Question about Dishwashers
Eswood UC25DP will not fill and start
Will not fill, once you manually set the start button off dishwasher will not wash
  • 236 Answers
SOURCE: Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Posted on Jun 16, 2007
the dr
  • 447 Answers
SOURCE: Kenmore dishwasher
needs a new control panel/ touchpad assembly very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
  • 213 Answers
SOURCE: whirlpool dishwasher mod# du1048xtpq4
whats the model number?
Posted on Nov 27, 2007
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
  • 276 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
When turning on dishwasher it just fills the base with water, tried manually draining and pressing reset buttons to no avail
Most dishwashers kick on a valve to fill with water.
There's a float in there somewhere that triggers the shut off to the filling water.
Once water reaches this cut off level the pump should be throwing water thru the wash arms.
If base isn't filling to capacity...Id look to the drain valve.
If it fills to capacity and stops...the pump may be out or something is obstructing it.
Hope this helps...
Jul 30, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
Wiring diagram for an ESWOOD ES-25 Dishwasher
You need serial number on front panel on sticker then ring Eswood. Melbourne or Sydney give them your fax no.
Dec 21, 2010 | Dishwashers
Eswood es50 dishwasher manual
Which serial number
Oct 30, 2010 | Dishwashers
Eswood commercial dish washer spar parts
Washtech UD parts can be supplied from www.ccnsnw.com however for eswood parts contact Harold on 61 2 9604 7333
Its a Sydney number and they have all parts you require - you must have the model and serial number when you call
Sep 24, 2010 | Dishwashers
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
How do you delime the hobart LXi. Where can I find the manual online?
With the unit off----hold the wash/delime button in and hold the on button in for 5 seconds.the dishwasher will fill and the delime icon will be on,then it will prompt you to add delime,add the delime and hit the wash button.It will run for 5 minutes,fill up twice and drain twice then turns off.
Feb 26, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Jun 13, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Miele G638 dishwasher.
Hi John I have the same problem, the manual says that it is because the water level is to low, this is checked by opening the door after the machine has stopped filling and before it starts to wash, the level should be 4mm above the main plastic filter ring, the level has two settings, these can be adjusted by pressing the start button and the On/Off button at the same time, release the start button and turn the control to economy 45,if the start light does not come on the level is set to normal, to increase level press the start button again and the light should come on, this will give you an increased filling time. it did no help me but it may help you. good luck
Jun 05, 2007 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
Owen Barnes
