Program instructions for auvio 15305 universal remote
coleslaw424
  • 43 Answers
SOURCE: Sentry really big universal remote
the following is a link to the updated code list for the RMC-10, note it is in pdf format so if you do not already have adobe acrobat reader you will have to download that before you can read the code list. I will also leave the link to download the adobe acrobat reader in case you need it
Hope this helps
Carl
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
http://www.adobe.com/products/acrobat/readstep2_allversions.html
Posted on Feb 07, 2008
aprmaejun
  • 97 Answers
SOURCE: PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 20, 2008
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
The "auto" mode isn't quite presented correctly in the documentation or posts I've seen...after MUCH trial and error (and about 3 hous) I've been able to set-up ANY infrared device, either by "auto" or learn. (Although maybe not "fully".)
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. ***
I sincerely hopes this helps anyone & everyone.
Posted on Dec 16, 2008
SOURCE: RCA universal remote modle #RCR311w need instructions and codes for LXI tv
http://remotefinder.rca.com/default.aspx?site=rca is the only place you have to go to. It works!
Posted on Dec 23, 2008
  • 4 Answers
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
I work for a hotel and we have an Auvio tv that needs a new remote. I have a universal remote to program but no codes to try. Can you send me some?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily....
http://electro-medical.blogspot.com/
Jan 24, 2017 | Universal Televison & Video
How do you program it to a GE universal remote
these are the codes
LG: 004 005 009 012 050 057 080 156 227 338
  • How to Program a GE Universal Remote ' Techwalla https://techwalla.com/content/program-ge-universal-remote Lost your Remote? Need help programming your GE Universal Remote? Most TV's, VCR's, DVD Player's, Cable and Satellite Boxes will work with a GE universal...
  • How to Program GE Universal Remote: Quick Steps www.brighthub.com > Electronics > Home Theater > Home Media 2011-04-18 · How to Program GE Universal Remote Using the Code Search Function. If you've tried the codes listed for your device brand and are unable to get your ...
  • GE Universal Remote Codes and Instructions ' direcTutor www.directutor.com/content/ge-universal-remote-instructions Goto GE remote Codes. Direct Code Entry for GE remotes with 4 digit codes. 1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
  • How to Program a GE TV Remote ' Techwalla https://techwalla.com/content/program-ge-tv-remote GE universal remote controls allow users to program multiple devices onto a single remote. The remote control uses codes to detect the device, and you can...
  • GE Universal Remote Quick Start Guide - YouTube Youtube
    • BY JASCOPRODUCTSCOMPANY
    • 3 MIN
    • 216K VIEWS
    2013-04-18 · Video embedded · http://www.jascoproducts.com Eliminate remote clutter with GE Universal Remotes
  • How to Program a GE Universal Remote Control ' eHow www.ehow.com > Tech > TVs > Remote Controls
    • BY EHOW ELECTRONICS EDITOR
    Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are ...
  • May 09, 2016 | LG "32"" inch New 2011 HD LCD TV With HD...
    What is the code for APEX model ld4088
    Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites http://electro-medical.blogspot.com/. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
    Jan 18, 2016 | Universal Televison & Video
    Need Auvio TV Codes for RCA universal remote RCA Remote model RCRBB04GR
    You need to contact the manufacturer of your universal remote for any and all codes.
    Nov 19, 2015 | Generic Auvio 1366X768 19 in. TV
    Need to find manual for auvio premium satellite/cable remote.
    If you can access this site, I am pretty sure you can get anywhere in the cyberworld without any problem. Why don't you do a search on the Company that manufactured the product you bought or just the product name + manual ( auvio 15-304 remote control manual). You will have several options to obtain the manual - usually free.
    Oct 27, 2015 | Televison & Video
    Need code to program a AUVIO 15-305 Universal Remote to COBY DVD938 Home Theater System.
    Need a code for magnavox dvd player as well as step by step instruct toons on how to program that code for dvd player
    Jan 30, 2011 | Directv RC23 Remote Control
    Auvio universal remote control codes
    Need a code for ultravision tv for auvio universal remote
    Dec 09, 2010 | Televison & Video
    Tryin to program remote and cant find the instruction
    I NEED HELP WITH A PHILPIS UNIVERSAL REMOTE......TRYING TO PROMGRAM IT WITH ESA TV
    Sep 15, 2009 | Philips Magnavox Learning Universal Remote
    Televison & Video Logo
    67 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
