Question about Electrical Supplies
My Hayward Swimpure Plus is not generating. When I power it up I get the no flow light blinking. After is recognizes flow it goes out and the generator light comes on for about 10 sec. After that I have no lights at all. I pulled the fuse and it looks good. What do you think?
CarlGehrke
  • 169 Answers
SOURCE: 10kw Generac shut down overspeed
Make sure that the throttle linkage is all there and not damaged/misadjusted, then get a manometer and check your inlet gas pressure. Gas pressure should be 8 inches of water column and stay there running or not.
Carl
Posted on Apr 06, 2009
SOURCE: my honda ev6010 engine runs good, but stopped
I am looking for an EV6010 Honda generator. I know they stopped manufacturing them, but I would like to know if anyone has a leftover for sale?
rmhoch@hotmail.com
Posted on Aug 19, 2009
SOURCE: My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Posted on Sep 30, 2009
SOURCE: I have a new Generac 20KW Propane generator with a
Sounds like the electritian wired something wrong. Control wiring for that generator should be:
N1 and N2 = 240 vac utility input
Wire 0 = ground
Wire 194 (15B) = + battery
wire 23 = transfer signal
Posted on Oct 30, 2009
SOURCE: Black Max 6250 generator worked good for 10 hrs
Hi there:
Remove the back cover and look for damaged brushes or electronic parts, I'm assuming you have some electric-mechanical skills. otherwise you better take it to a service shop
Posted on Jan 28, 2010
We just installed a RJ 45 Circu pool Salt water system. When we turned it on the no flow light continues to blink and the generate light goes on and off. Any ideas?
Turn up the speed on your pump?
Ensure the filter is clean and no lines are clogged.
Otherwise call the manufacturer
Mar 26, 2017 | Pool & Spa
Hayward Aqua system filter will not run
Hi, I believe you have an Aqua Rite Salt Chlorine Generator. Check system with no flow will always happen on start up but once flow is constant it will go away.
Sep 01, 2014 | Pool & Spa
Why will my hayward h 250 millivolt pool heater pilot light not stay lit
Looks like your pilot generator may have some corrosion on it. Follow the stainless steel tubing on the gas valve as it goes down to the burner area. At the end of this is the pilot assembly. If you can remove this so your able to work on it you will se a short metal rod that the pilot flame touches when lit. This generates current that keeps the gas flowing to the pilot to keep it lit. Take some sand paper and give it a light sand to remove any corrosion on it. Reassemble at put it together. You may also need to clean the pilot tube(stainless tube from valve). Small spiderwebs can reduce the flow to the pilot and cause this problem also
Jun 25, 2014 | Hayward 250kbtu Ng Pool Heater - Inground
Swimpure chlorine generator not working
Did you figure this out ? I have the same problem.
Sep 03, 2012 | Hayward Industrial Products SwimPure Salt...
T101r wiring a salt chlorinator
Is this 120Volt or 240Volt?
Where are the wires coming from.
How many wires does the Hayward have?
What is a pressure plate?
'Hook up red wire to Load?' Load usually means the chlororinator or motor that you want to connect wires to.
Are you using T101R 120Volt timer?
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Jul 30, 2012 | Solar Intermatic T101r 120v 40amp Timer...
Can/ how to adjust millivolt seeting for a lower power pump?
Before you do anything, check with Hayward as to the minimum flow they require to maintain safe temperatures in the heater. You may have to throttle the heater back. They may have a lower value pressure switch you could use, too.
May 14, 2010 | Hayward 2001 Series Millivolt Gas Pool...
Electrical Supplies Logo
326 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
