Question about Hitachi 53FDX20B 53" Rear Projection Television
Hitachi 53FDX20B Screen and Sound Shut down (Pwr light remains on
Have a 2002 53FDX0B, Picture and sound were working and then it shut down. Powered on and off, everything reset and worked for about 20-30mins and then it happened again. Length of time between resets has shortened to about 1-2 mins. When the screen shuts down the front power light stays on. Removed back of TV, when the problem occurrs there are 4 green LED's and 1 Red that remain lit even though the screen and sound don't work. Can see 3 fuses which appear to be okay. Don't see or hear a fan. TV has 3 color tubes. Any ideas would be helpful
  • mh5117 Jan 13, 2009
    Where can the Eeprom be purchased and on what board is it located? I have purchased and downloaded the Service Manual.
  • Bryon Reed Dec 30, 2013
    Loose cracked connections on vertical output IC, Resolder
    New Friend:
    Problem Solver:
  • 16 Answers
Posted on Dec 30, 2013
    Champion:
  • 240 Answers
You need to replace the Eeprom location 1004
regards,
daniel.
Posted on Jan 13, 2009
3 Suggested Answers
  • 2920 Answers
SOURCE: Hitachi 53FDX20B Projection TV:Picture and
check the transformer...it carries power to everything
tlm931
  • 273 Answers
SOURCE: TV PIcture and Sound Shut Down
it would appear its shutting down in a protect mode
its possible its a convergence circuit problem or something on the deflection bd
but it most likley will require some assistance from a tech that is used to working on this type of set
if you noticed when it does come on that the colors are all off line then suspect convergence circuit trouble the the green leds tell you what source is still alive there is a chart in the cabinet that will correspond with each source voltage that can lead you to tracking it down if you know what to look for and have the tools to do so
Posted on Jan 21, 2009
Hitachi Model No. 53FDX20B - picture has gone out. power light is on but no picture or sound
Replace Both of the STK ICs they will have Part Number on them,example STK392-570
Mats Electronics has ICs 1-800-628-1118
Jun 20, 2011 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53fdx20b
If you have OSD (on screen display) but no video or sound, you may have a problem with your video input switching or video processor. Either way this could require tracing the signal with an oscilloscope and could get expensive.
Nov 15, 2009 | Hitachi 53FDX20B 53" Rear Projection...
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
Aug 04, 2009 | ASUS Eee PC 900 Notebook
53FDX20B NO PICTURE AND SOUND
It powers up but no picture? In my experience with Hitachi TV's this has been an issue with the convergence IC's failing. You will need to have a technician replace those if needed.
Jul 23, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Logik tv
I just experienced the same issue that is described in the previous post. I went through all of the standard trouble shooting modes.
  • Powered down the LCD
  • Switched HDMI cables
  • Checked and reset all connections (even unrelated devices)
I finally got a picture when I made a straight cable connection. I have a sling box attached through my cable box and noticed that the picture was fine when viewed on my PC. I thought it had to be a problem with the LCD. As a last ditch effort I powered off my DVR box, it must have reset the signal from the cable box to the television because everything is working again. I hope this helps you.
Television: 46" Sharp Aquos (LC-46SB54U)
DVR: Scientific Atlantic Explorer 8240HDC
Feb 01, 2009 | Televison & Video
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
Jan 24, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Jan 16, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
260 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
