Question about Samsung AQV09NSD Neo Forte Wall Mounted Mini Split Heat Pump - 9,000 BTU
E101 fault code on AQV09k Air Con
The unit stopped working and started flashing E101. What is the issue with the unit and is it easily rectified?
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: AIR conditioner samsung aqv12a error message "E101
ErrorCode = 101
Explanation and Checking points = Indoor unit communication error - checkwiring
Posted on Oct 27, 2011
60000 BTU mitsubishi air.con is showing P8 error code and is blowing only hot air even temperature is set at 16 degrees. What might be the cause and how to rectify it.
go google and type in--Mitsubishi air conditioner fault code p 8-- and there are pages including a mitsubishi site that is a pdf version down load describing the fault
Dec 10, 2015 | Mitsubishi Heating & Cooling
Initially fan in indoor unit was surging,cutting in and out,now has stopped completely and red/green flash twice followed by red flashing 4 times
The flashing indicates a fault code. Not knowing what make / model you have makes it impossible to determine the exact fault. If the indoor fan was running erratically, it may just be a fan capacitor on the indoor unit. Some units have a separate capacitor, some have the capacitor mounted on the main indoor control board. Check and see if the fan starts if you give it a flick to start it spinning when you turn the air con on. If it runs and the error flash does not appear, then you will know its a fan capacitor.
Apr 12, 2015 | Heating & Cooling
Air con switches of when on heating then starts beeping 1beep 2beeps 3beeps
Some units emit a flashing code. Check your manual to see if the flashes represent a fault code.
Apr 22, 2014 | LG Heating & Cooling
Samsung Vivance mini split flashes E101 and E416, I looked up explanation, but do not understand what it means and how to solve issue
Check and replace room sensor. Once it gets rectified, automatically E416 will go off which means not running of blower motor
Nov 14, 2013 | Samsung AQV12VBCN Vivace Mirror Finish...
We have a 2007 CX7 and the air conditioning is not working well on either recirc or outside air in low ambient temps. When idling at the lights the air con becomes worse. There is no belt sqeal, and I dont...
When you have a moment pop the bonnet and look for the air con compressor run by a automotive belt on the side of the engine. Get the engine running at idle and then get someone else to turn the air con on whilst you watch the compressor. As the system is turned on the compressor clutch should engage and the unit should start turning, if this isn't happening there isn't enough pressure in the system (leak or just low on pressure) Get to your local air con guy and they will pressure test for leaks. Air con system is run on pressure, so that is really the issue you need to rectify
Note:- Manufacturers put the air con rad infront of the engine rad so stones get to that first, check the condition of the front rad through your bumper
Feb 19, 2011 | 2007 Mazda CX-7 Grand Touring
Fujitsu inverter air cond. Just stopped working properly. Model outdoor AOT30PMAL indoor unit AST30PBA-W. Code oper. Red led flashes fast continously green led (timer) repeats 13 slow flashes. After power...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
May 11, 2010 | Heating & Cooling
Remote doesn't work on air con
Should be current detect pcb faulty, or compressor drawing too much current.
I don't have your model a/c, but panasonic fault codes stay pretty much the same
Normally panasonics have this info on the inside of the access panel.
Plus fault codes from the indoor unit make it easier to look up.
if the compressor is running, check the amps and refrig pressures.
Sep 19, 2009 | Heating & Cooling
Power led flashing on air conditioner
This generally indicates a fault with the unit. Have you tried cleaning the air filters inside the indoor unit. This may help. Otherwise call Kelvinator or LG as they have similar unit and ask for their help and if it can't be rectified call for service.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
System will not start up.
This is a signal fault between the indoor and outdoor first make sure the dip switches are set start with the unit closest to the condensor set as unit 1 then next unit as 2 and so on the dip switches are inside the indoor unit on the pc board if you check the manual it will tell you which swithes to set, if this wasnt done when the units where installed they would have never worked i would also check the signal wiring between the wallmount and the splitter box / bc box and make sure there isnt a loose connection when you have ruled this out id say more than likely it is a faulty indoor board on the wallmounted unt
Jan 27, 2009 | Fujitsu 24C1 Air Conditioner
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
Samsung AQV09NSD Neo Forte Wall Mounted Mini Split Heat Pump - 9,000 BTU Logo
66 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
