Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Disassembling the mixer
Hi My daughter got a wonderful classic mixer on yard sale (it is KitchenAid K5A). It works fine but power cord must be replaced (insulation is cracked all over it). I took it from her (because it's unsafe) and promised to replace the cord. I removed the mixer from the stand. Removed screws that are supposed to hold top (mixer part) together. But it does not come apart. Can you suggest anything? Thank you! Michael
  • 3 more comments
  • Anonymous Dec 24, 2007
    I am unable to get the housing apart to get at the gears, dispite removing all screws, nuts, and bolts. I looked at the manual in the link, and although it does show an exploded view, it does not show how to disassemble it. Any other links showing greater detail?
  • CherylS Apr 05, 2008
    Exact same problem- I have one handed down from my Mom (K5-A) and the cord split. I can't get the Main body of the mixer apart to fix it
  • bakermom Sep 10, 2008
    Neither of the repair centers her work on hobart/kitchenaid K5A. I still cannot get the mixer apart. Any suggestions would be helpful. Thanks
  • Anonymous Dec 13, 2008
    Inherited Kitchenaid K45 from parents. Must be 40 years old or more. Need to replace power cord. Cannot get thing apart for access to electrical connections for cord.
  • horseman1968
    horseman1968 Aug 07, 2012
    there are pins you have to knock out with a small punch at some points...wish I could remember them all..and a cotter pin or two as well
  • 640 Answers
Does the plug run through the base or the back of the unit?
Posted on Aug 01, 2007
    New Friend:
Trust me, it does come apart...it could be you just need to give it a good whack with a rubber mallet..mine is in pieces after replacing the cord because I have six yellow wires i didnt mark...hint:mark your wires :)
Posted on Aug 07, 2012
Go to:  http://neilcrockett.com/mixer.htm
Posted on Mar 03, 2008
There are a number of places that have parts and have manuals that are similar to the machine you have. http://store.mendingshed.com/kitaidparts.html This place sells parts and has the shop repair manual for one generation later of your mixer but is basically the same thing. If you decide to have someone else rebuild it for you this place will do the whole thing for $69.95 which I think is a good deal; Hobart made your mixer so you might contact them as well for service. One other place rebuilds classic mixer as well and they specifically mention your model for repair @ $59.95; again a good deal. http://atomic-era-machine.bravehost.com/ Good luck and it is possible to fix it yourself with the downloaded shop manual but it might be more cost effective to have to it serviced by a professional.
Posted on Aug 19, 2007
Can anyone tell me the value of the resistor in a Kitchenaid K5A mixer. I think mine grew legs and walked away. Thanks, Mike
Are there any colors on the resistor or it is missing. If you know what the voltage and current should be in the circuit you can calculate the resistor value.
May 08, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid k5a
These mixers last for years and years. Aside from the fact that you could have a FIRE from a frayed electrical cord, interruption of power to the motor can cause additional problems. Get the Manual with all of the details on repairing the unit. Replace that power cord NOW! When the Housing is open, take a tooth brush or stiff paint brush and whisk out the debris collected inside over time. Check the contacts on the speed selector and look for any black deposits or surface material that may be there.
Mar 10, 2014 | Food Mixers
KitchenAid k5a arcing on control board
it was stuck on high speed because the phase control board went out, your fix may not be absolutely 100% and it is now causing an uneven distribution of the electric charge in the mixer and it is arching. My recommendation is to replace the speed control board (black and copper plate) and the phase control board. i bet it fixes the problem as these are the two parts that regulate the electricity in the mixer. Hope that helps. Buy the way if you don't fix the problem and continue to use the mixer you may have to replace the motor eventually as you can cause the armature and stator to short or burn out.
Feb 03, 2013 | KitchenAid K5ADH 5 Quart Mixer Dough Hook...
Which is the better mixer of these old models: K5A K5-A or K45 SS and what is the difference? KITCHENAID HOBART K5A K5-A 300 WATT MIXER and the KitchenAid Hobart Vintage K45 250 WATT. Thank you
Hello ajlina,
All of these are great home use units, all the attachments are interchangeable between these. The difference between these mixers is the K5 is a 5 quart mixer and the K45 is a 4.5 quart mixer. As I own both of them they are great in the kitchen and have the same durability.
Have any more questions please post to this thread and I will be happy to assist. Thank you for using FixYa.
Dec 09, 2010 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
K5A refurb/repair
First thing check the carbon brushes, when they wear out they arc at the armature. Two black screw covers one either side of the top motor housing. The brushes are keyed to only go back in one way so make a note of which corner of the brush has been shaved off. If you look in the hole with a torch you can see the little blocker in one corner deep down. As a rule it's back top corner on one side and back bottom corner on the other side.
Oct 21, 2017 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
3,052 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
