Question about Uniden DCT758-4 Phone
Phones (4) do not work
We experienced a power failure for a few minutes and our phones(4 of them ) do not work . We tried several resets but nothing helps.The phones(DCT758-4 Phone ) are less than a year old. It seems that the memory may be gone so I treated them like you ould a new installation and that didnt help either. Any suggestions ?? We still see an active screen on each phone but when you try to dial out it says out of range. Thanks.
HELLO I NEED TO BUY THE BASE ANSWERING SYSTEM ONLY BICAUSE MY OLD IS BROKEN SERIES DCT 758-4 THANK YOU
Posted on Jun 03, 2008
If you tried the registration process discribed in the book, it is possible that the base may have gotten zapped. Happened to me. Bought a new DCT 758 (cheap at Amazon.com) with only one extra handset and used two of the old handsets with it. It will only support the handset in the base and 3 others, so you can't use all of the old ones (save them for extras).
Posted on Aug 03, 2007
I have an Electrolux ewf1090 front load washing machine, about 7 years old. Tried to turn it on. Everything seems fine, all lights and buttons work, but when I press the start button nothing happens. What...
Good Afternoon Simo, thank you for allowing me to assist you. Let's try resetting the washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn unit on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, it would be advisable to contact an experienced appliance repair tech to assist further.
Aug 27, 2013 | Electrolux Washing Machines
Citycall android mobil how to reset
2. From the Menu, select Settings.2012_12_10_17.48.24.png3. Scroll down to Privacy and select it.2012_12_10_17.48.44.png4. From Privacy (settings) select Factory data reset.2012_12_10_17.48.54.png5. Now, unless you also want to delete all the files from your SD card, make sure "Format SD card/Erase SD card" is unchecked. Then click Reset Phone.2012_12_10_17.49.8.png
The resetting process might take a few minutes. When it's done, the phone will reboot itself. If you continue experiencing problems with your Android phone, I suggest to contact your carrier.
Feb 26, 2013 | Cell Phones
I have performed several hard resets, got the updated device and desktop manager software.. 5.0.... yet it will not recognize that my smart phone is connect. The computer shows usb device connected,...
From blackberry knowledge baseJVM Error 535: Interaction with the file system has experienced a catastrophic failure.
Unfortunately there really is nothing else you can do but bring it back to your mobile provider for repairs/exchange/upgrade. Sorry but nothing you do will help. This is a hardware issue with your phone.
Jul 15, 2011 | RIM Cell Phones
Reset nokia n95
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
OR:
I hard reset my phone by *# 7370#
In some models the above hard resets dont work then
press an hold "*","#","green" simaltaneously then power ur cell phone..after few seconds u ll see a formatting screen,it will take few minutes and ur cell phone will work fine
To master reset
go in settings and choose fone settings and do master reset
Aug 26, 2010 | Nokia N95 Cellular Phone
After a power failure, the internet light in my router is red. I tried all the usual, switching on and off, resetting, disconnecting from phone and power line for several hours. Nothing makes the internet...
a red led usually indicates an error or defect. if removing the power for several minutes (or hours like you did) does not reset the error, then i'm afraid that you will have to replace the device completely. however, the root cause may still be found before the router. have you tried unplugging and replugging the modem as well?
Apr 21, 2010 | NetGear DG834G Router
CURVE 8330 will turn on (AFTER A FEW MIN) AND THATS ALL IT DOES
Dont give your cell phone to newbie to practice on, you can only trust experienced Techinicians at Dr. Cell Phone.
For more information on cell phone repair or BlackBerry Repair visit www.drcellphone.com
Jun 10, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Kenmore top-load washer,"Elite" touch-pad control shows "PF" , how do I reset to get a cycle start?
PF is power failure. Your home has experienced a power failure since the last use.
Unplug it for 40 minutes to reset.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 16, 2009 | Washing Machines
Samsung upstage SPH M60.
Leave the battery pack connected therefor it will get more battery power. That's what i do to mine and it has always turned on.
Apr 24, 2008 | Samsung UpStage SPH-m620 Cellular Phone
DCT758-4 Phone has failed
if they are less than a year old you should be able to bring them back under warranty and get them replaced. sounds like they might have got a power spike and it killed the base.
Jun 09, 2007 | Uniden DCT758-4 Phone
My phone can not reset
I am having the exact same issue! I tested the jack with another phone and it works. It is something in the phone. I suspect there is a "clear" button somewhere - but can't find the owners manual.
Dec 13, 2006 | Siemens Gigaset 4200 Cordless Expansion...
Uniden DCT758-4 Phone Logo
201 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
