Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
4 blinks??? on my Sony TV
I just replaced the 2 covergence boards on the ''D'' board. Also replaced a pico fuse on the ''G'' board. Put it all together and now the TV will not power on and it has 4 blinking lights. I know it's a V-stop fault code but where do I start troubleshootin
  • Anonymous Jan 21, 2009
    my picture is rolled up and makes it in the shape of a smily face.
    it also blinks four times and turns off.
    Champion:
  • 240 Answers
Double check a conections to vertical section
do you hear the relay click if not the problem is with the G board.
check the A board conector 509 vertical drive is on pin 2.
check ic 512 on A board.
check ic 509 part number is la78045
hope this was of sum help to you.
thamks
daniel.
Posted on Jan 13, 2009
What are the specific pico fuses for my RPTV
The amperage is marked on the board right next to them--likely if they go to the convergence circuit they will be marked 5a or 5 amp.
Usually but not always there are more at the convergence chips.
I presume you did not look closely at the board where the two you found are---Sony marks everything.
Jun 15, 2012 | Sony Televison & Video
Replaced Convergence chips, same problem
This set has pico fuses on convergence board and also on G power board, there should be 2 5 amp pico fuses on power board.
If convergence is bad exactly as before double check the power board fuses and check to see if voltage (it is marked!) is there with power board disconnected from chassis..
Steve
Mar 01, 2012 | Sony KP-61HS30 TV
Kd-46wt500 sony big screen colors dont line up is projectors goin out picture on tv is blurry pic looks stretched out as well
Can you verify the model number and see if its A KP46WT500 model? If so chances are just the convergence Ics ( stk 392-560 ) and pico fuses are the problem. There are 6 3.5 amp pico fuses directly beneath the heat sink fins on the D board ( where the Convergence ICs are located) Check those six pico fuses and also two 5 amp picos on the G board ( where power cord plugs in) if any of the picos on either board are open then the Convergence ICs will require replacement.
Sep 26, 2011 | Sony KP-46WT500 46" Rear Projection...
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
I Change the two stk for the convergence but steel have troubles
most sony models require the 6 pico fuses on the D board and the 2 Picos on the G board will require replacement along with the two ICs. Did you check the pico fuses?
May 28, 2011 | Sony Televison & Video
How adjust the covergence in kp-51hw40? I remplaced both stk392-560 rgs Pedo
Did you check the 6 pico fuses on the D board and also the 2 pico fuses on the g board. Usually one on each board will require replacement with the new ICs. Then just pressing the perfect focus should reset the convergence after the picos have been tested and the blown ones replaced.
May 03, 2011 | Sony KP-61V85 61" Rear Projection...
I have a Sony KP46WT500 projection television. It shut off by itself and the red light is blinking 6 times. I've replaced the A & B boards and I'm still having this problem. What am I missing? I...
Hi, I got the same problem, you need change the pico fuse, the 2 STK, if you will do that and does not work need change the G Board ( Power Supply),but you can repair it, unplug the wire ac det and the TV will power on, but don't forget replace the pico fuse.
Mar 12, 2011 | Sony KP-46WT500 46" Rear Projection...
I've replaced my STK's, 2 pico fuses on the G boards, and tested each convergence resistor along with the pico fuses on the D board--albeit they were still soldered in place. I desoldered two pico fuses...
I believe there is a power board on the left side when looking from the back. It will be vertical, right next to the board you worked on. Take that board out. I believe there are about four pico fuses on that board. One or two of them will be open. Replace the fuses and you should be good to go.
Feb 19, 2011 | Sony KP-57WS500 57" Rear Projection...
KP-46WT520 46 in.
Either IC708 is faulty on the A board or the two pico fuses are blown on the A board PS701 and PS702
Jun 25, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
