question about Kohler OHC 16, 18 HP Service Manual TP-2480
Kohler OHC 18 starts and runs while the key is held to start but dies once you let the key go
My mower was sitting at idle and then stopped. Since then, I can't start it again however if I turn the key to "Start" and hold it, the motor runs and as soon as I let the key go the motor dies.
  • 408 Answers
SOURCE: kohler 12.5 motor starts then the longer it runs
Sounds to me like it is time for a carb kit and tune-up.
Posted on May 04, 2009
mamicheddy
  • 79 Answers
SOURCE: kohler motor starts then carb loads up with gas
If the engine is running rough then this could mean that you have weak spark or valve adjustment. When an engine runs rough it will not burn all the fuel, which will create excess fuel in the air cleaner housing. Also, make sure the the float is closing in the carberator.
Posted on May 07, 2009
  • 5681 Answers
SOURCE: no spark on my 14 hp kohler engine
Sometimes there is rust on the crankshaft and the magneto can not pick up the signal. Leave the sensor on the engine, try cleaning the rust off the crank damper and then run a clean rag between the sensor and crank. The gap varies but a old fashion matchbook seems to work in case the sensor is loose. Good Luck
Posted on Jul 26, 2009
  • 905 Answers
SOURCE: Kohler 17.5 command. will not start
The woodruff / flywheel key is likely partially sheared. Pull off the air housing, remove the starting clutch, to get to where you can see the flywheel key. I bet you will find that the key has distorted. Easily replaced once flywheel is pulled. Make sure to use the correct key when replacing it.
Posted on Jun 12, 2010
SOURCE: kohler command 18 backfires when warmed up
kohler pro 18 on craftsman riding mower. Idles fine but lacks power at high speed. i installed a new carb. does not seem like it is not opening up full throttle and will back fire if i accelerate the throttle too fast.
Posted on Mar 11, 2011
Kohler engine troubleshooting
Sounds like you got some dirt or rust in gas tank
try emptying the tank and cleaning it out. also check you bottom of you gas can too it could be souse of dirt in you tank.
Just remember to put fresh clean gas in mower gas tank after you clean it.
Aug 18, 2014 | Toro Garden
Why does my Vintage Cub Cadet 125, Kohler 12HP engine pop/backfire and die when given any throttle?
Carburetor needs adjusted. May need rebuilt or just cleaned. Could be one of the jets is plugged.
Jul 19, 2014 | Cub Cadet Garden
Problems kohler engine
it is a lean mixture problem, for some reason it is starving for fuel, could be many reasons for that, from stopped up vent on fuel cap to dirty injectors.
Jun 18, 2013 | Garden
LTX 1000 craftmans rider 18 hp ohv kohler rpm fluctuates, then dies. I let it sit for ten minutes and then start it and mow for a few minutes and then it does the same thing. is there a safety cut out
There could be some type of contaminate in your fuel/lines. Check for that!
Then check your fuel filter. and hoses.
Your carb needs to be rebuilt!
May 26, 2012 | Craftsman Garden
I've just had the same problem
check the fuel cap for a vent it needs to be vented . the air displaces the fuel no vent on fuel try running with the cap off . if it runs the vent was clogged or the wrong gas cap
Aug 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
2 mowers 19.5 hp and 27hp kohler, both die when you let off brake
Sure sounds like an elusive safety switch to me. There's usually one on the seat, the blade control, and the brake.
Jun 04, 2009 | Garden
Kohler OHC 16, 18 HP Service Manual TP-2480 Logo
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
